1982 chevy silverado 6.2 electric problems??? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by vr6vince, this thread has received 5 replies and been viewed 2800 times.
post #1 of 6 (permalink) Old 03-23-2008, 06:12 AM Thread Starter
could sumone please help me?
i hav a 1982 chevy silveerado with a 6.2 in it and i cant get it to turn over.
whenever i turn the ignition to start it it just goes dead,but the glow plugs and clock work and thats about the olny thing that work....the horn,headlights not evan the fourway flashers dont evan work???? I thought it was the batteries or the battery cables but i charged,tested the batteries and cleaned the cables and still the same problem.
can somebody please help me????
vr6vince is offline
post #2 of 6 (permalink) Old 03-23-2008, 03:21 PM
if you are + the batteries are fine, then try replaceing the cabels themselves. i met a fellow a year ago who had the same issue. like to drove him crazy. he finally found the problem to be the cabels themselves. this particular truck spent sometime near the coast, and the salt air over time had corroded the insides of the cables[ last few inches on the ends]. he said they were all blackish on the inside, after he stripped them back a ways. i have a few of the early models gm 6.2's, and have noticed two of the trucks have done the same thing. only mine are not bad enough to cause a starting problem as yet. also chk your starter connections as well. possible , but not likely you have a starter issue as well. chk all connections first. also be certain that you do indeed have TWO good batteries. i have seen batteries casue all kinds of goofy quirks with these trucks!
navistar45 is offline
post #3 of 6 (permalink) Old 03-23-2008, 04:37 PM Thread Starter
thankyou for ur help....
ill look into it rite now
vr6vince is offline
post #4 of 6 (permalink) Old 03-24-2008, 05:57 AM
Down nest to the starter are 2 wires that power the truck and charge the batteries, they have fusible links on them.
You can test to see if that is the problem by putting a jumper wire from the positive battery to the junction stud at the middle of the firewall that feeds the A/C. If that lights up the truck, fix the wire. The battery cable is often bad at the bottom end, if it has broken insulation at the starter take it off to inspect. A battery shop can replace the end terminal if you don't solder, or you can buy a new one. Don't cheap out on the battery cable get the right gage wire for diesel.
keydl
81 Isuzu /C223na, 5spd
keydl is offline
post #5 of 6 (permalink) Old 03-24-2008, 04:55 PM Thread Starter
i just tried that and i got no where,the starter finally made sum noise but dident spin over,sounded lik it was about to but it dident want to...
vr6vince is offline
post #6 of 6 (permalink) Old 03-24-2008, 09:22 PM
Then it is time to get the volt meter out and start with any non working circuit and trace to the gap on the circuit.
The fusible links at the starter are common, burned connectors at the fuse block are fairly far down the list. Failed ign electrical switch is common with increased loads for misc stuff. The ign sw is on top of the steering column about 6 in under the dash - it is held on with 2 8mm head screws on the left side of the column. The BAT2 terminal is often burned out of the connector and the switch.
keydl
keydl is offline
