Duramax info ! - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by M123KT-450, this thread has received 65 replies and been viewed 5841 times.
post #1 of 66 (permalink) Old 09-24-2009, 05:50 PM Thread Starter
M123KT-450's Avatar
Duramax info !
Just woundering about this fine duramax I keep getting told to buy.
What they got for power HP n TQ ?
What's the known problems with them 2001-2009 ?
Any and all info on the first Gen through present !
Mike
1953 REO M48 w/w.
1962 GMC C45.
1969 AMC AMX -390.
1971 AMC /Jeep J4K-DRW.
1988 AMC /Jeep Comanche.
1991 Dodge RamCharger.
AMO #9860
B.O.M.B Squad #43
Dually Club #98
M123KT-450 is offline
post #2 of 66 (permalink) Old 09-25-2009, 02:31 PM Thread Starter
M123KT-450's Avatar
I see ! So you all been blowin smoke !
The duramax most NOT be better faster strong then the 6.5 !
Your not being very convincing I should trade up !
Mike
1953 REO M48 w/w.
1962 GMC C45.
1969 AMC AMX -390.
AMO #9860
B.O.M.B Squad #43
Dually Club #98
post #3 of 66 (permalink) Old 09-25-2009, 03:02 PM
Administrator
fordt's Avatar
Images: 5
The different years have different HP/TQ ratings.
The LB7's are known for injector issues, but they are covered under a 7yr. 200K mile warranty.
They should blow a 6.5 out of the water.
-Wayne
2007 Chevy LBZ 6.6L Classic
fordt is offline
The Following 2 Users Say Thank You to fordt For this addition to TDG:
M123KT-450 (09-26-2009), merlin5577 (09-26-2009)
post #4 of 66 (permalink) Old 09-25-2009, 09:41 PM Thread Starter
M123KT-450's Avatar
I know each year has different ratings i wanted to know them all. I am sure it should blow the 6.5 away, But i would just like to get some info before i buy another diesel truck thats problematic and makes me WISHED i would have just gotten the Big GASSER as the 6.5-T is making me wish i had gotten the 454 instead. . .
Educate me guy's I want to know it all troubles failures pros cons ECT i wanna know the good the bad and the ugly of the DURAMAX diesel.
Mike
Mike
1953 REO M48 w/w.
1962 GMC C45.
1969 AMC AMX -390.
AMO #9860
B.O.M.B Squad #43
Dually Club #98
post #5 of 66 (permalink) Old 09-26-2009, 02:09 AM
Pardue the Traveler
New 0mega's Avatar
Well, they incrementally increase power over the years the LB7 started with 330hp and 550Tq??(not sure on the torque)The lmm is rated at 365hp and 650tq. The LB7's have injector issues but a lot have already had them changed, they have a waste gated turbo and 5 speed Allison and optional manual trans and no egr. The LLY's have overheating issues due to a poor intake design but there is a fix for that by swapping in a LBZ intake piece, they have the Variable Geometry/Vane Turbo and 5 speed Allison and egr. The LBZ has the least amount of issues, has the six speed Allison, VV turbo, egr and has no dpf. The LMM also hasn't show a lot of issues yet, it has the 6 speed Allison, VV tubo, egr and diesel particulate filter. The LLY, LBZ and LMM have had issues of Transmission lines leaking at the cooler in cold weather due to a poor fitting design, but there is a fix for it. There is not lift pump, the CP3 draws fuel by vacuum from the tank, so when you put more power to the truck the fuel rail will starve but a fass or airdog or a lift pump fix that issue. The Allison is great stock, if you put more than 100hp over stock you start slipping clutches. But stock you shouldn't have many issues. If you put more than 700hp to the Allison you will more than likely break input and output shafts. The transfer case has an issue and I can't remember what with out looking it up, but there is a fix for that as well. if you do a four wheel launch the tie rods flex and could break, so tie rod sleeves or bigger tie rods fix that. to get more flex out of the front end and level it, upper A arms and longer shocks.
Singles Club member #250
New 0mega is offline
The Following 2 Users Say Thank You to New 0mega For this addition to TDG:
M123KT-450 (09-26-2009), Robts (10-10-2009)
post #6 of 66 (permalink) Old 09-26-2009, 02:40 AM Thread Starter
M123KT-450's Avatar
I wasn't planning on modding it up, just wanted info on a key stock unit. all sounds good so far. . .
Mike
1953 REO M48 w/w.
1962 GMC C45.
1969 AMC AMX -390.
AMO #9860
B.O.M.B Squad #43
Dually Club #98
post #7 of 66 (permalink) Old 09-26-2009, 02:43 AM
Pardue the Traveler
New 0mega's Avatar
well that's the the good, bad and ugly that I know.
The Following User Says Thank You to New 0mega For this addition to TDG:
post #8 of 66 (permalink) Old 09-26-2009, 03:40 AM Thread Starter
M123KT-450's Avatar
thanks for your addition.
Mike
1953 REO M48 w/w.
1962 GMC C45.
1969 AMC AMX -390.
AMO #9860
B.O.M.B Squad #43
Dually Club #98
The Following User Says Thank You to M123KT-450 For this addition to TDG:
New 0mega (09-26-2009)
post #9 of 66 (permalink) Old 09-26-2009, 02:18 PM
Pardue the Traveler
New 0mega's Avatar
Most guys who buy a duramax love them, but the '04.5-05 LLY is usually the one to avoid, its kind of like the red headed step child of duramax's.
post #10 of 66 (permalink) Old 09-26-2009, 08:36 PM Thread Starter
M123KT-450's Avatar
Thanks for the heads up ! I'd hate to go from one problematic diesel to another !
Mike
1953 REO M48 w/w.
1962 GMC C45.
1969 AMC AMX -390.
AMO #9860
B.O.M.B Squad #43
Dually Club #98
4.5L Duramax info Rcannon All New 4.5L Duramax 20 09-29-2009 01:46 PM
Background info on C7 Cat and 7.8 Duramax FordRacing200 Medium and Heavy Duty 18 10-17-2007 11:25 PM
need info on 2007 duramax tedAU Duramax 2006-2007(LBZ & LLY) 6 07-20-2007 03:18 AM
ok its the Duramax Now What bpul2113 Duramax 2006-2007(LBZ & LLY) 16 07-04-2007 04:14 PM
new duramax man from oz mick Introductions 15 07-17-2006 06:03 AM
