Kelderman Air Ride Rear 2 bag system info?? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by New 0mega, this thread has received 2 replies and been viewed 1759 times.
post #1 of 3 (permalink) Old 07-20-2009, 03:31 AM Thread Starter
Pardue the Traveler
New 0mega's Avatar
Has anyone here put the kelderman rear 2 bag air system in their truck? The one class 4 hitch that has the air bags that replace the rear spring mounts. How does it handle a trailer? Is it really worth the effort to put it on?
Singles Club member #250
New 0mega is offline
post #2 of 3 (permalink) Old 07-21-2009, 04:35 AM
The '93 Dodge has it and it maintains the headlight aim and rides well empty. It usually carries a camper ( 2k) and sometimes pulls an equipment trailer ( 900 hitch ). It is 18# empty, 42# with the camper and 66# with the trailer. And a bicycle pump takes a min or so to pump it up if I change some place without air.
Truck and trailer are both well behaved, hitched to gather or with something else, loading other stuff on the trailer than the tractor I either use the spring bars w/cams or load forward for a level arm at the air bag. I think they would work as a scale, the same as air ride on the heavy trucks. Plot the dots for 4-5 weights for a #'s per 1K.
keydl
81 Isuzu /C223na, 5spd
keydl is offline
New 0mega (07-22-2009)
post #3 of 3 (permalink) Old 07-22-2009, 07:58 PM Thread Starter
Pardue the Traveler
New 0mega's Avatar
You should get the optional compressor that would save you some time when you can't find air.
info on fuel system 97CumminsTurboDiesel 24 Valve Performance 12 05-17-2009 10:03 PM
Looking for Air Ride / Lowering info for 4x4 Excursion bakantor General Ford Truck and Excursion 23 09-13-2007 11:13 PM
Fuel system info needed StuckinMud 2003-2007 6.0L Power Stroke 9 09-12-2006 03:12 AM
Need rear axle info Strokerin General Dodge Discussion 15 08-04-2006 04:40 AM
Anybody running Kelderman Air-Ride??? 4S FED General Ford Truck and Excursion 6 02-05-2006 01:20 AM
