A/C stops working - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by sexytrkr, this thread has received 9 replies and been viewed 4101 times.
post #1 of 10 (permalink) Old 05-25-2009, 10:02 PM Thread Starter
truckn'
sexytrkr's Avatar
Send a message via AIM to sexytrkr
Angry A/C stops working
A/C stops running when it rains or the radiator gets wet...any ideas?
2014 T800W 600hpISX15 18spd yanking a 2003 XL specialized 110HD with the cheater neck.
93 peterbilt 379ex hood. 3046B 18spd (in time out, broken crankshaft)
Lonestar Diesel club #9
sexytrkr is offline
post #2 of 10 (permalink) Old 05-25-2009, 10:24 PM
Mafia member #105
ripmf666's Avatar
Send a message via AIM to ripmf666 Send a message via Yahoo to ripmf666
Go under the hood and check all the wires to the ac.If needed I will look up the Gm specs to help you in a few and post those.also post the vin in the vin check area and I will check to see if it has ever been repaired before.
Devil Girl 2006 2500HD LBZ Ex-Cab 4x4
EFI Live tuned by IdahoRob,MPI twins installed by BigDipper,PPE lift pump, BigDipper 30% injectors, BigDipper Trans Precion ML converter.PPE Twin Cp3's.
Alot Of thanks To Kat & Pat at duramax diesels, Joe & Dan at PPE,George aka BigDipper
RIP LBZ 6/1/[email protected]:44pm she was strong
She's Alive again
Born on July 27, 2008, 11:59:02 PM
http://www.dieselbuilder.com/Media/P...adoBuild_2.pdf
ripmf666 is offline
The Following User Says Thank You to ripmf666 For this addition to TDG:
sexytrkr (05-25-2009)
post #3 of 10 (permalink) Old 05-25-2009, 10:49 PM Thread Starter
truckn'
sexytrkr's Avatar
VIN Posted....
sexytrkr is offline
post #4 of 10 (permalink) Old 05-27-2009, 02:30 AM Thread Starter
truckn'
sexytrkr's Avatar
UPDATE
ok, so checked all the connections and everything looks good...drove around today in 55 degree weather and the AC worked fine (snowflake symbol stays lit). Im thinking its a computer problem...I unhooked the batteries for about 30 minutes to reset the computers..Is there someway to reprogram the computer all together?
I havnt heard of this being a common problem and the fact that there arnt alot of people replying kinda reinforces that.
sexytrkr is offline
post #5 of 10 (permalink) Old 05-27-2009, 08:30 PM
'Ol Builder guy
Duke's Avatar
That makes me take pause a moment. My "snowflake" will blink, then go out if I try to run AC with recirculation in certain HVAC positions.
I wonder if this is your problem, too?
Duke is offline
post #6 of 10 (permalink) Old 05-28-2009, 02:16 AM Thread Starter
truckn'
sexytrkr's Avatar
when it acts up, i have it shut off, then push "AUTO" which should turn my snowflake(ac) on...but it doesnt. if i push the AC button manually then the snowflake flashes and then goes out and i dont get any AC...when it works correctly, the ac works in all positions.
but for the past 2 days its been working fine. rain, 50degree weather, etc etc..frusterating
sexytrkr is offline
post #7 of 10 (permalink) Old 06-03-2009, 11:40 AM Thread Starter
truckn'
sexytrkr's Avatar
Still have this problem guys. its getting frusterating, it only does it when it rains for awhile...then once the rain stops and i drive for 30 min or so it starts working fine again on its own.
I thought about taking it to the dealership, but theyre going to throw parts at it and charge me to do it.
sexytrkr is offline
post #8 of 10 (permalink) Old 06-16-2009, 08:39 AM
DmaxJake's Avatar
Send a message via AIM to DmaxJake
Possibly the compressor clutch to pulley clearance is out just enough that its good when it's dry but when wet it slips. Pretty far fetched but just a thought
07 Classic Duramax LBZ
-EFI Live by [email protected],PPE fuel valve shim kit, Banks Gauges, Intercooler, Bully Dog Shift enhancer, Airaid Intake, Diamond Eye 5" straight pipe, [COLOR="Red"][COLOR="Red"]Snow Performance stage II
410hp/767Lb-ft @ fall brawl 2009
DmaxJake is offline
post #9 of 10 (permalink) Old 08-06-2009, 01:20 PM
I am having the same issue on my 2005 3500 Dually 4x4 crew longbed did you ever find a resolution?
DV8OR is offline
post #10 of 10 (permalink) Old 08-07-2009, 02:51 AM Thread Starter
truckn'
sexytrkr's Avatar
PM replied.
I found a connector hanging below the passanger side in front of the tire. I set it in the tray for the air filter housing and havnt had a problem since. any ideas?
sexytrkr is offline
suspension stops? brentos Sled Pulling 11 05-02-2009 07:51 AM
4wd stops working,IN NE OHIO!!!!! little2000 1994-2003 7.3L Power Stroke 2 01-15-2009 05:19 PM
and bump stops 6L strokin Sled Pulling 5 12-31-2008 02:23 PM
turbo just stops working? SmokingIDI_7.3L 2003-2007 6.0L Power Stroke 10 02-03-2008 11:17 PM
Bump Stops??? NFA Fun General Ford Truck and Excursion 1 10-24-2006 08:54 PM
