How do I disable the airbag on a 95 K1500? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by JeffLipinski, this thread has received 1 replies and been viewed 919 times.
post #1 of 2 (permalink) Old 01-11-2009, 04:55 PM Thread Starter
I put a snowplow on my friend's 95 K1500 chevy PU. I won't let him plow with it until I get the airbag disabled. With my luck he would hit a curb too hard and POOF!. Anybody know how?
JeffLipinski is offline
post #2 of 2 (permalink) Old 02-01-2009, 11:46 PM
dagon dagon!
very carefully!!!!! I must warn you that the slightest static shock can trigger an airbag causing serious injury or possible death. never put your body in the air bag unit area, stay to one side of the unit, don't put your arms through the steering wheel and while the unit is out face the trim piece away from you.
-disconnect the battery and air bag fuse
-wait about 30 minutes
-unscrew the airbag unit (4 screws in back of steering wheel)
pull the unit out and there will be 2 wires going into the column, usually white and there should be a yellow connector. disconnect that connector and cut the two wires off right where they go into the unit tape the exposed wire ends
-place the unit back in the steering wheel and secure the 4 screws.
-leave the air bag fuse out and reconnect the battery
-see if the rookie can drive.
Navy_Seabee_CM is offline
Ford 2003.5-07 AUTOLOCK ENABLE/DISABLE Bcarriveau Ford - Modification instructions, Product installs and Tech Articles 1 01-05-2009 05:06 PM
Disable EPBV and Get Better MPG???? Mikey00F250 1994-2003 7.3L Power Stroke 3 01-31-2008 06:16 PM
AirBag Light? Jays7.3 1994-2003 7.3L Power Stroke 0 11-19-2007 03:33 PM
front seat for 1984 gmc k1500 staszekgra General Parts and Accessories 1 08-19-2007 01:37 AM
SCT egr disable? Carssuck 2003-2007 6.0L Power Stroke 9 07-31-2005 04:27 PM
