Search "
" across the entire site
Search "
" in this forum
Advanced Search
Cancel
Login / Join
What's New
Forum Listing
Showcase
Gallery
Advanced Search
Members
FAQ
Dark Mode
Menu
Log in
Register
Home
Forums
Dodge Diesel & Truck Discussion
5.9L Cummins (Pre 1994)
Follow Forum
Start Discussion
JavaScript is disabled. For a better experience, please enable JavaScript in your browser before proceeding.
Filters
Show:
Loading…
1
2
3
Go to page
Go
16
Next
1 of 16
Go to page
Go
Last
Sticky
Part number/tech info galore for your 12v
countryboy88
Dec 23, 2008
10
13K
Dec 23, 2008
by
countryboy88
G
Hp estimate....
gon2sea
Mar 26, 2019
0
834
Mar 26, 2019
by
gon2sea
S
Ve pump out of time help please
smokeone
Mar 13, 2016
0
2K
Mar 13, 2016
by
smokeone
J
6bt burning oil after replacing bad turbo
jaybob
Mar 12, 2016
0
1K
Mar 12, 2016
by
jaybob
G
DIAPHRAGM SPRING COLOR CODE...?
gon2sea
Dec 7, 2015
4
1K
Dec 19, 2015
by
Philip
transmission troubles/swap
01_24valve
Aug 11, 2015
2
1K
Nov 13, 2015
by
Philip
G
SMOKE AT LOW RPM
gon2sea
Nov 11, 2015
1
1K
Nov 13, 2015
by
Philip
G
VE pump fuel screw
gon2sea
Dec 25, 2014
0
2K
Dec 25, 2014
by
gon2sea
C
Timing question
City Guy
Sep 19, 2014
6
2K
Dec 24, 2014
by
City Guy
H
air filter change
hotrodharley
Jul 20, 2014
1
1K
Jul 21, 2014
by
Johnp3
AT shifts late after rebuild-mileage sux
Flyingpig
Mar 25, 2014
4
2K
Jun 22, 2014
by
Flyingpig
G
fuel leak on VE pump
gon2sea
Apr 17, 2014
1
2K
Apr 20, 2014
by
Philip
R
Steering shaft removal
Rob
Jan 29, 2014
0
1K
Jan 29, 2014
by
Rob
Auto to 5sp
CR Toney
Jan 26, 2014
1
1K
Jan 26, 2014
by
Johnp3
S
need advise on my 93 12valve
slickricks7.3
Mar 15, 2011
2
3K
Dec 6, 2013
by
simplysmn
C
Interior Parts
candersen1
Oct 17, 2011
1
2K
Dec 6, 2013
by
simplysmn
G
dana 60 front brakes single to dually
gon2sea
Jan 24, 2012
2
3K
Dec 6, 2013
by
simplysmn
Getrag G360 Overfill
BlowinSmoke
Nov 23, 2013
4
4K
Nov 30, 2013
by
BlowinSmoke
G
VE pump " star wheel" adjustment
gon2sea
Sep 5, 2011
7
21K
Sep 21, 2013
by
gon2sea
Loose Steering Gearbox
BlowinSmoke
Jul 13, 2013
15
4K
Jul 23, 2013
by
Johnp3
M
Injection pump bolts
MattW
Apr 5, 2013
1
2K
Jul 4, 2013
by
bmoeller
L
1989 Dodge D250 5.9L 6 cyl diesel turbo charged
llewis
Apr 28, 2013
3
4K
Jun 15, 2013
by
junkmandan
T
Axle swap
tommu
Mar 7, 2013
1
1K
Mar 8, 2013
by
Backslap
T
D250 brakes
tommu
Jan 28, 2013
9
9K
Mar 3, 2013
by
Backslap
T
1992 BAD noise
tommu
Mar 2, 2013
1
1K
Mar 2, 2013
by
tommu
Cold weather blues
BlowinSmoke
Jan 23, 2013
0
1K
Jan 23, 2013
by
BlowinSmoke
1
Is this truck a good deal for a young man?
1955 Chevy 6400
Oct 9, 2012
1
2K
Oct 20, 2012
by
later
G
transmission fluid temp sensor
gon2sea
Jan 24, 2012
2
3K
May 13, 2012
by
oldbeek
Where should I send my injections pump?
Lonesome7.3
May 29, 2011
2
3
4
62
7K
May 7, 2012
by
smbenefiel
Water leaking through door
BlowinSmoke
Dec 13, 2011
3
2K
Apr 10, 2012
by
dartman366
N
1993 D250
Nolafishr
Jan 8, 2012
1
2K
Apr 9, 2012
by
Tjunk
Tranny cooling on an 89 6BT powered Dodge ????????
Lonesome7.3
Mar 18, 2012
6
2K
Apr 3, 2012
by
Lonesome7.3
Bench seat swap
cumminsdiesel
Sep 25, 2010
2
2K
Feb 22, 2012
by
bmoeller
D
Vss and speedo wiring
De5id
Jan 30, 2012
0
1K
Jan 30, 2012
by
De5id
If you need help with a problem, look here first...
BigRed Cummins
Jan 4, 2009
2
2K
Jan 8, 2012
by
Nolafishr
D
Block heater
dartman366
Nov 1, 2011
4
2K
Nov 16, 2011
by
dartman366
1
2
3
Go to page
Go
16
Next
1 of 16
Go to page
Go
Last
Join the discussion
Continue with Facebook
Continue with Google
or
sign up with email
Discussions Regarding 1st Generation Dodge Trucks
4.1K
posts
1.2M
views
Join Community
Forum Staff
View All
nevrenufhp
Super Moderator
Administrator
Administrator
Join now to ask and comment!
or
sign up with email
Home
Forums
