2 Cycle Oil - Fuel Additive - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Mopar1973Man, this thread has received 0 replies and been viewed 5773 times.
post #1 of 1 (permalink) Old 01-02-2009, 06:55 PM Thread Starter
2nd Gen Guru
Mopar1973Man's Avatar
First and foremost... 2 Cycle Oil theory was designed for the older diesel engines in mind. The older engines deisgned for HSD and LSD.
WARNING!!!
DO NOT USE 2 CYCLE OIL IN 2007 NEWER VEHICLE ENGINE DAMAGE COULD RESULT!
As far as 2 cycle oil usage and information I've got a awful lot to even think about posting as a sticky so the best I can do is post link to the information and allow you guys (and gals) to read up and post question about such...
General 2 Cycle Oil Information
http://mopar.mopar1973man.com/tips/c...-cycle-oil.htm
Dose Information
Typical usage of 2 cycle is 128:1 ratio. But some 3rd Gen Cummins tend to like a light does at 200:1 Ratio. As for Fords and Chevy's the both can use the 128:1 without much problem
HFRR Testing of fuel additives (By DieselPlace.Com)
Orignal test results document
http://www.dieselplace.com/forum/att...9&d=1188575783
Bosch Fuel Tesing
http://mopar.mopar1973man.com/pdf/022003bosch.pdf
Noise Testing
http://mopar.mopar1973man.com/tips/c...oise/noise.htm
MSDS Sheets of common products
Failure Facts
Some of the common reason that 2 cycle oil might not perform as you expected.
  • Under/Over Dose of 2 cycle oil
  • Not measuring proper amount of oil to fuel.
  • Mixing With Other Additives
    • Cetane Boosters
    • Injection Cleaners
    • Anti-Gels (Pour Point Depressants)
  • Overhead Computer Vs. Hand Calculation
  • Weather Changes
    • Temperatures
    • Winds (Headwind or Tailwinds)
  • Road Conditions
    • Rain Flooded, Snow packed / Slushy
  • Speedometer/Odometer Errors
  • Changes In Fuel Quality
    • Winter Fuels (High Cetane >45)
    • Summer Fuels (Low Cetane <45)
  • Changes In Operation Of The Vehicle
    • Drivers
    • Speed
    • Load weight and towing weight changes
    • In town or highway operation
Mopar1973Man is offline
The Following 3 Users Say Thank You to Mopar1973Man For this addition to TDG:
huntem (01-17-2012), merlin5577 (08-16-2009), plainredtruck (01-02-2009)
Closed Thread
Gear Lube Additive brendonv General Ford Truck and Excursion 24 03-29-2009 07:16 AM
The 2 Cycle Oil Thread... Mopar1973Man Bio-Diesel/ULSD/Additives Discussions 30 01-28-2009 02:52 AM
LLY Fuel Injection Fuel Rail Assembly Replacement - Bank 1 ripmf666 GM Spec Info 0 12-28-2008 11:38 AM
LLY: Fuel Injection Fuel Rail Assembly Replacement - Bank 2 ripmf666 GM Spec Info 0 12-28-2008 11:37 AM
LLY: Fuel Injection Fuel Rail Assembly Replacement - Bank 1 ripmf666 GM Spec Info 0 12-28-2008 11:24 AM
