Home Brewers. - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Stacked6600, this thread has received 7 replies and been viewed 747 times.
post #1 of 8 (permalink) Old 08-10-2006, 01:12 PM Thread Starter
SRW Cartell #27
Stacked6600's Avatar
Home Brewers.
I just started recieving WVO from a new company and i noticed it is really dark. My first batch with the new oil turned out ok but even the B-100 was really dark. I have washed it twice and it has gotten lighter but still i am not happy with it. I was woundering if i did my calculations wrong and added to much lye would that darken the finished product? if so i think that is my problem .. PH levels are ok 7.9 but seems dark. Also i am using about a 23% methinal mix i dont think that would make a difference but if anyone has any information on why so dark please let me know.
Thanks
:shrug:
1999.5 F250 4x4 super cab 7.3L With edge attituede.
Converter lockup mod and EBPV exaust brake mod.
Air Hog cold air intake. Muffler delete, 35s on centerlines.
New F650 dash upgrade..
1995 F250 Single cab long bed 2wd.
2001 LB7 2500HD SOLD
AEM Brute Force intake, 5 1/2 stack exaust, Diablo Sport Predator Programmer. PPE boost valve, Autolite gauges. Built Allison (Alto steels, Red eagle clutches, Transgo shift kit, transgo lockup valve, and Personal Mods : ) edelbrock 1792 lift pump.
Singles Club Member #27
Stacked6600 is offline
post #2 of 8 (permalink) Old 08-10-2006, 11:38 PM
TDG Mafia Member #21
The color of the finished product is directly related to the wvo. If it was dark to begin with it is probably just fine. Dark and clear is good, dark and cloudy is bad. If you are still concerned, try to process a small batch starting with finished product and see if you settle out any more glycerin.
2007 F350 CC 4x4, EGR delete, stock for now
Old truck :"01" Dodge 3500 DRW. Goerend Bros w/ triple disk, Edge Drag Comp, Jammer Stage 5's, Turnbuckle, Dakota Digital and ISSPRO Gauges, BHAF,4" FLO-PRO exhaust, Vulcan kit, Holley Blue Pump, TC Lockup Switch, Snow stage 2, a few more little bits in the works
377hp and 823tq @ Smokin' (with stage 3's/no drag upgrade)
"400" club wannabe
akapparos is offline
post #3 of 8 (permalink) Old 08-10-2006, 11:42 PM
Do you have any pics of your process?
NMU98 is offline
post #4 of 8 (permalink) Old 08-11-2006, 11:49 AM Thread Starter
SRW Cartell #27
No i sure dont have any pics yet but i did make a small batch last night and it is clear just dark.. I washed it a few more times and it is lighter in color. The oil i normally work with is cleaner and uses less lye. I had a lot of glycerin out of this batch. I was worried that i mis-calculated my numbers so i tried again and it came out the same. I think it will be fine.. Thanks for the help.
post #5 of 8 (permalink) Old 08-14-2006, 03:41 PM Thread Starter
SRW Cartell #27
Thumbs up
I finally got the recipe correct. It took me a few because of the darkness of the oil .. h That really threw me off. I have never made any batches from oil that dark before.. It is darker than coke but a few washes and it is looking great. Thanks for the help .:Thumbup:
post #6 of 8 (permalink) Old 08-14-2006, 05:46 PM
What did you end up changing?
"400" club wannabe
post #7 of 8 (permalink) Old 08-14-2006, 06:18 PM Thread Starter
SRW Cartell #27
I had to add more lye. Since the oil was used so bad it took a little more than my origional calculation. the PH levels were off and it was so dark i couldnt tell if the glycerin fully setteled. It took the Glycerin a long time to settel at the bottem .. For 10 gal it takes it about 5--6 hrs to settel but the first batch i let it set for almost 10 before it would seperate and it wasent much. Also i noticed i have to mix the oil longer since it is darker..
post #8 of 8 (permalink) Old 08-14-2006, 06:26 PM
glad you got it right.:Thumbup:
"400" club wannabe
