GM All on Headlight Mod...anodder one..?? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Steakman, this thread has received 4 replies and been viewed 6012 times.
post #1 of 5 (permalink) Old 07-29-2009, 04:27 AM Thread Starter
.....and then there is the all on headlight mod.
Fogs
Fogs and lows
Fogs, lows and High's
for those that wish to do so...you need to make a very small little harness and solder it to a cpl of the relay's in your main Fuse box under the hood. This diagram is for the GMC/Chev 2500HD's...but I am sure it is applicable to most GM trucks and many GM products....and very likely the same logic could be used for Fords/Dodge products as well...just need to find out which relays operate which lamps and do the same thing. I would think that those that manufacfture automative relays may well do so for all three of the Detroit automakers.
I too find std headlamps to be dim (mind you, now they are HID's)..but still, I find to have the fogs on at same time as the Lows makes a huge difference to my aged eyes.
Anyway, one needs to use 2 diodes (Radio Shack PN's 1N4001 or 1N4004), in this schematic with both diodes having the cathode end which is the silver tipped end of the diode pointing towards the HiBeam relay on pin 85. So from Pin 85 on the fogs and pin 85on the lows...both gotto pin 85 on the highs. It should also be quite possible to have your Drl's included in this as well by adding a diode to its relay as well.
Then try it out...push in your fog light...on it comes, turn on your lows...on they come....then flick your hi beams and instead of the fogs and lows shutting off, they all stay on.! "Kewl" you say..!! if they do not stay on, then it is likely you have your diodes in the wrong way.
And the Lord said let there be Light, and Moses the head electrician flicked the switch and by Jesus, you could see for frickin miles..!!
Note: This is not something I invented..I'm just putting all the info into one post so that it makes it easy for those of you that do intend to do so, not have to run all over hells creation to find the info. Nods to UNIT453 for this info.
stk
Name:	All on Headlight mod.jpg
Steakman is offline
The Following 2 Users Say Thank You to Steakman For this addition to TDG:
fordt (07-29-2009), merlin5577 (07-29-2009)
post #2 of 5 (permalink) Old 07-29-2009, 06:07 AM
Gone Fishin...
merlin5577's Avatar
I have this mod on my 97' and my 03' and am glad I did them. It really is like night and day.
-Robert.
My Fleet;
1997 GMC Suburban SLT 5.7L 4A
Reading material
I am an old Fart;
Toot-Toot
merlin5577 is offline
post #3 of 5 (permalink) Old 07-29-2009, 10:51 AM
is here and there.
Rcannon's Avatar
Images: 11
I really need to learn how to wire stuff like this. Nice write up.
Rcannon is offline
post #4 of 5 (permalink) Old 07-29-2009, 11:18 AM
Administrator
fordt's Avatar
Images: 5
I am going to pick up the diode tonight, just one, because I don't have the fog lights in my ranchhand.
I will try and snap some pics.
Thanks Steakman!
-Wayne
2007 Chevy LBZ 6.6L Classic
fordt is offline
post #5 of 5 (permalink) Old 07-29-2009, 06:39 PM
Gone Fishin...
merlin5577's Avatar
Russ, if your not into wiring, Painless performance makes a kit to do it yourself. Its really easy to install.
-Robert.
My Fleet;
Reading material
I am an old Fart;
Toot-Toot
The Following User Says Thank You to merlin5577 For this addition to TDG:
Rcannon (07-30-2009)
Headlight Help !!! imported_Tommeyboy The Parking Lot 3 03-04-2008 04:19 AM
HID headlight kit Strokin05 Whats Been Sold 6 03-01-2008 06:17 AM
06 ram right headlight goldenfox Whats Been Sold 0 01-13-2008 05:07 PM
headlight imported_newtodiesel 2003-2007 6.0L Power Stroke 5 12-13-2007 12:42 AM
New Headlight look SAK General Ford Truck and Excursion 0 02-01-2006 08:37 PM
