Fuel despensing tank? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Detroit Diesel, this thread has received 4 replies and been viewed 1636 times.
post #1 of 5 (permalink) Old 12-22-2013, 12:19 AM Thread Starter
Detroit Diesel's Avatar
I am looking for a different way of being efficient with gasoline.
Chainsaws & ATV's are about the only things we have burning gasoline, everything else burns Diesel fuel!
The ATV's normally get a little low on the gauge, and the tank will hold a 2 gallon can of fuel. Then commonly refill the can with fuel out of a 5 gallon can. I would Like to buy or make a tank which would hold 10-15 gallons of Gas, with a small ~1/4 inch valve at the bottom which could be opened to refill the smaller tank. This would make dealing with the limited amount of gasoline simpler. Planning to be able to refill the tank with 5 gallon gas jugs.
Would Need about a foot to 18 inches under the tank to fit the 2 gal jug under.
Any Help or recommendations GREATLY Appreciated!!
Diesel
"Let Freedom Ring, and Turbos Sing!"
'07 Cummins, 2500, 4x4
-Prior-
'05 Cummins, 3500, 4x4, Larime, Dash pod, Perfomance Exhaust, Smarty,
May She Rest In Peace!
University of Missouri Shooting Team, Ranked 2nd in the Nation in 2009
Detroit Diesel is offline
post #2 of 5 (permalink) Old 12-22-2013, 12:46 AM
Weld engineer's Avatar
1- anhueser-Busch keg - 1/2 barrell equals 15 gallons 3 of them will make a heck of a party. Should be some of those in Missouri.
Stainless fittings for a top 1 inch or bigger and 1/4 or 1/2 for bottom from McMaster-Carr
Find someone local to TIG weld them in I have welded up kegs for a guy making home brew he posted it on craigslist. If you were in MI. I'd do it.
Make some legs and your done.
Stainless fuel tank you could even pick up a vented cap from farm store for a transfer tank.
Early 2004 F-250 4x4 CC 6.0
Weld engineer is offline
The Following User Says Thank You to Weld engineer For this addition to TDG:
Detroit Diesel (01-17-2014)
post #3 of 5 (permalink) Old 01-31-2014, 09:25 PM Thread Starter
Can't find One??
I was wondering if you could suggest a place to locate one?
I have been trying to find one then I could have fittings welded into the keg for filling with fuel & also for dispensing into smaller containers.
Thanks,
Diesel
-Prior-
post #4 of 5 (permalink) Old 01-31-2014, 11:39 PM
Aimless Wanderer
I have a horizontal six barrel rack in the shop. Two for oils, one for 50/50 coolant, one for off road diesel, one for gasoline, and one for distilled water, (plastic barrel). I welded bungs into the sides of the steel barrels from McMaster: http://www.mcmaster.com/#1698t14/=qhvkww and these face up when the barrels are horizontal in the racks. A spigot mounts into the bung on the top, (front when horizontal) and there is enough room to fill a five gallon can from any of them. With the exception of the water, all the fuels and oils are bulk filled off the fuel truck when I need.
The question I seek an answer for is simply; why, or why not?
Backslap is offline
The Following User Says Thank You to Backslap For this addition to TDG:
Weld engineer (02-01-2014)
post #5 of 5 (permalink) Old 02-01-2014, 12:53 AM
Thanks,
Diesel
eBay
Call your local ab, miller, coors distributor they will sell banged up ones
Party store that sells keg beer
Scrap yard if they don't have them they will tell you where to find them
9 am Sunday morning near any college frat house
Or buy a full keg and turn it into a weekend project.
Goodluck.
Tags
dispensing, fuel
1 1/4 tank fuel hillbilli General GM Truck Forum 7 05-16-2011 06:47 PM
94 stroker .engine oil getting in fuel and back in to fuel tank powerstroking 1994-2003 7.3L Power Stroke 11 02-14-2011 04:11 AM
NO Fuel Guage READING for FRONT TANK of Dual Tank '94 F250 Ed50free 1994-2003 7.3L Power Stroke 5 03-08-2010 07:25 PM
Fuel tank ?'s One Fast Harley 2003-2007 6.0L Power Stroke 18 09-23-2007 08:10 PM
Fuel tank selector and rear fuel tank MUPPETHUNTER 1994-2003 7.3L Power Stroke 0 06-02-2007 07:24 PM
