lift pump help ?? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 1bAdmAx, this thread has received 6 replies and been viewed 887 times.
post #1 of 7 (permalink) Old 03-09-2008, 05:47 PM Thread Starter
lift pump help ??
any one have pics of a lift pump install i want to run ppe but have no idea how to do this pump install pic or info would help alot do i have to run a return line off the tank ?:smoke
1bAdmAx is offline
post #2 of 7 (permalink) Old 03-12-2008, 03:42 PM
ill let you know friday thats when i will have mine in
Jared Duramax is offline
post #3 of 7 (permalink) Old 03-16-2008, 08:22 PM
I am curious about this also. I have an edelbrock 1792 to install but the fuel line is a metal line all the way to the engine compartment. Do you install it inside the engine compartment? Where have you guys mounted them before?
03 Chevy Silverado 2500 HD, K/N intake, PPE boost fooler, Edge hot juice w/monitor, 4" MBRP turbo back exhaust, Line X bed lining, B/W turnover hitch, Merchant Automotive xfer case pump upgrade
Dux2bux is offline
post #4 of 7 (permalink) Old 03-17-2008, 11:53 PM Thread Starter
some of the people i have talked to say use the line off of the fuel cooler infront of the tank but do i need a return im lost when it coms to this thing to be stright foward i just go by what i was told...
1bAdmAx is offline
post #5 of 7 (permalink) Old 03-18-2008, 01:35 AM
What type of lift pump are you going to use? The 150 FASS on mine was very easy to install.
maxxis_mudder is offline
post #6 of 7 (permalink) Old 03-18-2008, 02:47 AM
There's a couple holes in the frame just in front of the fuel cooler that work well. make a mounting plate for the pump and mount it there. You have to get the fuel line quick disconnect fittings (Lisle Tool, IIRC) and run the pump from the lines coming out of the cooler. Good idea to run a bypass around the pump if the pump is not a flow thru one, so if it fails the CP3 can still pull fuel.
PPE, 1792 dont use a separate return. Fass, Airdog do.
I'm thinking of running a NAPA filter setup with a PPE pump.
TheBac is offline
post #7 of 7 (permalink) Old 04-22-2008, 06:13 AM
diesel idiot
Tom I run a NAPA filter head in front of my 1792 style pump. Works great, just be sure to change the filter often. I can hear my lift pump start to bog when it gets dirty. I mounted it on the tank shrouding and its really easy to change.
2004 Chevy CC/SB LB7 LT3
EFILive, SC Trans w/ 1058 by me, Traction bars and centerlink braces built by me, Custom adjustable stock wastegate, 6 inch custom exhaust, 1792 Lift Pump, Belltech 3" drop shackles, Black H2's w/ Falken 285/60/17s for summer, BFG 315/70/17s for winter, SD sleeves, DiPricol EGT and Boost gauges on the pillar along with an Aeroforce for rail PSI and trans temp, 2 Kicker Comp CVT 10's w/ memphis amp, t-rex full face billet grille,limo tint, .Oh yeah I'm 20 and I built and tuned it myself.
tahoedmax is offline
