125 wont start - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by sexytrkr, this thread has received 5 replies and been viewed 1071 times.
post #1 of 6 (permalink) Old 03-17-2009, 04:25 PM Thread Starter
truckn'
sexytrkr's Avatar
Send a message via AIM to sexytrkr
125 wont start
ok, bikes been running good. went to ride, got halfway down the driveway and it died. I forgot to turn the fuel valve on, so i turned it on, and now i cant get it to start. I put the bike on its side and fuel pours out the fuel tube out the bottom. bike still wont start. has spark, i took the carb off and cleaned it. still nothing. any ideas? Im still kinda new to 2 strokes. Thanks
2014 T800W 600hpISX15 18spd yanking a 2003 XL specialized 110HD with the cheater neck.
93 peterbilt 379ex hood. 3046B 18spd (in time out, broken crankshaft)
Lonestar Diesel club #9
sexytrkr is offline
post #2 of 6 (permalink) Old 03-18-2009, 02:47 AM
RussK's Avatar
Pull plug and see if is it wet or dry?
2001/05ish f250 Lariat 4x4 automatic, airaid intake, custom paint, 4 tan buckets’ covered in dead cow skin, wood dash & trim,gauges,elc trans cooler,Custom door sill lights (light up ground when door opens) Lots and lots of sound deadening other than that pretty much stock
Mercedes e320 (wife’s)
Nissan Maxima (work driver)
Dodge Magnum (work driver)
Trx 250r (off road adrenalin pump)
FORD 3600 diesel tractor
Singles club #164
american club # 9
I want to die while asleep like my grandfather,
not screaming in terror like the passengers in his car.
Russell
my truck from the begining
http://s391.photobucket.com/albums/o...um/my%20truck/
RussK is offline
post #3 of 6 (permalink) Old 03-18-2009, 03:11 AM Thread Starter
truckn'
sexytrkr's Avatar
it was wet. I orded a new float kit for it....im thinking thats the problem? if thats not the problem then it will have a new float and everything anyways i guess.
sexytrkr is offline
post #4 of 6 (permalink) Old 03-25-2009, 12:02 PM Thread Starter
truckn'
sexytrkr's Avatar
Went out today after the bike had been sitting about a week, kicked it a few times and it stutered so i kept kicking it....finally fired and laid down about a 2ft by 4ft glaze of oil on the ground from the exhaust, ran it about half throttle and once it cleared up it was business as usuall.
sexytrkr is offline
post #5 of 6 (permalink) Old 04-03-2009, 03:30 AM
Tow Mater
what ratio are you mixing your fuel? i mix 45-50:1... if problem occurs again maybe a fouled plug
*TOW MATER* 2010 F-350 crew cab long box single wheel, go recon running lights and a few other little things, more to come...
Singles member #208
BOMB Squad member #35
Buckshot341 is offline
post #6 of 6 (permalink) Old 04-03-2009, 03:18 PM Thread Starter
truckn'
sexytrkr's Avatar
TBO i dont remember what im running. I think one quart to 5 gallons...its been awhile since ive mixed it, i dont ride much..But ive ridin it since i got it started and she runs good. Maybe she was having a bad day.
sexytrkr is offline
wont start? ericandkayti 7.3L and 6.9 IDI (Pre 1994) 9 02-28-2009 12:45 AM
wont start at all chevotaSS 6.5L Diesel Engine 37 02-29-2008 10:06 PM
Wont start??? ccoxva 5.9L Cummins (Pre 1994) 1 02-25-2008 02:45 PM
wont start doob51 5.9L Cummins 12 Valve (1994-1998.5) 3 05-06-2007 01:05 PM
