trucks that can run used motor oil - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by gvr4578, this thread has received 4 replies and been viewed 7060 times.
post #1 of 5 (permalink) Old 04-08-2012, 10:55 PM Thread Starter
hi
does anyone have a list of trucks that can run used motor oil mixed with diesel?
is it any car with mechanical injectors?
currently have 94 chevy and 03 2500 duramax.
thanks
Matt
gvr4578 is offline
post #2 of 5 (permalink) Old 04-09-2012, 01:38 PM
Combat Trucker
hillbilli's Avatar
Most older IDI diesels can handle it and 12v cummins. As long as you filter your oil good prior and theres no water in it you should be fine. I contemplated doing it on my 96 6.5 but never got around to doing it. How strong of a mixture are you thinking of running?
07 Ram 2500 5.9 Megacab
96 k2500 Extcab 6.5TD vin F NV4500 3.73 245k miles
07 Hemi Durango
03 Ram 2500 (Gone but not forgotten)
hillbilli is offline
post #3 of 5 (permalink) Old 04-09-2012, 05:38 PM Thread Starter
So it sounds like midway through 98 Dodge are capable of using this, then they switched to 24V.
IDI seems to be up to 94 for Ford.
Does anyone know what the latest engine type for Chevy was?
what is the limiting factor/s that makes them not capable of doing this now?
I would ideally like to be able to run 80% as i have heard multiple have done this before.
gvr4578 is offline
post #4 of 5 (permalink) Old 04-09-2012, 06:30 PM
Combat Trucker
hillbilli's Avatar
80% oil or diesel? Any 6.5 chevy should be able to run. Mid 90's up 6.5's have an electronic sensor in the IP. If the fuel gets to dark it can mess with the sensor, its kinda like an electronic eye. Thats why i never tried in my 6.5. Ive heard of people doing it in 24v, but the 12v will run on just about anything. Most people dont run WEO or WVO in their newer diesels because of the cost of injectors. They run on much higher fuel psi and any contamination will be a costly repair.
A lot of people also run 2 stroke oil mixed with their fuel, but at usually 120-128 to one mixtures. 30oz or so per tank.
07 Hemi Durango
post #5 of 5 (permalink) Old 04-09-2012, 08:39 PM
I worked at a logging camp in the early 70s they bought a fancy machine for adding the motor oil back into the fuel tank. They did not use any oil from the filters, just from the oil pan, these were 12 cylinder Detroit's of Cummins, it pumped the oil threw a 750D luberfiner filter for an hour to filter it and get rid of the acid build up. Then it transfered fuel to the mix and ran that mix threw a different 750D filter to scrub it, that was done for anouther hour. Then it was put back into the fuel tank. The mix was continually heated, and it was done on units that just came off the road.
There would be 25 gallons of oil from the Cummins, and 16 for the Detroit's, the fuel tanks held about 500 gallons. They stopped this before a month was done because of seized injectors these were top stop Cummins and the old N65 in the Detroit's with a popping preasure of less than 450 lbs.
Every single unit that had the oil put into the fuel needed at least one full set of injectors. They ended up having to drain and flush the fuel tanks on every unit and all that fuel 20 trucks x 500 gallons that is a lot of fuel they had to pay to be sent back to the refinery to be disposed of. That is a lot of trucks shut down, and lost production.
I made a fortune changing injectors.
You are draining the oil that is full of acids, fine metals, and carbon and then someone is going to tell you it is good to run in the fuel system. Phone any injection shop and ask them if they will warranty their products if you do this, oil filters are filtering at best 30 microns. How many filters would be needed to clean this. ask and injection dealer to what filtration you need to go to?
It is like adding lapping compound to you oil, because it will polish the crankshaft.
Johnp3 is offline
Tags
used motor oil list
2012 1/2 Ford Trucks coming with CAT Motor broth 2011+ 6.7L Power Stroke Diesel 15 03-29-2011 04:45 PM
would this fit any of our trucks??? drgriff General Ford Truck and Excursion 1 07-08-2010 07:28 PM
running used motor oil in diesel trucks?? kyle94 7.3L and 6.9 IDI (Pre 1994) 6 04-25-2010 05:01 PM
Looking at trucks crazycracker 2008-2010 6.4L Power Stroke 2 02-08-2008 11:28 PM
08' trucks? Rich 6.7L Cummins (2007.5-2011) 9 11-19-2007 12:55 AM
