Duramax Code - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by wideopen, this thread has received 0 replies and been viewed 3888 times.
post #1 of 1 (permalink) Old 01-05-2006, 01:10 PM Thread Starter
Registered User
Duramax Code
P0100 ** Mass or Volume Air Flow Circuit Malfunction
P0101** Mass or Volume Air Flow Circuit Range/Performance Problem
P0102** Mass or Volume Air Flow Circuit Low Input
P0103** Mass or Volume Air Flow Circuit High Input
P0104** Mass or Volume Air Flow Circuit Intermittent
P0105** Manifold Absolute Pressure/Barometric Pressure Circuit Malfunction
P0106** Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance Problem
P0107** Manifold Absolute Pressure/Barometric Pressure Circuit Low Input
P0108** Manifold Absolute Pressure/Barometric Pressure Circuit High Input
P0109** Manifold Absolute Pressure/Barometric Pressure Circuit Intermittent
P0109** Intake Air Temperature Circuit Malfunction
P0111** Intake Air Temperature Circuit Range/Performance Problem
P0112** Intake Air Temperature Circuit Low Input
P0113** Intake Air Temperature Circuit High Input
P0114** Intake Air Temperature Circuit Intermittent
P0115** Engine Coolant Temperature Circuit Malfunction
P0116** Engine Coolant Temperature Circuit Range/Performance Problem
P0117** Engine Coolant Temperature Circuit Low Input
P0118** Engine Coolant Temperature Circuit High Input
P0119** Engine Coolant Temperature Circuit Intermittent
P0120** Throttle/Petal Position Sensor/Switch A Circuit Malfunction
P0121** Throttle/Petal Position Sensor/Switch A Circuit Range/Performance Problem
P0122** Throttle/Petal Position Sensor/Switch A Circuit Low Input
P0123** Throttle/Petal Position Sensor/Switch A Circuit High Input
P0124** Throttle/Petal Position Sensor/Switch A Circuit Intermittent
P0125** Insufficient Coolant Temperature for Closed Loop Fuel Control
P0126** Insufficient Coolant Temperature for Stable Operation
P0130** O2 Sensor Circuit Malfunction (Bank 1 Sensor 1)
P0131** O2 Sensor Circuit Low Voltage (Bank 1 Sensor 1)
P0132** O2 Sensor Circuit High Voltage (Bank 1 Sensor 1)
P0133** O2 Sensor Circuit Slow Response (Bank 1 Sensor 1)
P0134** O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 1)
P0135** O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)
P0136** O2 Sensor Circuit Malfunction (Bank 1 Sensor 2)
P0137** O2 Sensor Circuit Low Voltage (Bank 1 Sensor 2)
P0138** O2 Sensor Circuit High Voltage (Bank 1 Sensor 2)
P0139** O2 Sensor Circuit Slow Response (Bank 1 Sensor 2)
P0140** O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 2)
P0141** O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 2)
P0142** O2 Sensor Circuit Malfunction (Bank 1 Sensor 3)
P0143** O2 Sensor Circuit Low Voltage (Bank 1 Sensor 3)
P0144** O2 Sensor Circuit High Voltage (Bank 1 Sensor 3)
P0145** O2 Sensor Circuit Slow Response (Bank 1 Sensor 3)
P0146** O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 3)
P0147** O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 3)
P0150** O2 Sensor Circuit Malfunction (Bank 2 Sensor 1)
P0151** O2 Sensor Circuit Low Voltage (Bank 2 Sensor 1)
P0152** O2 Sensor Circuit High Voltage (Bank 2 Sensor 1)
P0153** O2 Sensor Circuit Slow Response (Bank 2 Sensor 1)
P0154** O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 1)
P0155** O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 1)
P0156** O2 Sensor Circuit Malfunction (Bank 2 Sensor 2)
P0157** O2 Sensor Circuit Low Voltage (Bank 2 Sensor 2)
P0158** O2 Sensor Circuit High Voltage (Bank 2 Sensor 2)
P0159** O2 Sensor Circuit Slow Response (Bank 2 Sensor 2)
P0160** O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 2)
P0161** O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 2)
P0162** O2 Sensor Circuit Malfunction (Bank 2 Sensor 3)
P0163** O2 Sensor Circuit Low Voltage (Bank 2 Sensor 3)
P0164** O2 Sensor Circuit High Voltage (Bank 2 Sensor 3)
P0165** O2 Sensor Circuit Slow Response (Bank 2 Sensor 3)
P0166** O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 3)
P0167** O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 3)
P0170** Fuel Trim Malfunction (Bank 1)
P0171** System too Lean (Bank 1)
P0172** System too Rich (Bank 1)
P0173** Fuel Trim Malfunction (Bank 2)
P0174** System too Lean (Bank 2)
P0175** System too Rich (Bank 2)
P0176** Fuel Composition Sensor Circuit Malfunction
P0177** Fuel Composition Sensor Circuit Range/Performance
P0178** Fuel Composition Sensor Circuit Low Input
P0179** Fuel Composition Sensor Circuit High Input
P0180** Fuel Temperature Sensor A Circuit Malfunction
P0181** Fuel Temperature Sensor A Circuit Range/Performance
P0182** Fuel Temperature Sensor A Circuit Low Input
P0183** Fuel Temperature Sensor A Circuit High Input
P0184** Fuel Temperature Sensor A Circuit Intermittent
P0185** Fuel Temperature Sensor B Circuit Malfunction
P0186** Fuel Temperature Sensor B Circuit Range/Performance
P0187** Fuel Temperature Sensor B Circuit Low Input
P0188** Fuel Temperature Sensor B Circuit High Input
P0189** Fuel Temperature Sensor B Circuit Intermittent
P0190** Fuel Rail Pressure Sensor Circuit Malfunction
P0191** Fuel Rail Pressure Sensor Circuit Range/Performance
P0192** Fuel Rail Pressure Sensor Circuit Low Input
P0193** Fuel Rail Pressure Sensor Circuit High Input
P0194** Fuel Rail Pressure Sensor Circuit Intermittent
P0195** Engine Oil Temperature Sensor Malfunction
P0196** Engine Oil Temperature Sensor Range/Performance
P0197** Engine Oil Temperature Sensor Low
P0198** Engine Oil Temperature Sensor High
P0199** Engine Oil Temperature Sensor Intermittent
P0200** Injector Circuit Malfunction
P0201** Injector Circuit Malfunction - Cylinder 1
P0202** Injector Circuit Malfunction - Cylinder 2
P0203** Injector Circuit Malfunction - Cylinder 3
P0204** Injector Circuit Malfunction - Cylinder 4
P0205** Injector Circuit Malfunction - Cylinder 5
P0206** Injector Circuit Malfunction - Cylinder 6
P0207** Injector Circuit Malfunction - Cylinder 7
P0208** Injector Circuit Malfunction - Cylinder 8
P0209** Injector Circuit Malfunction - Cylinder 9
P0210** Injector Circuit Malfunction - Cylinder 10
P0211** Injector Circuit Malfunction - Cylinder 11
P0212** Injector Circuit Malfunction - Cylinder 12
P0213** Cold Start Injector 1 Malfunction
P0214** Cold Start Injector 2 Malfunction
P0215** Engine Shutoff Solenoid Malfunction
P0216** Injection Timing Control Circuit Malfunction
P0217** Engine Overtemp Condition
P0218** Transmission Over Temperature Condition
P0219** Engine Overspeed Condition
P0220** Throttle/Petal Position Sensor/Switch B Circuit Malfunction
P0221** Throttle/Petal Position Sensor/Switch B Circuit Range/Performance Problem
P0222** Throttle/Petal Position Sensor/Switch B Circuit Low Input
P0223** Throttle/Petal Position Sensor/Switch B Circuit High Input
P0224** Throttle/Petal Position Sensor/Switch B Circuit Intermittent
P0225** Throttle/Petal Position Sensor/Switch C Circuit Malfunction
P0226** Throttle/Petal Position Sensor/Switch C Circuit Range/Performance Problem
P0227** Throttle/Petal Position Sensor/Switch C Circuit Low Input
P0228** Throttle/Petal Position Sensor/Switch C Circuit High Input
P0229** Throttle/Petal Position Sensor/Switch C Circuit Intermittent
P0230** Fuel Pump Primary Circuit Malfunction
P0231** Fuel Pump Secondary Circuit Low
P0232** Fuel Pump Secondary Circuit High
P0233** Fuel Pump Secondary Circuit Intermittent
P0234** Engine Overboost Condition
P0235** Turbocharger Boost Sensor A Circuit Malfunction
P0236** Turbocharger Boost Sensor A Circuit Range/Performance
P0237** Turbocharger Boost Sensor A Circuit Low
P0238** Turbocharger Boost Sensor A Circuit High
P0239** Turbocharger Boost Sensor B Malfunction
P0240** Turbocharger Boost Sensor B Circuit Range/Performance
P0241** Turbocharger Boost Sensor B Circuit Low
P0242** Turbocharger Boost Sensor B Circuit High
P0243** Turbocharger Wastegate Solenoid A Malfunction
P0244** Turbocharger Wastegate Solenoid A Range/Performance
P0245** Turbocharger Wastegate Solenoid A Low
P0246** Turbocharger Wastegate Solenoid A High
P0247** Turbocharger Wastegate Solenoid B Malfunction
P0248** Turbocharger Wastegate Solenoid B Range/Performance
P0249** Turbocharger Wastegate Solenoid B Low
P0250** Turbocharger Wastegate Solenoid B High
P0251** Injection Pump Fuel Metering Control "A" Malfunction (Cam/Rotor/Injector)
P0252** Injection Pump Fuel Metering Control "A" Range/Performance (Cam/Rotor/Injector)
P0253** Injection Pump Fuel Metering Control "A" Low (Cam/Rotor/Injector)
P0254** Injection Pump Fuel Metering Control "A" High (Cam/Rotor/Injector)
P0255** Injection Pump Fuel Metering Control "A" Intermittent (Cam/Rotor/Injector)
P0256** Injection Pump Fuel Metering Control "B" Malfunction (Cam/Rotor/Injector)
P0257** Injection Pump Fuel Metering Control "B" Range/Performance (Cam/Rotor/Injector)
P0258** Injection Pump Fuel Metering Control "B" Low (Cam/Rotor/Injector)
P0259** Injection Pump Fuel Metering Control "B" High (Cam/Rotor/Injector)
P0260** Injection Pump Fuel Metering Control "B" Intermittent (Cam/Rotor/Injector)
P0261** Cylinder 1 Injector Circuit Low
P0262** Cylinder 1 Injector Circuit High
P0263** Cylinder 1 Contribution/Balance Fault
P0264** Cylinder 2 Injector Circuit Low
P0265** Cylinder 2 Injector Circuit High
P0266** Cylinder 2 Contribution/Balance Fault
P0267** Cylinder 3 Injector Circuit Low
P0268** Cylinder 3 Injector Circuit High
P0269** Cylinder 3 Contribution/Balance Fault
P0270** Cylinder 4 Injector Circuit Low
P0271** Cylinder 4 Injector Circuit High
P0272** Cylinder 4 Contribution/Balance Fault
P0273** Cylinder 5 Injector Circuit Low
P0274** Cylinder 5 Injector Circuit High
P0275** Cylinder 5 Contribution/Balance Fault
P0276** Cylinder 6 Injector Circuit Low
P0277** Cylinder 6 Injector Circuit High
P0278** Cylinder 6 Contribution/Balance Fault
P0279** Cylinder 7 Injector Circuit Low
P0280** Cylinder 7 Injector Circuit High
P0281** Cylinder 7 Contribution/Balance Fault
P0282** Cylinder 8 Injector Circuit Low
P0283** Cylinder 8 Injector Circuit High
P0284** Cylinder 8 Contribution/Balance Fault
P0285** Cylinder 9 Injector Circuit Low
P0286** Cylinder 9 Injector Circuit High
P0287** Cylinder 9 Contribution/Balance Fault
P0288** Cylinder 10 Injector Circuit Low
P0289** Cylinder 10 Injector Circuit High
P0290** Cylinder 10 Contribution/Balance Fault
P0291** Cylinder 11 Injector Circuit Low
P0292** Cylinder 11 Injector Circuit High
P0293** Cylinder 11 Contribution/Balance Fault
P0294** Cylinder 12 Injector Circuit Low
P0295** Cylinder 12 Injector Circuit High
P0296** Cylinder 12 Contribution/Range Fault
P0300** Random/Multiple Cylinder Misfire Detected
P0301** Cylinder 1 Misfire Detected
P0302** Cylinder 2 Misfire Detected
P0303** Cylinder 3 Misfire Detected
P0304** Cylinder 4 Misfire Detected
P0305** Cylinder 5 Misfire Detected
P0306** Cylinder 6 Misfire Detected
P0307** Cylinder 7 Misfire Detected
P0308** Cylinder 8 Misfire Detected
P0309** Cylinder 9 Misfire Detected
P0311** Cylinder 11 Misfire Detected
P0312** Cylinder 12 Misfire Detected
P0320** Ignition/Distributor Engine Speed Input Circuit Malfunction
P0321** Ignition/Distributor Engine Speed Input Circuit Range/Performance
P0322** Ignition/Distributor Engine Speed Input Circuit No Signal
P0323** Ignition/Distributor Engine Speed Input Circuit Intermittent
P0325** Knock Sensor 1 Circuit Malfunction (Bank 1 or Single Sensor)
P0326** Knock Sensor 1 Circuit Range/Performance (Bank 1 or Single Sensor)
P0327** Knock Sensor 1 Circuit Low Input (Bank 1 or Single Sensor)
P0328** Knock Sensor 1 Circuit High Input (Bank 1 or Single Sensor)
P0329** Knock Sensor 1 Circuit Intermittent (Bank 1 or Single Sensor)
P0330** Knock Sensor 2 Circuit Malfunction (Bank 2)
P0331** Knock Sensor 2 Circuit Range/Performance (Bank 2)
P0332** Knock Sensor 2 Circuit Low Input (Bank 2)
P0333** Knock Sensor 2 Circuit High Input (Bank 2)
P0334** Knock Sensor 2 Circuit Intermittent (Bank 2)
P0335** Crankshaft Position Sensor A Circuit Malfunction
P0336** Crankshaft Position Sensor A Circuit Range/Performance
P0337** Crankshaft Position Sensor A Circuit Low Input
P0338** Crankshaft Position Sensor A Circuit High Input
P0339** Crankshaft Position Sensor A Circuit Intermittent
P0340** Camshaft Position Sensor Circuit Malfunction
P0341** Camshaft Position Sensor Circuit Range/Performance
P0342** Camshaft Position Sensor Circuit Low Input
P0343** Camshaft Position Sensor Circuit High Input
P0344* Camshaft Position Sensor Circuit Intermittent
P0350** Ignition Coil Primary/Secondary Circuit Malfunction
P0351** Ignition Coil A Primary/Secondary Circuit Malfunction
P0352** Ignition Coil B Primary/Secondary Circuit Malfunction
P0353** Ignition Coil C Primary/Secondary Circuit Malfunction
P0354** Ignition Coil D Primary/Secondary Circuit Malfunction
P0355** Ignition Coil E Primary/Secondary Circuit Malfunction
P0356** Ignition Coil F Primary/Secondary Circuit Malfunction
P0357** Ignition Coil G Primary/Secondary Circuit Malfunction
P0358** Ignition Coil H Primary/Secondary Circuit Malfunction
P0359** Ignition Coil I Primary/Secondary Circuit Malfunction
P0360** Ignition Coil J Primary/Secondary Circuit Malfunction
P0361** Ignition Coil K Primary/Secondary Circuit Malfunction
P0362** Ignition Coil L Primary/Secondary Circuit Malfunction
P0370** Timing Reference High Resolution Signal A Malfunction
P0371** Timing Reference High Resolution Signal A Too Many Pulses
P0372** Timing Reference High Resolution Signal A Too Few Pulses
P0373** Timing Reference High Resolution Signal A Intermittent/Erratic Pulses
P0374** Timing Reference High Resolution Signal A No Pulses
P0375** Timing Reference High Resolution Signal B Malfunction
P0376** Timing Reference High Resolution Signal B Too Many Pulses
P0377** Timing Reference High Resolution Signal B Too Few Pulses
P0378** Timing Reference High Resolution Signal B Intermittent/Erratic Pulses
P0379** Timing Reference High Resolution Signal B No Pulses
P0380** Glow Plug/Heater Circuit "A" Malfunction
P0381** Glow Plug/Heater Indicator Circuit Malfunction
P0382** Exhaust Gas Recirculation Flow Malfunction
P0385** Crankshaft Position Sensor B Circuit Malfunction
P0386** Crankshaft Position Sensor B Circuit Range/Performance
P0387** Crankshaft Position Sensor B Circuit Low Input
P0388** Crankshaft Position Sensor B Circuit High Input
P0389** Crankshaft Position Sensor B Circuit Intermittent
P0400** Exhaust Gas Recirculation Flow Malfunction
P0401** Exhaust Gas Recirculation Flow Insufficient Detected
P0402** Exhaust Gas Recirculation Flow Excessive Detected
P0403** Exhaust Gas Recirculation Circuit Malfunction
P0404** Exhaust Gas Recirculation Circuit Range/Performance
P0405** Exhaust Gas Recirculation Sensor A Circuit Low
P0406** Exhaust Gas Recirculation Sensor A Circuit High
P0407** Exhaust Gas Recirculation Sensor B Circuit Low
P0408** Exhaust Gas Recirculation Sensor B Circuit High
P0410** Secondary Air Injection System Malfunction
P0411** Secondary Air Injection System Incorrect Flow Detected
P0412** Secondary Air Injection System Switching Valve A Circuit Malfunction
P0413** Secondary Air Injection System Switching Valve A Circuit Open
P0414** Secondary Air Injection System Switching Valve A Circuit Shorted
P0415** Secondary Air Injection System Switching Valve B Circuit Malfunction
P0416** Secondary Air Injection System Switching Valve B Circuit Open
P0417** Secondary Air Injection System Switching Valve B Circuit Shorted
P0418** Secondary Air Injection System Relay "A" Circuit Malfunction
P0419** Secondary Air Injection System Relay "B" Circuit Malfunction
P0420** Catalyst System Efficiency Below Threshold (Bank 1)
P0421** Warm Up Catalyst Efficiency Below Threshold (Bank 1)
P0422** Main Catalyst Efficiency Below Threshold (Bank 1)
P0423** Heated Catalyst Efficiency Below Threshold (Bank 1)
P0424** Heated Catalyst Temperature Below Threshold (Bank 1)
P0430** Catalyst System Efficiency Below Threshold (Bank 2)
P0431** Warm Up Catalyst Efficiency Below Threshold (Bank 2)
P0432** Main Catalyst Efficiency Below Threshold (Bank 2)
P0433** Heated Catalyst Efficiency Below Threshold (Bank 2)
P0434** Heated Catalyst Temperature Below Threshold (Bank 2)
P0440** Evaporative Emission Control System Malfunction
P0441** Evaporative Emission Control System Incorrect Purge Flow
P0442** Evaporative Emission Control System Leak Detected (small leak)
P0443** Evaporative Emission Control System Purge Control Valve Circuit Malfunction
P0444** Evaporative Emission Control System Purge Control Valve Circuit Open
P0445** Evaporative Emission Control System Purge Control Valve Circuit Shorted
P0446** Evaporative Emission Control System Vent Control Circuit Malfunction
P0447** Evaporative Emission Control System Vent Control Circuit Open
P0448** Evaporative Emission Control System Vent Control Circuit Shorted
P0449** Evaporative Emission Control System Vent Valve/Solenoid Circuit Malfunction
P0450** Evaporative Emission Control System Pressure Sensor Malfunction
P0451** Evaporative Emission Control System Pressure Sensor Range/Performance
P0452** Evaporative Emission Control System Pressure Sensor Low Input
P0453** Evaporative Emission Control System Pressure Sensor High Input
P0454** Evaporative Emission Control System Pressure Sensor Intermittent
P0455** Evaporative Emission Control System Leak Detected (gross leak)
P0460** Fuel Level Sensor Circuit Malfunction
P0461** Fuel Level Sensor Circuit Range/Performance
P0462** Fuel Level Sensor Circuit Low Input
P0463** Fuel Level Sensor Circuit High Input
P0464** Fuel Level Sensor Circuit Intermittent
P0465** Purge Flow Sensor Circuit Malfunction
P0466** Purge Flow Sensor Circuit Range/Performance
P0467** Purge Flow Sensor Circuit Low Input
P0468** Purge Flow Sensor Circuit High Input
P0469** Purge Flow Sensor Circuit Intermittent
P0470** Exhaust Pressure Sensor Malfunction
P0471** Exhaust Pressure Sensor Range/Performance
P0472** Exhaust Pressure Sensor Low
P0473** Exhaust Pressure Sensor High
P0474** Exhaust Pressure Sensor Intermittent
P0475** Exhaust Pressure Control Valve Malfunction
P0476** Exhaust Pressure Control Valve Range/Performance
P0477** Exhaust Pressure Control Valve Low
P0478** Exhaust Pressure Control Valve High
P0479** Exhaust Pressure Control Valve Intermittent
P0480** Cooling Fan 1 Control Circuit Malfunction
P0481** Cooling Fan 2 Control Circuit Malfunction
P0482** Cooling Fan 3 Control Circuit Malfunction
P0483** Cooling Fan Rationality Check Malfunction
P0484** Cooling Fan Circuit Over Current
P0485** Cooling Fan Power/Ground Circuit Malfunction
P0500** Vehicle Speed Sensor Malfunction
P0501** Vehicle Speed Sensor Range/Performance
P0502** Vehicle Speed Sensor Low Input
P0503** Vehicle Speed Sensor Intermittent/Erratic/High
P0505** Idle Control System Malfunction
P0506** Idle Control System RPM Lower Than Expected
P0507** Idle Control System RPM Higher Than Expected
P0510** Closed Throttle Position Switch Malfunction
P0520** Engine Oil Pressure Sensor/Switch Circuit Malfunction
P0521** Engine Oil Pressure Sensor/Switch Circuit Range/Performance
P0522** Engine Oil Pressure Sensor/Switch Circuit Low Voltage
P0523** Engine Oil Pressure Sensor/Switch Circuit High Voltage
P0530** A/C Refrigerant Pressure Sensor Circuit Malfunction
P0531** A/C Refrigerant Pressure Sensor Circuit Range/Performance
P0532** A/C Refrigerant Pressure Sensor Circuit Low Input
P0533** A/C Refrigerant Pressure Sensor Circuit High Input
P0534* Air Conditioner Refrigerant Charge Loss
P0550** Power Steering Pressure Sensor Circuit Malfunction
P0551** Power Steering Pressure Sensor Circuit Range/Performance
P0552** Power Steering Pressure Sensor Circuit Low Input
P0553** Power Steering Pressure Sensor Circuit High Input
P0554** Power Steering Pressure Sensor Circuit Intermittent
P0560** System Voltage Malfunction
P0561** System Voltage Unstable
P0562** System Voltage Low
P0563** System Voltage High
P0565** Cruise Control On Signal Malfunction
P0566** Cruise Control Off Signal Malfunction
P0567** Cruise Control Resume Signal Malfunction
P0568** Cruise Control Set Signal Malfunction
P0569** Cruise Control Coast Signal Malfunction
P0570** Cruise Control Accel Signal Malfunction
P0571** Cruise Control/Brake Switch A Circuit Malfunction
P0572** Cruise Control/Brake Switch A Circuit Low
P0573** Cruise Control/Brake Switch A Circuit High
P0574** Cruise Control Related Malfunction
P0575** Cruise Control Related Malfunction
P0576** Cruise Control Related Malfunction
P0578** Cruise Control Related Malfunction
P0579** Cruise Control Related Malfunction
P0580** Cruise Control Related Malfunction
P0600** Serial Communication Link Malfunction
P0601** Internal Control Module Memory Check Sum Error
P0602** Control Module Programming Error
P0603** Internal Control Module Keep Alive Memory (KAM) Error
P0604** Internal Control Module Random Access Memory (RAM) Error
P0605** Internal Control Module Read Only Memory (ROM) Error
P0606** PCM Processor Fault
P0608** Control Module VSS Output "A" Malfunction
P0609** Control Module VSS Output "B" Malfunction
P0620** Generator Control Circuit Malfunction
P0621** Generator Lamp "L" Control Circuit Malfunction
P0622** Generator Field "F" Control Circuit Malfunction
P0650** Malfunction Indicator Lamp (MIL) Control Circuit Malfunction
P0654** Engine RPM Output Circuit Malfunction
P0655** Engine Hot Lamp Output Control Circuit Malfucntion
P0656** Fuel Level Output Circuit Malfunction
P0700** Transmission Control System Malfunction
P0701** Transmission Control System Range/Performance
P0702** Transmission Control System Electrical
P0703** Torque Converter/Brake Switch B Circuit Malfunction
P0704** Clutch Switch Input Circuit Malfunction
P0705** Transmission Range Sensor Circuit malfunction (PRNDL Input)
P0706** Transmission Range Sensor Circuit Range/Performance
P0707** Transmission Range Sensor Circuit Low Input
P0708* Transmission Range Sensor Circuit High Input
P0709* Transmission Range Sensor Circuit Intermittent
P0710** Transmission Fluid Temperature Sensor Circuit Malfunction
P0711** Transmission Fluid Temperature Sensor Circuit Range/Performance
P0712** Transmission Fluid Temperature Sensor Circuit Low Input
P0713** Transmission Fluid Temperature Sensor Circuit High Input
P0714** Transmission Fluid Temperature Sensor Circuit Intermittent
P0715** Input/Turbine Speed Sensor Circuit Malfunction
P0716** Input/Turbine Speed Sensor Circuit Range/Performance
P0717** Input/Turbine Speed Sensor Circuit No Signal
P0718** Input/Turbine Speed Sensor Circuit Intermittent
P0719** Torque Converter/Brake Switch B Circuit Low
P0720** Output Speed Sensor Circuit Malfunction
P0721** Output Speed Sensor Range/Performance
P0722** Output Speed Sensor No Signal
P0723** Output Speed Sensor Intermittent
P0724** Torque Converter/Brake Switch B Circuit High
P0725** Engine Speed input Circuit Malfunction
P0726** Engine Speed Input Circuit Range/Performance
P0727** Engine Speed Input Circuit No Signal
P0728** Engine Speed Input Circuit Intermittent
P0730** Incorrect Gear Ratio
P0731** Gear 1 Incorrect ratio
P0732** Gear 2 Incorrect ratio
P0733** Gear 3 Incorrect ratio
P0734** Gear 4 Incorrect ratio
P0735** Gear 5 Incorrect ratio
P0736** Reverse incorrect gear ratio
P0740** Torque Converter Clutch Circuit Malfuction
P0741** Torque Converter Clutch Circuit Performance or Stuck Off
P0742** Torque Converter Clutch Circuit Stuck On
P0743** Torque Converter Clutch Circuit Electrical
P0744** Torque Converter Clutch Circuit Intermittent
P0745** Pressure Control Solenoid Malfunction
P0746** Pressure Control Solenoid Performance or Stuck Off
P0747** Pressure Control Solenoid Stuck On
P0748** Pressure Control Solenoid Electrical
P0749** Pressure Control Solenoid Intermittent
P0750** Shift Solenoid A Malfunction
P0751** Shift Solenoid A Performance or Stuck Off
P0752** Shift Solenoid A Stuck On
P0753** Shift Solenoid A Electrical
P0754** Shift Solenoid A Intermittent
P0755** Shift Solenoid B Malfunction
P0756** Shift Solenoid B Performance or Stuck Off
P0757** Shift Solenoid B Stuck On
P0758** Shift Solenoid B Electrical
P0759** Shift Solenoid B Intermittent
P0760** Shift Solenoid C Malfunction
P0761** Shift Solenoid C Performance or Stuck Off
P0762** Shift Solenoid C Stuck On
P0763** Shift Solenoid C Electrical
P0764** Shift Solenoid C Intermittent
P0765** Shift Solenoid D Malfunction
P0766** Shift Solenoid D Performance or Stuck Off
P0767** Shift Solenoid D Stuck On
P0768** Shift Solenoid D Electrical
P0769** Shift Solenoid D Intermittent
P0770** Shift Solenoid E Malfunction
P0771** Shift Solenoid E Performance or Stuck Off
P0772** Shift Solenoid E Stuck On
P0773** Shift Solenoid E Electrical
P0774** Shift Solenoid E Intermittent
P0780** Shift Malfunction
P0781** 1-2 Shift Malfunction
P0782** 2-3 Shift Malfunction
P0783** 3-4 Shift Malfunction
P0784** 4-5 Shift Malfunction
P0785** Shift/Timing Solenoid Malfunction
P0786** Shift/Timing Solenoid Range/Performance
P0787** Shift/Timing Solenoid Low
P0788** Shift/Timing Solenoid High
P0789** Shift/Timing Solenoid Intermittent
P0790** Normal/Performance Switch Circuit Malfunction
P0801** Reverse Inhibit Control Circuit Malfunction
P0803** 1-4 Upshift (Skip Shift) Solenoid Control Circuit Malfunction
P0804** 1-4 Upshift (Skip Shift) Lamp Control Circuit Malfunction
wideopen is offline
