2 stroke fouling plugs? - Page 2 - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by supr87gt, this thread has received 13 replies and been viewed 4105 times.
post #11 of 14 (permalink) Old 04-02-2010, 03:54 AM
RussK's Avatar
Originally Posted by Kiddyextreme View Post
60:1 for the mix is perfect. I'm not sure how you are riding the bike, but any 2-stroke is not meant to be ridden at low rpm for a length of time.
It will run fine at 60/1 but you will wear the rod bearing and crank bearings quickly. 32/1 runs just as good and will give you longer crank life.
On fowling your plug, check filter and carb jetting.
2001/05ish f250 Lariat 4x4 automatic, airaid intake, custom paint, 4 tan buckets’ covered in dead cow skin, wood dash & trim,gauges,elc trans cooler,Custom door sill lights (light up ground when door opens) Lots and lots of sound deadening other than that pretty much stock
Mercedes e320 (wife’s)
Nissan Maxima (work driver)
Dodge Magnum (work driver)
Trx 250r (off road adrenalin pump)
FORD 3600 diesel tractor
Singles club #164
american club # 9
I want to die while asleep like my grandfather,
not screaming in terror like the passengers in his car.
Russell
my truck from the begining
http://s391.photobucket.com/albums/o...um/my%20truck/
RussK is offline
post #12 of 14 (permalink) Old 11-24-2012, 03:58 PM
4ck1's Avatar
the one thing not mentioned here is the exhause may be blocked. it dont take much...but as they said clean filter and exhaust system...change fuel with GOOD quality 2 stroke oil and RUN IT LIKE YA STOLE IT...wide open...clean it out !
4ck1 is offline
post #13 of 14 (permalink) Old 11-24-2012, 04:01 PM
4ck1's Avatar
also the older 2 strokes...in the 70s did foul plugs all the time
4ck1 is offline
post #14 of 14 (permalink) Old 11-24-2012, 07:19 PM
Fire App. Mech.
I have a CR500 I trail rode all the time until I broke a case on it. It never once fouled a plug. I think I opened it wide open once in its entire life. Most of the time it was very low RPM putzing like a 4 stroke. I also ran 32:1 oil in it.
Because of this I discount the idea that the oil mixture has anything to do with it. I say there are two reasons it could be fouling. One is that the plug is not hot enough to burn off the oil. If you are into a slower style of riding then a hotter plug will sometimes be required. The down side is that at higher power output for longer periods of time, detonation (pinging) may occur and damage the engine if it is allowed to continue for a long time.
The other cause of fouling could be a rich gas/air ratio which might also cause poor running. If the engine had been set up right before, then I would not be thinking it is a mixture problem yet.
Birken Vogt is offline
freeze plugs robfrass 5.9L Cummins (2003-2007.5) 13 01-15-2008 05:58 AM
plugs SSpeeDEMONSS The Parking Lot 0 12-15-2007 10:24 PM
Glo-plugs LB7, LLY, and LBZ TonyBurkhard Whats Been Sold 0 10-28-2007 12:21 AM
Turbo Vane Fouling ralphinnj 2003-2007 6.0L Power Stroke 11 07-11-2007 12:57 PM
Glow Plugs Dan 85 6.9 7.3L and 6.9 IDI (Pre 1994) 0 04-11-2007 06:16 PM
