wvo questions - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 96 stroker, this thread has received 5 replies and been viewed 761 times.
post #1 of 6 (permalink) Old 03-04-2008, 01:43 PM Thread Starter
wvo questions
ok i have a few questions. when you make it home. how much should you mix it with #2 diesel to make it run right? cause from what i heard you have to have seprate tank and pump to run 100 veggie. and would penut oil work for this?
96 F350 crew cab long bed. DIY green filter intake 7 inch stacks. stock height .275,000 and still truckin
96 stroker is offline
post #2 of 6 (permalink) Old 03-06-2008, 12:14 AM
TDG Mafia # 81
Horsehaulin's Avatar
WVO is not a good source of fuel. The best bet is to make it into Bio-diesel. Thats what I would do.
WVO burned up a injector pump in my 99 6.5TD powered truck, it has glycerin and fats from the foods it cooks that clogs fuel filters and everything else related to the fuel system really fast. Also toasted a lift pump at the same time, but I think that was from age.
Tony
Horsehaulin is offline
post #3 of 6 (permalink) Old 03-07-2008, 12:58 AM Thread Starter
thats what i meant
post #4 of 6 (permalink) Old 03-07-2008, 06:33 AM
TDG Mafia # 81
You can run 100% bio in the summer months, but it is wise to blend it down to less than 20% in the winter months. Depending where you live ofcourse, and peanut oil would work just fine once converted to Bio.
In my area the highest bio I can get is B20 retail bought as I dont have a processor or the time to make my own bio. I run the B20 in the summer months and when it drops below 10* I switch to B2, as that is the only other blend they offer in this are right now.
Hope you get your processor up and running properly!
Tony
post #5 of 6 (permalink) Old 03-12-2008, 02:36 PM
Horse,
Where are you buying the B20 retail??? Know of anywhere in Indianapolis that sells?
scarr133 is offline
post #6 of 6 (permalink) Old 03-15-2008, 01:09 AM
http://www.biodiesel.org/buyingbiodi...lfuelingsites/
Go here it should be able to tell you where your local bio station is. They are not all on here but most of them are.
Trapper is offline
