Question.. - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by junior323, this thread has received 13 replies and been viewed 1041 times.
post #1 of 14 (permalink) Old 01-18-2008, 09:22 AM Thread Starter
Question..
I have 100 gallons of mineral oil and 110 gallons of soy oil... can I make bio diesel with these?
TIA
-Junior
junior323 is offline
post #2 of 14 (permalink) Old 01-22-2008, 07:55 PM
Mafia Member #110
razrbakcrzy's Avatar
Images: 14
You can with the soy oil, I do not know about the mineral oil...
MY TRUCK 2004 Crew cab 4X4 Laramie 305/555 Cummins - Volant CAI - Striker II - set on level 3 - 17.8 MPG Mixed driving. I just drove nearly 1000 miles of Hwy only @ 22.1 mpg avg. 90% with cruise control set on 74 mph. (HAND CALCULATED)
I am not going anywhere! I do not wish him well and I am never going to agree with him. Just as the liberals did to George Bush, I hope he fails his mission. Only his mission is not to win a war on terror, his mission is to turn this United States into a socialistic society.
"Conservatives and liberals are kindred spirits as far as government spending is concerned. First, let's make sure we understand what government spending is. Since government has no resources of its own, and since there's no Tooth Fairy handing Congress the funds for the programs it enacts, we are forced to recognize that government spending is no less than the confiscation of one person's property to give it to another to whom it does not belong -- in effect, legalized theft. Liberals believe government should take people's earnings to give to poor people. Conservatives disagree. They think government should confiscate people's earnings and give them to farmers and insolvent banks. The compelling issue to both conservatives and liberals is not whether it is legitimate for government to confiscate one's property to give to another, the debate is over the disposition of the pillage." -- Walter Williams in his book All It Takes Is Guts
razrbakcrzy is offline
post #3 of 14 (permalink) Old 01-23-2008, 02:20 AM
2nd Gen Guru
Mopar1973Man's Avatar
Soy oil for sure can be used for BIO diesel production....
In small portions you can use the mineral oil as a fuel lubricant. I wouldn't use more than 128:1 ratio. But I would NOT suggest using mineral oil. Not knowing whats in it... (Ash levels, other chemicals, etc) These thing can level deposits on your pistons or injectors...
Mopar1973Man is offline
post #4 of 14 (permalink) Old 01-25-2008, 03:08 AM
don't use the mineral oil, you need fatty acid chains in order to make bio-diesel, or hydrocarbon chains to make petrol-diesel, if you can tell me just what mineral oil is I can tell you whether to make it or not, but until you can, don't
cajuncummins is offline
post #5 of 14 (permalink) Old 01-25-2008, 03:45 AM Thread Starter
I was told by a good source that I can run soy oil 50/50 with diesel, how good of an idea is that?
and here is info on the mineral oil.... http://en.wikipedia.org/wiki/Mineral_oil
-Junior
post #6 of 14 (permalink) Old 01-26-2008, 02:31 AM
well, you can run anywhere between 0 and 100% percent converted soy oil, or you can run 100% straight soy oil, and that's it unless it's been converted it won't mix well with the diesel
and as for the mineral oil, I don't think it's the right stuff, from that article it sounds like t's too viscous, the atom-chains are too long to work well, it might, but i still wouldn't, there;'s no real risk to risk it
post #7 of 14 (permalink) Old 01-26-2008, 03:11 AM Thread Starter
thanks for all the info Cajun!
-Junior
post #8 of 14 (permalink) Old 01-26-2008, 03:19 AM
if you need any help on the conversion you can pm me or ask in a thread, it's all pretty simple, just gotta be careful, any ford 03-newer, any d-max, and any dodge 03-newer will be very picky when it comes to particulates in the fuel, so you need to filter it well
post #9 of 14 (permalink) Old 01-26-2008, 03:23 AM Thread Starter
awesome! thanks!
what would need to start converting?
-Junior
post #10 of 14 (permalink) Old 01-26-2008, 03:32 AM
well, I meant the oil to fuel, sorry, but your truck is pretty new, so I'd say nothing, but there are some problems with rubber lines being eaten away at, but nothing serious, and your first fuel filter might need to be changed pretty quickly, as well as bio lubricates engine parts, it's a solvent to just about everthing else, and you will need to change the fuel filter or it might get clogged with fresh junk you've just knocked off
