88-98 fullsize GM 1/2 ton rear disc swap - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 4cstr, this thread has received 5 replies and been viewed 15307 times.
post #1 of 6 (permalink) Old 12-19-2005, 07:19 AM Thread Starter
4cstr
1994 GMC Yukon rear disc swap
Here is all the components needed for the rear disc swap. Brackets purchased online. 1987 S-10 front brake calipers, Raybestos QS brakepads, 1988 Chevy K1500 rotors, Chevette brake hoses, brake fluid, caliper bolts, axle seals, 80W-90 gear lube, and friction modifier for the limited slip.
Here is a closeup of the bracket. Pretty straightforward. 3/8" thick steel with a zinc plating on it, and some bosses welded on for a little more meat for the calipers to mount to.
Before: Standard (or should I say substandard) C/K rear drums.
You also gotta have good help on a project like this. Thanks go out to my little brother Danny.
After the axles are pulled, and all the drum related stuff is removed, you can bolt on the brackets. I used red Loctite to make sure these buggers don't come loose.
Here are a couple of after pictures. It's pretty straightforward as far as bolting up calipers, installing hoses, and bleeding the brakes.
The stock disc/drum proportioning is pretty good for disc/disc on a Suburban/Yukon/Tahoe/Blazer application. Plus, the antilocks still work perfectly. The biggest advantage is that the 'ol Yook now stops on a dime, even with the 35's on.
post #2 of 6 (permalink) Old 09-02-2006, 01:14 AM
where do you get the brackets for the disc brake swap
ballplr is offline
post #3 of 6 (permalink) Old 09-02-2006, 01:16 AM
wher do you get the brackets for the disc brake swap? The problem I have is my brakes dont work worth a darn the truck will not stop
ballplr is offline
post #4 of 6 (permalink) Old 09-26-2007, 11:57 PM
.93 gmc rear drum to disc conversion
hello ,I am interested in thie conversion what year chevette .
polleo is offline
post #5 of 6 (permalink) Old 10-20-2007, 12:04 AM
i found my own answer thanks . KingTek Performance .ha
polleo is offline
post #6 of 6 (permalink) Old 10-20-2007, 12:05 AM
rear brake gmc KingTek Performance ha
polleo is offline
