1999 1/2 ton chevy gear size??? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by bootcamp, this thread has received 1 replies and been viewed 1047 times.
post #1 of 2 (permalink) Old 02-14-2010, 03:46 PM Thread Starter
bootcamp's Avatar
Can some body help me out with the size of the ring and pinion in a 1/2 tone chevy 4x4. Brotherinlaw needs to regear his truck (gas burner by the way) and I have finaly talk him into it. But he ask me if I could get the info for him. I dont have any clue as to what size the ring and pinion are in his truck. He is currently running either 3.42 or 3.73 but is going to 4.56. I have check all the normal sites for gears but they all require you to know what size. nothing easy any more. Also if any of the vendors here can help out will be greatly appriciated.
Thanks Paul
USMC 87-90 MOTOR-T
Build Date 01/05 05 F250 4x4 swb cc lariat
SCT XCAL3 Tune by DFuser,fluid damper,MBRP exhaust-no kitty, crossover fuel line, Coolant filter, CFM Intake elbow, Pro Comp 6" stage 2 lift and traction bars,ccv reroute, Gauges-trans,pyro,fuel,bbreg mod, B&W goose neck and companion hitch, firestone airbags, Earls anplumbing-6 hose and fittings to upgrade fuel lines,T/P stage I fuel line kit,Welded up pipe and welded egr cooler install, 4.10 yukon gears, ceramic coated manifolds install with new head gaskets and ARP's, PML trans pan, AEM brute air filter, AirDogII 165 sucking it straight off the bottom of the tank with Hellmans sump and Strictly Diesel RR kit
2010 Honda VFR1200 for when I really want to go FAST My newest collection to the armada, 2004 VW R32 and its all wheel drive
SINGLES CLUB MEMBER #259
bootcamp is offline
post #2 of 2 (permalink) Old 02-14-2010, 04:21 PM
CRAZY CANUCK
BriteWhiteRam's Avatar
could be either a 10 bolt 8.5 or 12 bold 9.5.... in the OBS 99
It looks to be an 8.6 in the NBS 99-2000
Aaron the Crazy Canuck
Canadian Club Member #1
Singles Club member #186
Ridin Dirty Club #5
TDG TOTQ
BriteWhiteRam is offline
The Following User Says Thank You to BriteWhiteRam For this addition to TDG:
bootcamp (02-14-2010)
1999 Chevy 2500 w/ Supercharged 383 Stroker Motor Gas Sucks Vehicles For Sale 0 12-16-2009 11:53 PM
930,599 Mile Engine, 1999 Chevy Van CrowsSynthetics General Gas Vehicle 25 02-01-2009 06:21 PM
Tire size, gear ratio and speedometer snoboy General Ford Truck and Excursion 3 08-07-2007 03:25 AM
what gear size should I run?? onebadf150 2003-2007 6.0L Power Stroke 4 05-21-2007 11:58 PM
Programmer tire size/gear change 320mph 2003-2007 6.0L Power Stroke 11 02-11-2006 11:51 AM
