cr125 problems - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by SSpeeDEMONSS, this thread has received 6 replies and been viewed 1141 times.
post #1 of 7 (permalink) Old 01-13-2009, 08:26 PM Thread Starter
SSpeeDEMONSS's Avatar
cr125 problems
ok, its not my bike. a guy from work wanted me to take a look at it so here i am. it seems as tho its running out of fuel in the bowl but not. it runs good(i think its a '01?), has a good powerband. not used to the little 2stroke powerband as i ride a built 426f but it runs good. then, after a little while you will be going and it will seem to bog down like its running out of gas. so let off for a little and its fine. which makes me think it could be emptying the bowl(stuck bowl, clogged line, etc) but then sometimes ill get on it, it'll pull hard then bog down and if i stay on the throttle a sec or 2 later it will hit hard like its already wound up. doesnt make sense. then i rode it more and it seemed to want to bog more and more as i rode it. mind you, i cant ride it for too long as the cops will probably show up. does anybody have any idea of what i may be?
BRING BACK THE OLD TDG!
SSpeeDEMONSS is offline
post #2 of 7 (permalink) Old 01-13-2009, 08:30 PM
KEE KEE WHOO!
sotexy's Avatar
Send a message via AIM to sotexy
TDG LUSH ELITE #1
TDG Singles Member #148
TDG Outlaw #29
TDG AMERICAN #3
TDG B.O.M.B Squad #3
TDG Ridin Dirty #13
"Lose the zero, get with a Hero!"
"PUT SOME SOUTH IN YOUR MOUTH!!"
sotexy is offline
post #3 of 7 (permalink) Old 01-16-2009, 12:33 AM
RussK's Avatar
I had my ATV do that. If you have not changed any thing (adjustments) in the carb, then I would take it apart and clean it out real good. Usually junk / dirt gets in there, clean the air filter and changes the sparkplug, check fuel line for full flow. Trash gets in side the tank as well. Post and let me know what happens
ALSO make sure the vent tube for the tank isnít clogged (it happens)
2001/05ish f250 Lariat 4x4 automatic, airaid intake, custom paint, 4 tan bucketsí covered in dead cow skin, wood dash & trim,gauges,elc trans cooler,Custom door sill lights (light up ground when door opens) Lots and lots of sound deadening other than that pretty much stock
Mercedes e320 (wifeís)
Nissan Maxima (work driver)
Dodge Magnum (work driver)
Trx 250r (off road adrenalin pump)
FORD 3600 diesel tractor
Singles club #164
american club # 9
I want to die while asleep like my grandfather,
not screaming in terror like the passengers in his car.
Russell
my truck from the begining
http://s391.photobucket.com/albums/o...um/my%20truck/
RussK is offline
post #4 of 7 (permalink) Old 01-19-2009, 02:48 PM Thread Starter
yeah, the carb and all was supposed to have been cleaned by a shop. i just told him i dont want to touch it. he should take it back to the shop and make them fix it since they were told that it "runs great" yet it doesnt.
post #5 of 7 (permalink) Old 01-19-2009, 04:40 PM
DieselKid's Avatar
Send a message via AIM to DieselKid
Could be a TON of things. Sounds like dirt in the carb and sometimes its getting sucked up through the main jet. Also could be the float hieght being too low and sucking air into the main jet. Or it could be ignition related. I would pull the float bowl off and make sure no dirt is in there and then pull out the pilot and main jet and blow it out with brake clean.
08 Mitsu Evo X - SOLD
2003 F-250 6.0L - SOLD
2000 F-250 7.3L - SOLD
Engineering Co-op at Navistar(International)
DieselKid is offline
post #6 of 7 (permalink) Old 01-19-2009, 04:43 PM Thread Starter
yeah, thats what it sounds like. but then it doesnt act like that. i was going to check the bowl to make sure it was adjusted properly then make sure it wasnt sticking but it doesnt seem like that when you ride it. it will bog down like its out of fuel then within a sec or so it will hit hard like you turned a switch on. petcock and feed line seems to be flowing just fine. im not a large 2 stroke guy so its going to the shop.
post #7 of 7 (permalink) Old 02-13-2009, 05:32 PM
Fro_911's Avatar
Check your reeds... my money says one is cracked.
"The more you sweat in peace, the less you bleed in war."
Early '99 F350 4x4 CC SWB
'05 3500 4x4 CC LWB Dually
Fro_911 is offline
I got problems bigbear3 1994-2003 7.3L Power Stroke 6 03-27-2008 01:15 PM
99 Problems bigbear3 1994-2003 7.3L Power Stroke 3 11-03-2007 04:04 AM
problems with 04 mxchase 2003-2007 6.0L Power Stroke 8 08-16-2007 05:46 AM
Electrical problems/dash problems curtis2003 5.9L Cummins (2003-2007.5) 1 10-21-2006 08:27 AM
Problems? ACC inc. Duramax 2004.5-2005(LLY) 5 03-20-2006 02:19 AM
