More starting problems with my Pro-Hauler - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Lonesome7.3, this thread has received 7 replies and been viewed 2635 times.
post #1 of 8 (permalink) Old 04-25-2013, 02:05 PM Thread Starter
A while back I had some issues with my 1989 Yamaha Pro-hauler not starting. After some work I found out is had a torn intake. After that it ran fine. I stuck it in the shed and left it alone for a few weeks. When I went out to use it was hard to start again. I sprayed a quick squirt of starting fluid and it started up and ran great. It worked all day with no issues. I would even shut it down for up to an hour and it would start again as soon as I touched the button. I have zero complaints about how it ran that day. The very next day I went out to use it and it would not start for anything. It ran on choke for a few moments but that was it. Since then I have tried a few times to start it with no luck. I do not want to use starting fluid anymore because I should not have to. I think something is out of adjustment in the carb. Any ideas as to what that would be? Maybe the needle needs to be re-positioned, maybe the float it off. If it is the float any ideas how I can find out where it is suppose to be positioned? What about the choke? Is there something with that I should look at?
Here are the specs on my Pro-Hauler:
http://www.yamahamotorsports.com/out...ler_small.aspx
post #2 of 8 (permalink) Old 04-26-2013, 02:43 AM
Weld engineer's Avatar
I'd guess the float and needle are stuck. My little Honda generator had this happen. I'm convinced today's gas goes to crap in a couple of months. I've never used Stabil in the past but both my generators (one for house backup and one for RV) start hard and never used to if I ran them every few months so I use it now.
Early 2004 F-250 4x4 CC 6.0
Weld engineer is offline
post #3 of 8 (permalink) Old 04-26-2013, 02:45 AM Thread Starter
I guess I should drain the gas as well then.
post #4 of 8 (permalink) Old 04-26-2013, 02:49 AM
Had to drain the tank on the 8000w generator as the gas didn't even smell like gas anymore and it would not run. I also try to fill stored engines with winter gas because summer gas here seems to be even worse with special magic dust to reduce emissions.
post #5 of 8 (permalink) Old 04-26-2013, 02:52 AM Thread Starter
You all have summer and winter gas?
post #6 of 8 (permalink) Old 04-26-2013, 02:59 AM
Yup. And of course the switch causes prices to jump every Spring as refineries switch over. It's less volatile so it doesn't evaporate as fast.
http://ask.cars.com/2009/02/whats-th...y-cars-pe.html
post #7 of 8 (permalink) Old 04-26-2013, 03:01 AM
We have winter diesel, winter gas and winter underwear up here.
post #8 of 8 (permalink) Old 04-26-2013, 03:09 AM Thread Starter
I learn more and more about northern states every time I long on.
Starting Problems. bigbird389 2003-2007 6.0L Power Stroke 11 09-29-2011 06:23 PM
Starting problems bpogue 1994-2003 7.3L Power Stroke 11 06-04-2011 04:11 AM
starting problems jameyd 5.9L Cummins (1998.5-2002) 3 09-14-2007 06:11 PM
pro comp lift problems detailman General Ford Truck and Excursion 7 02-17-2007 06:43 PM
'95 7.3 starting problems... dieseldummy 1994-2003 7.3L Power Stroke 23 02-02-2007 02:41 AM
