DIY veggie oil conversion? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 91redstang, this thread has received 9 replies and been viewed 2551 times.
post #1 of 10 (permalink) Old 01-30-2007, 09:31 PM Thread Starter
I am going to try and run my truck on used veggie oil and was wondering if anyone had some resources or infomation on a DIY kit that i could put together? A list of parts, diagrams, anything would be a great help. thanks Jim
91redstang is offline
post #2 of 10 (permalink) Old 01-30-2007, 10:33 PM
I be Architect'n
http://biodiesel.infopop.cc/6/ubb.x?a=cfrm&s=447609751
Everything a person could ever want to know about everything veggy.
2K3 EXCURSION 7.3L 4x4 EDDIE BAUER 107K miles as of 06-13-07
AFE Stage II / 4" MBRP exhaust / DP-Tuner F5 (Stock, 60hp Tow, 80hp Econo, 120hp race & High Idle) / Quadzilla Commander/ATS Housing
Running homebrewed BioDiesel and custom SVO kit for 70k miles.:Thumbup:
Misc. Mods: ZooDad/By-Pass Oil Filter/203* T-Stat/Coolant Filter/HPX/CCV Reroute/Tranny Filter/Foil Delete/Stereo Stuff/ITP Reg Return/Non-EBPV Pedistal and Exhaust Housing/Adjustable Waste Gate Controller/
"If you love your motorcycle, set it free. If it comes back to you it was probably a high-side."
I'LL TRY TO KEEP UP, BUT THE EXCURSION IS A BIG GIRL AND BIG GIRLS DON'T LIKE TO MOVE FAST.
6_Myles is offline
post #3 of 10 (permalink) Old 01-31-2007, 03:53 AM
Talking Bio Diesel
Check out this web sites;globalstewards.org and Journeytoforever.org
Turtledude is offline
post #4 of 10 (permalink) Old 01-31-2007, 04:41 AM
jd87's Avatar
vegistroke.com has what I'm gonna put in mine. I like how it uses 2 separate fuel systems all the way up to the heads instead of using the same lines back to the tanks, having to purge the lines a couple miles before you shut the truck off.
Finished rebuilder 2005 F250 Power Stroke CC SWB FX4 XLT, 2.5"F/1"R skyjacker lift kit, diamond-plate bed caps, Line-X, Sonic Blue Pearl, Billet grille inserts, 17" Mickey Thompson Classic II's, 35" Hankook Mud Terrain's
Current Project: 97 F350 Power Stroke CC LWB XLT 4x4, sideswiped, 62k miles.
jd87 is offline
post #5 of 10 (permalink) Old 06-23-2007, 10:03 AM
Formerly NATTYGASMECH
Canyon JYD's Avatar
I like the sound of that I'll have to check this out. The only one I know of is the greasecar system where the same fuel line is used.
Canyon JYD is offline
post #6 of 10 (permalink) Old 06-23-2007, 10:50 AM
search for "Elsbett"
DieselMonk is offline
post #7 of 10 (permalink) Old 06-24-2007, 09:28 PM
TDG Mafia # 81
Horsehaulin's Avatar
Only thing I want to warn all WVO users of. Filter your oil, and make 150% sure it is dry! I got a tank of WVO with water in it, and it made short order of my IP.
IMO, it is better to buy or make your own bio processor, which converts WVO to biodiesel. Most of these will have some sort of dryer built in or if you build your own, most sites with free instructions will tell you how to make a drying system.
If you go the route of straight WVO or a 50/50 mix, make sure it is clean and dry, a good 2 micron filter setup added to your oem filter would be a great idea. Just my 0.01 cents,
Tony
Horsehaulin is offline
post #8 of 10 (permalink) Old 06-25-2007, 12:02 PM
T.D.G. Mafia Member #88
cumminspride's Avatar
He isn't kidding, I lost a lift pump running the same oil out of the same barrels. Its all good and well untill she dies on ya on the side of the road. If you would like to see the difference between real fuel and well filtered WVO then pour equal amounts into some semi clear containers and let them set for a week. The scum that settles in the bottom of the WVO one is fat and glycerin, this is not smart to run through an IP or an injetor, clean it and dry it and bubble wash it --- that is smart --- but do what you want, all i know is that just filtered and mixed WVO is not good for a diesel engine.
cumminspride is offline
post #9 of 10 (permalink) Old 06-28-2007, 03:34 AM
Curious how far( micron ) you filtered the oil to?
I understand removing 110% of the water from the oil. Were contaminants other than water to blame also?
Thanks
Sader123 is offline
post #10 of 10 (permalink) Old 06-28-2007, 07:59 PM
TDG Mafia # 81
I would filter down as far as humanly possible. I run a custom built/installed 2 micron filter on my truck. Its basically a CAT 2 micron made by WIX/NAPA.
Run that secondary filter, and you should be good to go with a decent stand alone filter for something like farm fuel for your mixing setup.
