lift - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by firehillbilly, this thread has received 5 replies and been viewed 875 times.
post #1 of 6 (permalink) Old 05-07-2009, 03:11 AM Thread Starter
resident mason
firehillbilly's Avatar
lift
Trucks almost mine. Time to think about lift/tires. Probably 6" or so. Still used everyday for work so not to tall. Who makes the best? Knuckle kit or spindle? Been checkin on them range from 1200 to 2500+ so big spread there. Any suggestions? Like to run 33's or 35's.
06 Sierra 2500 4wd lb. Predator, S&B, MBRP duals-no cat, Quadzilla gauges, Allison Jr., Riderite air bags, PPE Tie rod sleeves, egr plate / finger stick. 02 Chevy 3500 8.1L 4wd dump 9' Fisher mm2, sander. 03 Kubota L4630. 80'S or 90's Komatsu pc50. 89 d250 5.9 which may someday go into something.:
firehillbilly is offline
post #2 of 6 (permalink) Old 05-07-2009, 03:38 AM
If all you want is to run 35's just find the right wheels and maybe do a bit of bumper/fender trimming. H2 wheels seem to work really well, but they only come in 17" and I wanted to stay with 16s. I have the cognito upper control arms and t-bars cranked about 2" above stock, and with the wheel I have I had to do quite a bit of trimming. If you wanna see some pics I can try and get them up tomorrow. Tahoedmax had 35's and actually lowered his suspension w/o any rubbing.
If you really want to do a full blown lift I think cognito has a great product.
mckey73 is offline
The Following User Says Thank You to mckey73 For this addition to TDG:
firehillbilly (05-07-2009)
post #3 of 6 (permalink) Old 05-07-2009, 05:10 AM Thread Starter
resident mason
I don't really care about a full blown lift. My tbars are already cranked about an inch and w/ air bags in back I still get raked stance which I like. I just want more rubber on the tar and slight lift. I load crap in and out of this truck daily so stock height is perfect but not really. Don't really want to trim anything except bumper. Here we get a lot of salt on roads in winter and trimming means fresh cuts which are hard to seal and so you get rust. i'll check out cognitos stuff though. thanks.-Neil
post #4 of 6 (permalink) Old 05-07-2009, 02:51 PM
You might get a little more lift with the cognito UCA's, but it might work with the right wheels. 305's would have definately cleared w/o any fender mods. I know the GMC bumpers are a little closer to the wheels but I still would have had to cut mine to fit the 305's.
mckey73 is offline
post #5 of 6 (permalink) Old 05-13-2009, 01:30 AM Thread Starter
resident mason
just want 305's on 8" rim. what do you get about 3" from just the ucas? like to not crank tbars any higher.
post #6 of 6 (permalink) Old 05-13-2009, 02:27 AM
I didn't upgrade to the green keys since I was able to level the truck with the stockers. They are maxed out and I think it gave me about 2". The half shafts don't look to be at too extreme of an angle. If I ever upgrade axle shafts then I might go higher.
mckey73 is offline
Lift is Done - Clearing out extra lift parts TxFireman1972 Whats Been Sold 0 01-12-2009 09:32 PM
Body Lift + Suspension Lift evictorwalli General Ford Truck and Excursion 7 02-29-2008 04:47 PM
Lift or not 07 350 NWGMonst General Ford Truck and Excursion 4 01-24-2008 10:42 PM
4" lift and 6" lift pic's firecat General Ford Truck and Excursion 6 09-15-2007 01:41 AM
anyone need a 6" lift for their stock lift... I know a guy needs stock 01quadcab 5.9L Cummins (1998.5-2002) 8 06-21-2007 04:54 AM
