recycle motor oil - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by rockntractor, this thread has received 54 replies and been viewed 12123 times.
post #1 of 55 (permalink) Old 12-21-2007, 12:18 AM Thread Starter
recycle motor oil
is it possible to make diesel out of used motor oil??
rockntractor is offline
post #2 of 55 (permalink) Old 12-21-2007, 01:30 AM Thread Starter
i hate to answer my own question but ,i did a little research. some people heat it above 160 f and use it straight ,others mix it in various combinations with diesel fuel. i even found epa regulations on how much wholesalers can legally mix with low sulfur diesel fuel . we probably have had some in our tanks from time to time without knowing it. it does not have the glycerin that veggy oils have so you don't need methyl or lie to process it. it seems to be a filtering and viscosity issue.this deserves more research!
post #3 of 55 (permalink) Old 12-21-2007, 04:48 AM
some pour it from the oil pan into the tank.... Ive heard others who strain it first and then into the tank... thats my plan, strain down to 10u and into the tank.
jvbutter is offline
post #4 of 55 (permalink) Old 12-21-2007, 11:31 PM Thread Starter
i filtered some today and mixed it 25% with 75% diesel i drove 80 miles with it in my 96 f350 7.3. it ran great no difference in smoke a little better mileage.i went ahead and upped the concentration to 50-50 it runs great.i left straight diesel in my rear tank,5 minutes before i shut down i switch tanks so theres straight diesel in the filter bowl when i start up cold. so far so good
post #5 of 55 (permalink) Old 12-22-2007, 12:13 AM
resident mason
firehillbilly's Avatar
I'm curious, do you think it'll work with common rail???? If I get too much 2stroke in the mix she seems a little slower, I can't imagine straight used oil no matter the blend.
06 Sierra 2500 4wd lb. Predator, S&B, MBRP duals-no cat, Quadzilla gauges, Allison Jr., Riderite air bags, PPE Tie rod sleeves, egr plate / finger stick. 02 Chevy 3500 8.1L 4wd dump 9' Fisher mm2, sander. 03 Kubota L4630. 80'S or 90's Komatsu pc50. 89 d250 5.9 which may someday go into something.:
firehillbilly is offline
post #6 of 55 (permalink) Old 12-22-2007, 12:32 AM Thread Starter
i am no expert but i just read that new 2 stroke oil has additives and that used oil has broken down the additives making it better for the injectors. i haven't tried it in my kubota 7040 yet i have to wait till the warranty is up in august. i am going to try it in my 466 int and my 1984 6.9 diesel. also my truck is programmed edge evolution extreme setting i don't know if that makes any difference or not. i'm a novice whats common rail?
post #7 of 55 (permalink) Old 12-22-2007, 02:30 AM
i ordered a couple of Bio filters off Ebay the other day... so I will start my recycling process then... whoooo Yaaahhhhh
jvbutter is offline
post #8 of 55 (permalink) Old 12-29-2007, 02:50 AM
2nd Gen Guru
Mopar1973Man's Avatar
You got to remember that WEO doesn't have the lubricity of new engine oil or 2 cycle oil. So you might have to add a bit of fresh oil to it to keep the HFRR value low...
http://mopar.mopar1973man.com/2002%2.../HFRR/HFRR.htm
Mopar1973Man is offline
post #9 of 55 (permalink) Old 12-30-2007, 10:00 PM
yup yup, been reading off that link you posted this morning... trying to decide if the standyne is worth the extra $$$ vs 2 cycle
jvbutter is offline
post #10 of 55 (permalink) Old 12-30-2007, 11:58 PM
2nd Gen Guru
Basicaly there both the same for HFRR. But I'm pretty sure the Standyne cost more... But not by much...
