hi/low beam all on mod - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by sexytrkr, this thread has received 4 replies and been viewed 2538 times.
post #1 of 5 (permalink) Old 03-29-2010, 07:15 PM Thread Starter
truckn'
sexytrkr's Avatar
Send a message via AIM to sexytrkr
do you guys know about this? I looked back a few pages and didnt see anything about it, if not i'll share it for sure. I could take a couple pics, but its VERY easy. took me longer to find the diods at radio shack then to do the whole mod.
you get a $.99 diode from radio shack and put it between the 85 of the low beam and 85 of the highbeam relay posts. It allows you to keep your low beams on when using your high beams.
2014 T800W 600hpISX15 18spd yanking a 2003 XL specialized 110HD with the cheater neck.
93 peterbilt 379ex hood. 3046B 18spd (in time out, broken crankshaft)
Lonestar Diesel club #9
sexytrkr is offline
post #2 of 5 (permalink) Old 03-29-2010, 09:06 PM
Gone Fishin...
merlin5577's Avatar
I've seen this mod before and its a great upgrade. I purchased the all-on kit from painless performance before I even knew it existed.
-Robert.
My Fleet;
1997 GMC Suburban SLT 5.7L 4A
Reading material
I am an old Fart;
Toot-Toot
merlin5577 is offline
post #3 of 5 (permalink) Old 04-01-2010, 04:28 PM
496 Cubic Inches
496 BB's Avatar
I just grounded out my yellow on my passenger high beam wire and got same thing. Think this is for 01-02's only though.
I got all this info in my stickies whenever I get to post em here. Im an electrical freak...lol.
You guys can make your headlights come on manually also you know. Where they wont come on automatically at dusk for you. Thats easy one too.
2001 HD 8.1L 4x4 Crew SB LT
EFI Live, K&N CAI, MSD, Plug mod (in testing), 160* T-Stat, Flomaster 40 Series SS (Duals)(No tails), Custom H-Pipe, (2) RF P2410's in custom down fire box, Rockford Old Skool 250aii amp, AirLift bags, On board compressor, Custom mount gauges, Body colored trim, 285 Revo ATV's, 16x10 Ions, 6K HID Lows & Fogs, Blue LED Dash, Blue LED Switches, Blue LED Footwell Lights, Blue LED Interior Lighting, and so much more....
Some people are like Slinkies ... not really good for anything, but you can't help smiling when you see one tumble down the stairs
Better to remain silent and be thought a fool, than to speak and remove all doubt
496 BB is offline
post #4 of 5 (permalink) Old 04-01-2010, 06:50 PM Thread Starter
truckn'
sexytrkr's Avatar
ew ew tell me tell me!!! please...its aggrivating starting my truck at night and having to immidiatly turn off the headlights.
sexytrkr is offline
post #5 of 5 (permalink) Old 04-02-2010, 12:26 AM
496 Cubic Inches
496 BB's Avatar
Ok heres the easy way. IF you have climate control then you will have 4 wires if not then two.
The little bubble on your dash is what your after. Easiest way to get to it is pull the radio out and go from behind and up. That little bubble is a PITA to get out sometimes but IIRC it just twist out gently. Once its out this is what you do:
Non auto climate models - You should have just 2 wires in there. Black and white IIRC. You can cut them and put one resistor end on white and one resistor end on black to complete the circuit.
Auto Climate models - You will have 4 wires on bubble. Cut the black and white and run your resistor same way as above.
Ok what you need to do is buy an 8.8 ohm resistor and run it from the white wire to the black wire.
Another way of doing this is from the BCM under the dash. I havent done it this way but have heard of it. Might be easier to work with. Heres how:
The white wire is landed on the BCM at J3-A4 and the black wire at J4-B7. I believe that J3 is the middle connector on the BCM and J4 is the right connector. Someone may want to verify this. I know that J2 is the left connector. So what you would do is find these plugs and locate the actual pin on the plug. Like J3 would be middle plug and A4 would be the pin within that plug. Should be a white wire. Cut that up a little bit so if you need to re splice to stock again you can. Locate other plug and pinout and DO NOT CUT the wire. It is the ground and you need it to stay that way...lol. Do peel back a little bit of the wires insulation so you can wrap the resistor end around it and solder it to it. Connect other end of resistor to white wires end and make proper connections. You may be able to just get away with soldering resistor end to white and trying to stab other end of resistor into the pinout for the black. Wont hurt to try. Test it all out and put back together.
Ok whats next? Now your gonna be asking for how to make your switches blue LEDs....lol. Trust me....that was a REAL PITA! Looks cool as **** though.
496 BB is offline
Dual or mono beam? outlawcrewcab 1994-2003 7.3L Power Stroke 1 06-07-2007 01:51 PM
Twin I Beam Swap For Solid Axel? strokedout_07 1994-2003 7.3L Power Stroke 2 03-13-2007 02:01 AM
1995 Mack No Low Beam Lights King of Obsolete Medium and Heavy Duty 12 09-09-2006 11:54 PM
Straight vs Twin I Beam BiG_stroke07 1994-2003 7.3L Power Stroke 16 06-03-2006 01:43 AM
High beam Fog light mod done today M.R.C. F-250 General Ford Truck and Excursion 9 10-19-2005 04:35 AM
