!990 Chevy front axle - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by hoofpie, this thread has received 6 replies and been viewed 1876 times.
post #1 of 7 (permalink) Old 12-24-2009, 02:03 AM Thread Starter
I have a Chevy 1990 3/4 ton. I have had alot of trouble with the axle shaft on the passenger side popping the snap ring out of the groove on the end of the axle. When this happens the front axle bangs and will not pull. Is there an up-dated axle, or a fix for this? Thanks for any help.
hoofpie is offline
post #2 of 7 (permalink) Old 02-05-2010, 03:58 AM
master of destruction
do you have a lift on the truck? Or are the torsion bars cranked?
pileofparts is offline
post #3 of 7 (permalink) Old 02-11-2010, 01:19 AM Thread Starter
No lift and I have not checked the torsion bars.
Thanks
hoofpie is offline
post #4 of 7 (permalink) Old 02-11-2010, 03:46 AM
Gone Fishin...
merlin5577's Avatar
I am pretty sure you do not have torsion bars. It should have a dana 60 with leaf springs.
-Robert.
My Fleet;
1997 GMC Suburban SLT 5.7L 4A
Reading material
I am an old Fart;
Toot-Toot
merlin5577 is offline
post #5 of 7 (permalink) Old 02-11-2010, 04:51 AM
It's deffinetly a torsion bar IFS setup. The only trucks that were straight axled after 88 (89-91) were blazers and suburbans (gm 10 bolt front axle) and crew cab one ton trucks (dana 60). If the torsion bars are cranked it can cause unusual stress on the cv shaft which I have seen cause the snap ring to want to pop off and te shaft slide out. But thats only in extreme cases where the bars are cranked ALL the way up. Do you know the history of the truck? I have also seen situations where the diff brackets are tweaked and the diff itself is moved one way or hte other causing it to be closer to one side than the other. Thats far more likely on lifted trucks though not stock.... how about pics? Maybe that would help me.
post #6 of 7 (permalink) Old 02-12-2010, 12:27 AM
Gone Fishin...
merlin5577's Avatar
I thought that was only true of 1/2 ton trucks? Werent all 3/4 & 1 ton trucks solid front axle until 1992?
-Robert.
My Fleet;
Reading material
I am an old Fart;
Toot-Toot
post #7 of 7 (permalink) Old 02-12-2010, 05:07 PM
Pardue the Traveler
New 0mega's Avatar
nope in '88 Gm went entirely with IFS
Singles Club member #250
New 0mega is offline
1982 Chevy rear axle hoofpie GM Performance Forum 3 03-25-2010 10:51 PM
Front axle farmer dave General Ford Truck and Excursion 6 12-25-2009 02:49 PM
front drive lineline will spin but wont lock into front axle Wally1tm 5.9L Cummins 12 Valve (1994-1998.5) 3 12-13-2009 07:33 PM
Axle conversion for 1/2 ton Chevy??? AllanB 4X4 Offroad Forum 5 09-05-2009 03:27 PM
03/04 front axle into a 01? 4x4 thuddddddd 1994-2003 7.3L Power Stroke 6 02-23-2008 04:55 AM
