2003 6.0 PSD - what mods do I need? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Ewog, this thread has received 5 replies and been viewed 1147 times.
post #1 of 6 (permalink) Old 03-12-2007, 04:18 PM Thread Starter
OK now that fuel has gone up again. I am getting more and more interested in the whole biodeisel thing. So I have a few questions before I get going.
1) What changes do I need to make to my truck/fuel system to run biodiesel. I was hoping to get the kit from freedomfuelamerica.com and want to run it at 100%
2) Is it better to run it by itself or mix it at like 50/50%?
3) My truck just turned 100,000 so warrenty isn't an issue but milage is. So should I do anything else to my motor before running this.
Any help would be greatly appreicated.
I live in So Cal so temps aren't much of an issue.
Ewog is offline
post #2 of 6 (permalink) Old 03-12-2007, 08:39 PM
TDG Mafia Member #21
You don't need to do any mods to the truck to run bio. Mods come in when people want to run wvo or svo. You can run the bio at any concentration you want. Some trucks react differently to each amount so just play with it and find a good balance for your truck.
2007 F350 CC 4x4, EGR delete, stock for now
Old truck :"01" Dodge 3500 DRW. Goerend Bros w/ triple disk, Edge Drag Comp, Jammer Stage 5's, Turnbuckle, Dakota Digital and ISSPRO Gauges, BHAF,4" FLO-PRO exhaust, Vulcan kit, Holley Blue Pump, TC Lockup Switch, Snow stage 2, a few more little bits in the works
377hp and 823tq @ Smokin' (with stage 3's/no drag upgrade)
"400" club wannabe
akapparos is offline
post #3 of 6 (permalink) Old 03-13-2007, 02:12 PM
What you will need is a few fuel filter changes within a couple months. The bio will clean your fuel tank and send all the dirt to the filters especially since you have 100k miles on the truck you will get dirty filters fast.
2006 Dark Copper/Arizona Beige F-250 4x4 King Ranch CC SB 6.0/TorqShift 3.73LS Build 09/05:Bought 09/05 w/3 miles(12-15-06 9,300 all stock miles)
1993 Mack RW713 Superliner E7-350 Jacobbs Jake 8LL 20/58 Camelback 12R 24.5 Tandem Dump(12-15-06 586,000 miles)
1989 Mack RW713 Superliner E6-350 Dynatard 12sp 20/58 Camelback 11R 24 Tandem Dump(12-15-06 317,000 miles)
1996 Cat 416B 4X4 Ext-hoe (12-15-06 6,200 hrs)
2006copperPSD is offline
post #4 of 6 (permalink) Old 03-13-2007, 08:10 PM
I would always have a spare fuel filter on board and tools. You never know when the Bio is cleaning out all the diesel sludge and clogging up your fuel filter.
DieselMonk is offline
post #5 of 6 (permalink) Old 03-18-2007, 02:55 PM
I have to agree You will need to change your fuel filters after running BioDiesel.
You may get a full tank or two run threw your system with out a problem but then the filter will clog and you will see a decrease in power. No Big Deal just change the filter and be on your way. BioDiesel Fuel is much better for your engine as well as your wallet. Have you looked at www.MIYBioDiesel.com ?
Best of luck
Jim
wilseya is offline
post #6 of 6 (permalink) Old 03-18-2007, 04:12 PM
Super Moderator
John_G's Avatar
As others have correctly stated you can run pretty much any Bio % you want, but only B5 is "approved" by the engine manufacturer. This is mostly because no BioDiesel standards have been agreed to for other blends.
Biodiesel is VERY high in Cetane, but slightly lower in energy content. It is a very slight net benefit to fuel economy, and a HUGE benefit to start-ability and lubricity.
NOx emissions are significantly reduced with high biodiesel blended fuels, but all other emissions are reduced significantly, if not eliminated completely (PM).
You should have no problems with B100 in SoCal, but as others have discussed, fuel filtration is a BIGGY!
I vote for LIBERTY!
John_G is offline
