New to this and lost, Bio questions - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 06MegaRam, this thread has received 3 replies and been viewed 824 times.
post #1 of 4 (permalink) Old 03-12-2008, 01:57 AM Thread Starter
I am confused, I got some 55 gal drums, cut the top off one and made a stand for it. I went to buy a hot water heater element and they said there is no way to tell what temp the element would heat up to??? Do you wire the element to a switch and check temp till it gets to about 60 and turn it off?? still learning and reading alot. Good info here, you guys amaze me....... I guess I just need someone to help me with direction...
06MegaRam is offline
post #2 of 4 (permalink) Old 03-12-2008, 02:48 AM
You should need a separate temp guage and adjust your element to keep that temp. look here. http://www.cybernet1.com/mcquaid/App...cessor.htmthis is off the top of my head and I can't seem to find my copy of the book to build one but I will keep looking.
Trapper is offline
post #3 of 4 (permalink) Old 04-05-2008, 06:26 PM
megaram, just use an old water heater, change the 220 volt element to 110 volt, remove the top element and plug the hole ( if it has one) also disable the top thermostat( if it has one). now you have a tank, heater and thermostat you can set at whatever temp. you want. i usually set mine at 120 degrees. i suggest you consult "biodiesel community website" good reading on the appleseed.
1996 F 250 extended cab,4x4,7.3l auto trans,power adder cone filter, 3.5 inch straight exhaust, DFuser 18k mod.and veggie powered.
tommy vestrat is offline
post #4 of 4 (permalink) Old 04-08-2008, 05:59 PM Thread Starter
Thanks , I want to try it but can't find Lye in my home town....Still looking
