transformer oil? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by sawmillman, this thread has received 7 replies and been viewed 922 times.
post #1 of 8 (permalink) Old 01-13-2008, 08:35 PM Thread Starter
transformer oil?
I was working for a guy acouple of months ago and he has been running oil from electical transformers in his truck and eguipment does anyone have a opinion on this do you think it's safe.:shrug:
sawmillman is offline
post #2 of 8 (permalink) Old 01-14-2008, 04:27 AM
yes it is ok(safe) my bro has a 98 12 valve, and he runs motor oil, trans fluid, hydraulic fluid with no problem
dmaxvaz is offline
post #3 of 8 (permalink) Old 01-14-2008, 01:47 PM
TDG MAFIA MEMBER #71
POWER STROKE 99's Avatar
Most new transformers have mineral oil in them.
POWER STROKE 99 is offline
post #4 of 8 (permalink) Old 01-14-2008, 01:59 PM
i know hydralic fluid is supposed to be equal to 30w motor oil but only for topping off
86 1 tonhauler is offline
post #5 of 8 (permalink) Old 01-15-2008, 02:24 AM Thread Starter
does the truck smoke bad when running that stuff?doesn't clog injectors
post #6 of 8 (permalink) Old 01-23-2008, 02:17 AM
2nd Gen Guru
Mopar1973Man's Avatar
As long as you don't exceed about 5% volume of oil. (Cummins Specs)
(5% Volume is about 1.75 Gallons of oil to 35 Gallons of fuel)
As for me I run right at 128:1 ratio of 2 cycle oil and it runs great. It lubes the fuel system up, the 2 cycle oil is meant to be burn compared to transformer oil (mineral oil), leaves no deposits on the pistons or injectors. Plus it increase my summer MPG by about +2 MPG's... As for power I got good number on the dyno look at my sig...:Thumbup:
Mopar1973Man is offline
post #7 of 8 (permalink) Old 02-01-2008, 10:10 PM
~CrazyDiesel~ is offline
post #8 of 8 (permalink) Old 02-01-2008, 11:42 PM
2nd Gen Guru
Thanks... Thats some food for thought there... Another one to add to the DON'T USE listing...
