GM Military CUCV Gearing for my K2500 ? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by M123KT-450, this thread has received 6 replies and been viewed 2544 times.
post #1 of 7 (permalink) Old 12-08-2009, 11:00 PM Thread Starter
M123KT-450's Avatar
Ok i was looking at the CUCV's the Pickup truck's rescue squads possibly the Blazer's ?
All seem to have a 6.2L diesel, 3spd auto trans, 4.56 gears, 7.50-16 & 235/85R16 32" tires.
The surplus dealers have been swapping out the 6.2-NA/3spd auto for a 6.5-NA/4spd auto's with great success . . . say's they run 70/75mph just fine. . .
So then, I could go from 4.10's down to 4.56's in my truck and be just fine as i thought !
Just figured i would pass that along to you Ney Sayer's. . .
Mike
1953 REO M48 w/w.
1962 GMC C45.
1969 AMC AMX -390.
1971 AMC /Jeep J4K-DRW.
1988 AMC /Jeep Comanche.
1991 Dodge RamCharger.
AMO #9860
B.O.M.B Squad #43
Dually Club #98
M123KT-450 is offline
post #2 of 7 (permalink) Old 12-09-2009, 01:43 PM
depends on what your gonna do with it. for my use i prefer the 4.10 rato just about every time. part time pulling and no od, i like the 3.73 ratio. very little pulling and lot of highway[ no od], i like the 3.42. most military blazers come with the 3.08 ratio, and they do ok so long as your not pulling. i have another with a 3.73 ratio, and i really like it. if folks are going with the 4spd auto, i would stay with a 4.10 or 3.73 ratio, unless going to a taller tire. again, depends on what your doing with it.
navistar45 is offline
post #3 of 7 (permalink) Old 12-09-2009, 10:30 PM Thread Starter
M123KT-450's Avatar
towing around 12 n 15K-LB load's crawling threw the Mud muck and what not, and more then likely i'll also be turning a set of 19.5 wheels n tires for long tread life better handling lower maintenance cost Remember I Mudder's so getting 60K miles for a set of Lugger's is way better then only getting 25-35K miles like the 16's do plus the 16's cost $200-$250 a tire v.s. 19.5 MT's n MTR's at $150-$175 a tire . . .
My truck get really Doggy towing 4,500-6,000LB's which is under half what i'd like to tow with it . . .
My 6.5-T seems to be a top end puller doesn't seem to be doing much till 2,400rpm, all my power seems to be from 2,500rpm to 3,500rpm, in the stock trim it runs [email protected],500rpm n [email protected],800rpm in OD, way to conservative for my liking.
I'd like to see max speed be more like 80-85mph, 65-75mph be like 2,700-2,900Rpm which yes seems high for a diesel but you gotta remeber the 6.5 is used in marine app's different externals same internals they run 2,800-3,200rpm's sustained continuous
EDIT:
Less speed more Grunt ! i don't drive fast so there for having my truck geared for high speeds (107mph) is wasted power IMO.
Mike
1953 REO M48 w/w.
1962 GMC C45.
1969 AMC AMX -390.
AMO #9860
B.O.M.B Squad #43
Dually Club #98
post #4 of 7 (permalink) Old 12-10-2009, 01:24 PM
be quiet with those pruposed weight you haul, this thread will get turned into something else by the weight police. very reason why i seldom mention my weight's. sounds like what you want, the 4.56's will do the trick. 6.2/6.5's do there best at lowend and topend, mid range is dead. the 4.88's in my f450 are a bit too low for what i want, the 4.63's in my 3500hd are just about perfect[ if it still had the 6.5 in it]. this one has a 5.9 repower, and the 4.63's make it noisy around 60mph in od. flip to double od, and at 70mph it's perfect!
The Following User Says Thank You to navistar45 For this addition to TDG:
M123KT-450 (12-10-2009)
post #5 of 7 (permalink) Old 12-10-2009, 04:08 PM Thread Starter
M123KT-450's Avatar
Well i work Rigs there truck's and truck is spelled = W O R K ! and that's how i run them . . .
Tho some use them for fun and drag race them or Mud bog them or do sled pulling, I work mine tho from time to time i have had fun with'm the main goal is work push pull tow haul.
Mike
1953 REO M48 w/w.
1962 GMC C45.
1969 AMC AMX -390.
AMO #9860
B.O.M.B Squad #43
Dually Club #98
post #6 of 7 (permalink) Old 12-13-2009, 01:12 PM
agreed..
M123KT-450 (12-14-2009)
post #7 of 7 (permalink) Old 12-15-2009, 12:23 AM Thread Starter
M123KT-450's Avatar
I'm going to go with 4.56's and leave my truck on 16's i really wanted to go 19.5's but it's just not working as cost effectively as i would like it to. . .
So now that i know i can safely run 4.56's with the 16's then that is what i am going to do. . .
Mike
1953 REO M48 w/w.
1962 GMC C45.
1969 AMC AMX -390.
AMO #9860
B.O.M.B Squad #43
Dually Club #98
94 Chev K2500 6.5TD wheeler4x4 6.5L Diesel Engine 3 10-13-2009 04:30 PM
Parts for a 1996 GMC K2500 6.5 Diesel thejdman04 GM Parts 0 08-08-2009 03:07 PM
Tires for 2006 K2500 - What Size? Lark3po Duramax 2006-2007(LBZ & LLY) 23 10-20-2007 12:52 AM
84 cucv blazer kep184 6.2L Diesel Engine 2 09-18-2007 12:16 AM
parts for sale from 99 K2500 6.5l imported_turbojoe Whats Been Sold 0 08-27-2006 02:41 AM
