Throwing out an idea - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by New 0mega, this thread has received 4 replies and been viewed 772 times.
post #1 of 5 (permalink) Old 06-28-2009, 03:58 AM Thread Starter
Pardue the Traveler
New 0mega's Avatar
I have this idea for Common Rail heads for 6.5L and 6.2L. I understand that the 6.2/6.5 are not the greatest motor design, but I would have figured that someone would have tried to make this mod with all the 6.2/6.5's still around.
Singles Club member #250
New 0mega is offline
post #2 of 5 (permalink) Old 07-03-2009, 03:21 AM
I think the result would be the return of the Toroflow and 5.7 because they won't handle the fuel flow that most would set them up to.
keydl
81 Isuzu /C223na, 5spd
keydl is offline
post #3 of 5 (permalink) Old 07-03-2009, 08:46 PM Thread Starter
Pardue the Traveler
New 0mega's Avatar
I was thinking of marine/generator applications where the motor is running a lot, would it not be more efficient to have a common rail head in that instance.
post #4 of 5 (permalink) Old 07-04-2009, 04:01 AM
While you are at it chance the timing chain to a balanced gear drive and it may live long enough to pay for the parts in fuel savings. or just start with an engine that will run 25k hours to start with lie a Thermoking.
keydl
keydl is offline
post #5 of 5 (permalink) Old 07-06-2009, 05:30 AM Thread Starter
Pardue the Traveler
New 0mega's Avatar
And a whole list of other changes to make the motor last longer.
I'm no engineer or a fabricator so designing common rail heads is a bit out of my league unfortunately. .
Suspension idea... Good Idea???? Snowaholic 5.9L Cummins (2003-2007.5) 8 10-17-2007 06:37 PM
'07 throwing codes Muddin Duramax 2006-2007(LBZ & LLY) 6 09-20-2007 12:10 PM
Good Idea or Bad Idea? moparcummin 5.9L Cummins 12 Valve (1994-1998.5) 10 02-24-2007 05:29 PM
04 throwing codes 973604x4 2003-2007 6.0L Power Stroke 0 06-13-2006 06:24 AM
