Help - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Diesel Dave 04, this thread has received 4 replies and been viewed 653 times.
post #1 of 5 (permalink) Old 03-13-2008, 03:11 PM Thread Starter
Diesel Dave 04's Avatar
Help
Im swaping a 5.3 in s 2000 chevy silverrodo 4X4 What were they thinking, How do you get to the 2 upper Bellhousing bolts? I removed the intake plenam to get the old enging out but I really didnt want to take the intake plenam off a new engine to install it. is there a way around this?
Please help asap Thanks Dave
08 F-350 crew cab Lariat 4X4 Dually auto 4:10 gears.
rideing on Hankook Dyna pro AT's
Diesel Dave 04 is offline
post #2 of 5 (permalink) Old 03-16-2008, 03:17 AM
can you use a very long extension and go up from underneath? That;s usually the best way to get those PITAs on most vehicles.
TheBac is offline
post #3 of 5 (permalink) Old 03-16-2008, 03:19 AM Thread Starter
I got it
post #4 of 5 (permalink) Old 03-16-2008, 01:44 PM Thread Starter
what I did was set the engine in and bolt it to the bell with the 6 bottom bolts then later once the engine mounts were bolted up I removed the tranny mount and lower the tail end of the tranny down and it gave just enough room to get up to the bolt at 10 Oclock and i got the 12Oclock one from up top. I wouldnt want to try this job without a lift in the shop.
post #5 of 5 (permalink) Old 03-19-2008, 03:37 AM
I cut holes in the floor and put conduit plugs in them, just pull the carpet back and use the right size hole saw. Inch and a quarter conduit is about 1 1/2 in dia hole and the plugs are about $1.60 a pair.
keydl
81 Isuzu /C223na, 5spd
keydl is offline
