2 stroke oil? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by JIMS 03 73, this thread has received 10 replies and been viewed 1983 times.
post #1 of 11 (permalink) Old 12-02-2009, 02:21 PM Thread Starter
JIMS 03 73's Avatar
2 stroke oil?
Do any of you gm guys run the 2 stroke mix? Is it needed and do you have any fuel filter issue's? My boss has an 08 duramax and has had fuel filter issues in the past while up north. Just a thought on cold weather? Sorry long winded
Charcoal Gray 2003 F-350 7.3L
SRW SC
SINGLE'S #197
RIDIN DIRTY #58
DIY INTAKE AND NO CAT
EDGE EVO. W/ POD
JIMS 03 73 is offline
post #2 of 11 (permalink) Old 12-02-2009, 03:03 PM
TDG Mafia Goon
BombDocDiesel's Avatar
I didn't have any issues with it. I didn't notice any benefits either, though.
-Josh-
My Gassers
TDG MAFIA!! MAFIA Application
American Club #38
B.O.M.B. Squad #55
Singles Club #248
Army Bomb Squad!
BombDocDiesel is offline
post #3 of 11 (permalink) Old 12-02-2009, 03:55 PM Thread Starter
JIMS 03 73's Avatar
Do you run anything to combat the "dry" fuel? I know noise wise in my 7.3l it helps. But the duramax's arent anywheres near as noisey. Do you think the gm's are fussy on the filter side of thing's? Or good right until they need to be changed. I know they need "regular" changes.
SRW SC
SINGLE'S #197
RIDIN DIRTY #58
EDGE EVO. W/ POD
post #4 of 11 (permalink) Old 12-02-2009, 04:51 PM
TDG Mafia Goon
Really you won't see that much improvement, if any, with 2-stroke in a Duramax. I run Opti-Lube XPD and I get decent but not great results, https://www.thedieselgarage.com/forum...ad.php?t=89099
2-stroke works great in my Cummins and I like a little extra lube for my 130K mile VP44.
I run 10-15K on a filter just to make myself a bit more comfy. I think the meter in the dash goes to around 17-20K, depending.
-Josh-
My Gassers
American Club #38
B.O.M.B. Squad #55
Singles Club #248
Army Bomb Squad!
post #5 of 11 (permalink) Old 12-02-2009, 06:53 PM Thread Starter
JIMS 03 73's Avatar
About every other oil change then. Which is what he does. Thanx for the info.
SRW SC
SINGLE'S #197
RIDIN DIRTY #58
EDGE EVO. W/ POD
post #6 of 11 (permalink) Old 12-02-2009, 07:17 PM
TDG Mafia Goon
You're welcome. I run a 15K Oil Change interval. Amsoil with a dual remote/bypass setup.
-Josh-
My Gassers
American Club #38
B.O.M.B. Squad #55
Singles Club #248
Army Bomb Squad!
post #7 of 11 (permalink) Old 12-02-2009, 10:42 PM
M123KT-450's Avatar
15K ! on AMSOIL ? really. . .
I'm running AMSOIL and i go 9,000miles with a fresh oil filter every 3,000 miles. . .
Mike
1953 REO M48 w/w.
1962 GMC C45.
1969 AMC AMX -390.
1971 AMC /Jeep J4K-DRW.
1988 AMC /Jeep Comanche.
1991 Dodge RamCharger.
AMO #9860
B.O.M.B Squad #43
Dually Club #98
M123KT-450 is offline
post #8 of 11 (permalink) Old 12-02-2009, 10:54 PM
TDG Mafia Goon
Mike
Mike I run 7500 send in a sample and change the full-flow filter. At 15K I change oil and both filters and send in a sample. So far so good. I may cut it back to 12K if this last sample comes back with funny numbers.
-Josh-
My Gassers
American Club #38
B.O.M.B. Squad #55
Singles Club #248
Army Bomb Squad!
post #9 of 11 (permalink) Old 12-03-2009, 05:14 PM
CRAZY CANUCK
BriteWhiteRam's Avatar
what your boss may need is a diesel fuel anti-gel agent(or anti-waxing) in cold temps diesel will wax up and wont flow at all, its best to use anti-gel if temps are even 5-10 degrees above freezing, and definately when they dip below freezing
If your boss wants to use 2-stroke oil make sure he uses the stuff intended for Snowmobiles, it will have additives that will help with anti-waxing, increases the "pour point" of the fuel
Aaron the Crazy Canuck
Canadian Club Member #1
Singles Club member #186
Ridin Dirty Club #5
TDG TOTQ
BriteWhiteRam is offline
post #10 of 11 (permalink) Old 12-03-2009, 05:20 PM Thread Starter
JIMS 03 73's Avatar
Right i agree on the oil for sleds. All the trucks at work run the same fuel and no anti gel. Just the blended fuel the fuel company delv. No problems ever. Had a couple filters plug up in the summer. Just needed to be changed earlier. No he keeps a spare in the truck. Occasionally though it gets pretty cold.
SRW SC
SINGLE'S #197
RIDIN DIRTY #58
EDGE EVO. W/ POD
2 stroke oil Taylor34 General Ford Truck and Excursion 15 03-23-2009 08:33 PM
Want to try 2 stroke but..... rhodeisland350 Bio-Diesel/ULSD/Additives Discussions 76 04-26-2008 04:20 AM
2 stroke oil use.... mpdxtreme 1994-2003 7.3L Power Stroke 33 02-26-2008 02:06 PM
2 stroke oil BriteWhiteRam 5.9L Cummins (2003-2007.5) 46 02-16-2008 10:46 PM
2 stroke oil ? 7.3stroker 5.9L Cummins (1998.5-2002) 3 01-01-2008 10:57 PM
