LinkBack | Thread Tools | Display Modes |
Why would an automotive plug wire not work on an ATV coil?
The ATC 110 I have been working on had an Accel 8MM plug wire on it. Some one at some point in time cut the ends off and used it on this trike. It “appears” as though it was done correctly. However, I did nto get any spark. I thought the coil was bad. I just recently got another 110 that did have spark. I took just the plug wire off of that one and replaced the 8MM wire. Now, I have spark. Other than the wire being damaged, are there any other reasons a standard automotive plug wire would not work? A few people told me that plug wire would not do the job. Why?
Sponsored Links | |||
Originally Posted by Lonesome7.3
View Post
http://www.motorcycleproject.com/mot...gwiretech.html
It's about resistance and likely you have too much of it between the wire and spark plug right now.
Wes
Early 2004 F-250 4x4 CC 6.0
Thanks, that is a good link.
Thread Tools | |
Display Modes | |
Similar Threads | ||||
Thread | Thread Starter | Forum | Replies | Last Post |
wire diagram for trailers all plug types(sticky mods) | jestersv | Towing and Hauling | 1 | 02-01-2011 11:07 PM |
Glow plug relay doesn't work sometimes | RLU_tech | 1994-2003 7.3L Power Stroke | 12 | 01-17-2011 08:33 PM |
Steering Wheel Inflatable Restraint Module Coil Replacement (Coil) | ripmf666 | GM Spec Info | 0 | 12-28-2008 01:40 PM |
problem checking glow plug with 5 pin plug | Firefighter E2 | 1994-2003 7.3L Power Stroke | 1 | 11-25-2007 07:18 PM |
glow plug wire location help! | 03f3507.3 | 1994-2003 7.3L Power Stroke | 3 | 11-16-2007 03:54 AM |
Posting Rules | |
