New products from AMSOIL for LSF. - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Don Stefanik, this thread has received 4 replies and been viewed 640 times.
post #1 of 5 (permalink) Old 11-02-2006, 11:50 AM Thread Starter
For those concern about lubricity problems with the new low suphur fuels, AMSOIL has updated their product ADC.
Product Description
AMSOIL Diesel Concentrate (ADF) provides maximum diesel operating efficiency. It compensates for the variances in quality of different fuels (including biodiesel) and the deficiencies of today’s Ultra Low Sulfur Diesel fuel (ULSD) for better engine operation. New engine technology, tighter tolerances and emission regulations require high-quality diesel fuel for long-term engine operability. AMSOIL Diesel Concentrate meets the low sulfur mandate. It improves diesel fuel quality to exceed today’s stringent performance requirements. AMSOIL Diesel Concentrate extends equipment life, lowers operating costs and improves diesel performance.
Improves Fuel Economy and Restores Horsepower
As diesel engines are used, they become less efficient over time. Fuel injector deposits interrupt spray patterns, causing poor fuel atomization, incomplete combustion, excessive emissions and smoke. Tests prove that AMSOIL Diesel Concentrate cleans dirty injectors, improving fuel economy by up to five percent and restoring horsepower to like new. Acceleration is improved and with regular use, AMSOIL Diesel Concentrate continues to enhance performance by keeping injectors clean. The net savings on fuel expense can result in no additional cost to vehicle operation.
Lubricates Fuel Pump and Injectors
Ultra low sulfur diesel fuel has significantly reduced lubricity – a critical property in controlling wear in fuel pumps and injectors. AMSOIL Diesel Concentrate adds back all the lubricity properties needed and more. Fuel pump and injector service life is extended, saving time and money on maintenance costs.
Reduces Cylinder Wear, Retains Engine Oil TBN Longer
With high rates of exhaust gas recirculation (EGR) in modern diesel engines, acids from combustion are of particular concern. AMSOIL Diesel Concentrate neutralizes acids during combustion. It helps reduce acid caused cylinder wear and helps extend engine oil TBN, maintaining engine oil quality longer for better protection.
Minimizes Soot Loading
AMSOIL Diesel Concentrate is a powerful cleaner that cleans fuel injectors and piston rings for improved combustion and better sealing. It minimizes soot generated from incomplete combustion and helps keep soot out of the crankcase. Reduced soot loading controls soot related wear and engine oil viscosity increase.
Fuel Stabilizer
Fuel degradation can cause gums, which increase deposits and the chance of filter plugging. AMSOIL Diesel Concentrate significantly improves the oxidation and thermal stability of diesel fuel. It overcompensates for ultra low sulfur diesel fuel’s potential stability loss caused by extra processing and sulfur removal. Diesel fuel treated with AMSOIL Diesel Concentrate easily meets the requirements of the National Council of Weights and Measures (NCWM) Premium Diesel Fuel Specification for resisting diesel fuel degradation.
Improves Water Tolerance
AMSOIL Diesel Concentrate is an alcohol-free product that protects fuel systems against water contamination. It helps prevent fuel/water emulsions and it protects metal against rust. Water can be drained easier and fuel filters are less likely to plug, ensuring drivability.
Heating Oil Improver
AMSOIL Diesel Concentrate provides many of the same benefits in heating oil furnace applications. It provides fuel oil storage stability, water stability, rust protection, fuel oil filter longevity, and in certain applications, can keep fuel oil nozzles clean for proper spray in the combustion chamber. AMSOIL Diesel Concentrate promotes trouble-free operation. AMSOIL Cold Flow Improver is recommended where fuel oil is stored outside.
Recommendations
AMSOIL Diesel Concentrate is recommended for use with all types of heavy- and light-duty, on- or off-road and marine diesel engines. Recommended mix ratio is one oz. of additive per five gallons of fuel. Use with every new tank of fuel for the best performance and protection against fuel pump wear, injector wear and injector deposits. Compatible with all types of exhaust emission systems such as diesel particulate filters (DPFs). Add Diesel Concentrate to fuel before storage. Excellent for use with AMSOIL Cetane Boost and AMSOIL Cold Flow Improver. This diesel fuel additive complies with the federal low sulfur content requirements for use in diesel motor vehicles and non-road engines.
Don Stefanik is offline
post #2 of 5 (permalink) Old 11-08-2006, 10:18 PM
So what's the verdict, anybody try this yet?
I run Amsoil products in my ATV's and love them.
What about running them in my 7.3???
Copenhagen250r is offline
post #3 of 5 (permalink) Old 11-09-2006, 01:37 AM
#454
Motown Fire's Avatar
If you have an easy source of biodiesel, use it. It's the best lucbricator for our motors.
2011 Dodge 3500 DRW CTD CrewCab 4X4 G56
2012 PJ 40' Dual Tandem Flat Bed
Motown Fire is offline
post #4 of 5 (permalink) Old 11-11-2006, 12:22 AM
You mean you *aren't* running them in your 7.3 yet? The whole truck should be filled with Amsoil, bumper to bumper!
hippie is offline
post #5 of 5 (permalink) Old 11-14-2006, 09:03 PM
I'm fairly new to the diesel scene.
I've run amsoil in virtually everything I've owned from weed wackers to atv's to vehicles and love their products.
What do I need from Amsoil?
I hear alot about the filter bypass kit....any info would be greatly appreciated!!
They offer several products for the diesel, who runs what for what application?
What would you recommend?
