won't idle klr 650 "07" - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by dodgefarmer2, this thread has received 7 replies and been viewed 3279 times.
post #1 of 8 (permalink) Old 07-16-2009, 02:15 AM Thread Starter
dodgefarmer2's Avatar
anybody know how to adjust the carburator on a kawasaki klr 650 "07"?
08 dodge 3500 dually, quad cab, inferno red,6.7, 4x4, 6sp auto, rhino lined bed, b&w gooseneck turnover ball,full length fiberglass running boards (color matching),reese hitch.
MEMBER THE DUALLY CLUB #75
MEMBER THE AMERICAN CLUB #41
10,055,000.00 points approximately
dodgefarmer2 is offline
post #2 of 8 (permalink) Old 07-16-2009, 05:07 PM
motoxracer42's Avatar
post a picture of your carb and ill tell you lol. should be a screw on the side with a spring under it. you would tighten the screw to bring the idle up. i would do it while its running. you might have to rev the bike once or twice after you move the screw.
06 orange powerstroke crew cab.
check it out at ridinhighmotorsports.com
motoxracer42 is offline
post #3 of 8 (permalink) Old 07-16-2009, 08:11 PM
7.3rambaler's Avatar
adjust the..idle speed? fuel mixture?
2000 F-250 7.3L. Ext Cab. Short Box.
Dp Tuner 80 eco-tune
Fully Built Tranny with Triple Disk Converter
AFE stage 2, 4in from turbo back stright pipe, foil Delete, X-Wheel Gauges-tranny-pryo-boost
7.3rambaler is offline
post #4 of 8 (permalink) Old 07-17-2009, 01:41 AM Thread Starter
probably the mixture, if you keep jacking the throttle it will run, let off the throttle pull the clutch it will die, i have the equipment to get a picture, but i don't know how to get it on the computer yet. illiteracy sucks
i seen the idle screw with the spring, there is a allen head screw at the bottom of the carb,would that be the mix, rich or lean?
post #5 of 8 (permalink) Old 07-17-2009, 03:51 AM
dont mess with the bottom screw if it was already set. that will change your idle but usually if you havent changed anything you shouldnt have to mess with that. just change the idle on the screw with the spring.
The Following User Says Thank You to motoxracer42 For this addition to TDG:
dodgefarmer2 (07-17-2009)
post #6 of 8 (permalink) Old 07-17-2009, 03:13 PM
the bottom screw on the outside of the carb is prob a drain, if its brass. you usally have to take the carb apart to get into messing with the fuel mixture(jets and all).
but like he said turn your idle up but not to high, just so it will stay running and sound ok.
The Following User Says Thank You to 7.3rambaler For this addition to TDG:
dodgefarmer2 (07-18-2009)
post #7 of 8 (permalink) Old 07-19-2009, 11:02 AM Thread Starter
the idle screw must have vibrated way out, screwed it in a bunch, solved the problem, i would have bet on a mixture issue, but it wasn't, thanks again guys.
post #8 of 8 (permalink) Old 07-24-2009, 02:31 PM
Send a message via AIM to powerstroke 6.0
a good start would be to pull the carb and pull the individual jets out and clean them , it sounds like ure piliot circut is cloged , does the bike run better when its on choke ?
powerstroke 6.0 is offline
2001 F250 Crossover Steering & Adjustable Track Bar w/ 10" high (8" lift+2" shackles) kcrowe 1994-2003 7.3L Power Stroke 0 07-02-2009 06:37 PM
The "New Diesel Emissions" prevent the use of a "Jacobs" (jake brake) HARLEY6LF250SDU General Diesel 4 01-17-2009 02:53 PM
TO joe "csipsd" and Chelsea "cdiesel" moose99psd The Parking Lot 29 04-28-2007 03:57 AM
Safe to "fast idle" in 5deg. weather? fastback4 2003-2007 6.0L Power Stroke 20 03-02-2007 12:17 AM
NBA Headlines Ford: A new No. 1 contender<img src="http://espn.go.com/i/in.gif" width="11" height="11" hspace=4 border="0" alt="Insider"> RSS Feeder The Parking Lot 0 06-09-2006 07:00 AM
