opinions on 8.1 - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by pontiacross, this thread has received 8 replies and been viewed 1093 times.
post #1 of 9 (permalink) Old 10-24-2009, 02:34 AM Thread Starter
pontiacross's Avatar
opinions on 8.1
thinking about buying another truck to use as a daily driver and to tow my pulling truck around if my other tow rig isn't available.
what kind of milage do the 8.1's get incompairason to smaller gasers in the same size truck.
also how are they power and reliability wise.
it you have any other opinions on the subject let me know.
Thanks
Ross
Tow Rig
Becker Brothers Enterprises
pontiacross is offline
post #2 of 9 (permalink) Old 10-24-2009, 03:55 AM
M123KT-450's Avatar
The 8.1 I got has been worked hard for almost 100K miles I'm talking always loaded in excess of its GVWR.
It'll out pull a 454vortec easy as pie !
It dose about 13-18mpg depending on how heavy you load it and how hard you drive it.
Truck is always pulling a tandum enclosed trailer loaded with lawn mowing gear, that weights about 12-15K-lbs hitch to the reciever all summer long in the hot heat.
All winter long in the bitter cold slush n slop its pushing an 8 foot boss V-plow.
Truck is an 02 2500HD 8.1 4spd auto 4.10 gears and 235/85R16E tires.
Hope that helps some?
they also use the 8.1 in trucks as heavy as a 6500 n 7500 so its gotta be tough.
Mike
1953 REO M48 w/w.
1962 GMC C45.
1969 AMC AMX -390.
1971 AMC /Jeep J4K-DRW.
1988 AMC /Jeep Comanche.
1991 Dodge RamCharger.
AMO #9860
B.O.M.B Squad #43
Dually Club #98
M123KT-450 is offline
The Following User Says Thank You to M123KT-450 For this addition to TDG:
pontiacross (10-24-2009)
post #3 of 9 (permalink) Old 10-24-2009, 04:00 AM Thread Starter
thanks I find that milage pretty hard to believe though. dad has a 2500 with a 6.0 in it and he cant hardly get 15 out of it
I have been looking at v-10 fords and everyone talks like they get 12 or less loaded and unloaded
but fuel milage isn't my main consern....
Ross
Tow Rig
post #4 of 9 (permalink) Old 10-24-2009, 04:20 AM
M123KT-450's Avatar
The harder the engine works the more fuel it burns. . .
your 6.0L tows running 1/2 throttle while my 8.1L towing the same load runs at 1/4 throttle i wounder who burns less fuel. . .
I swapped out a bad tired 4.3L V6 in an S-10 for a 5.0L V8 i gain almost 2.5mpg just driving around. . .
Mike
1953 REO M48 w/w.
1962 GMC C45.
1969 AMC AMX -390.
AMO #9860
B.O.M.B Squad #43
Dually Club #98
post #5 of 9 (permalink) Old 10-24-2009, 03:08 PM
Gone Fishin...
merlin5577's Avatar
The 8.1 is a good motor, and was available with the Allison trans which is quite a tough combo. Some of the earlier years had oil consumption issues do to ring clearances but other then that no issues. A friend has one in a 3/4 ton Yukon XL and averages 13mpg, and his does have the Allison. He tows a 8K lb camper with it occasionally and it handles that no problem... to the tune of 8mpg.
-Robert.
My Fleet;
1997 GMC Suburban SLT 5.7L 4A
Reading material
I am an old Fart;
Toot-Toot
merlin5577 is offline
The Following User Says Thank You to merlin5577 For this addition to TDG:
post #6 of 9 (permalink) Old 10-24-2009, 09:57 PM Thread Starter
thanks I am looking for one with a stick by the way so if anyone see one let me know
Ross
Tow Rig
post #7 of 9 (permalink) Old 10-25-2009, 12:24 AM
Formerly NATTYGASMECH
Canyon JYD's Avatar
I had a friend who's father had 3/4 ton stick 8.1. Can't remember the numbers but when he told me about the mpg I said bull to it too, but he swore they hand calculated it out.
Canyon JYD is offline
The Following 2 Users Say Thank You to Canyon JYD For this addition to TDG:
M123KT-450 (10-25-2009), pontiacross (10-25-2009)
post #8 of 9 (permalink) Old 10-25-2009, 04:41 PM
M123KT-450's Avatar
Like i said the 8.1 Came in commercial grade Gm truck's which should easily speak for its durability and power . . .
I have ran the 200 2500HD as DD for a few weeks just back n forth to the shop it got 18mpg running in tow/haul mode pulling 3 ATV's 280 miles each way it got 13mpg. . .all hand calculated then re calced by another then another to make sure it was correct. . .
Now towing 8-12k-LBs i am sure it'll drop in the single digits but it is a gas engine under a heavy load that it will slightly fast then a diesel but then yes it is less efficient. . .
Mike
1953 REO M48 w/w.
1962 GMC C45.
1969 AMC AMX -390.
AMO #9860
B.O.M.B Squad #43
Dually Club #98
pontiacross (10-26-2009)
post #9 of 9 (permalink) Old 10-26-2009, 04:16 AM
Euro Sparky/ Wrencher
french277's Avatar
Non seulement vous les trouvez dans le camion et j'ai vraiment travaillé sur industrail verison des 8.1 moteurs gaz et ils soutiennent vraiment l'abus assez bon et je sais qu'ils ont eu l'habitude d'être dans useage Marin aussi maintenant que se tiennent vraiment là-bas comme loin vous savez avec l'utilisation marine qui est très dure useage due vous fonctionnerez près du chargement complet.
Idem avec industrail verison les premiers modèles ont une certaine question avec l'huile mais autrement ils ne travaillent juste excellent sans aucun suprise.
Not only you find them in the truck and I did work on industrail verison of the 8.1 gaz engines and they really hold up the abuse pretty good and I know they used to be in Marine useage as well now that do hold up there as far you know with marine usage that is very harsh useage due you will run near full load.
Ditto with industrail verison the early models have some issue with oil but otherwise they just work fine without any suprise.
Merci,Marc
Pas de problème,il marche n'est-ce pas?"(No problem, it works doesn't it?)
french277 is offline
The Following User Says Thank You to french277 For this addition to TDG:
opinions cwood22 5.9L Cummins (2003-2007.5) 13 03-15-2008 04:44 PM
Tell me your opinions cuebird 1994-2003 7.3L Power Stroke 5 06-07-2007 04:52 AM
Need some opinions 4cstr General Ford Truck and Excursion 8 05-13-2007 05:22 AM
