Mystery Oil - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by cumminsdieselfreak, this thread has received 15 replies and been viewed 3598 times.
post #1 of 16 (permalink) Old 03-29-2008, 03:29 AM Thread Starter
Mystery Oil
Would Marvels Mystery Oil combined with OFF-ROAD diesel make a stock OBS smoke a lot??? THANKS!
cumminsdieselfreak is offline
post #2 of 16 (permalink) Old 03-29-2008, 03:33 AM
pontiacross's Avatar
I cant imagine why. on road and off road diesel shouldn't make any difference. and I'd think the Marvels Mystery Oil would be pretty clean burning unless you were running it about 50/50 or something and then it'd just be oil smoke.
Ross
Tow Rig
Becker Brothers Enterprises
pontiacross is offline
post #3 of 16 (permalink) Old 03-29-2008, 03:35 AM
TDG Official Poo Flinger
TANK'S 250's Avatar
Images: 38
Don't use Marvel....IT IS HORRIBLE FOR YOUR ENGINE!!!
Engines need lubricity,...and Marvel is worse than USLD....
Your better off putting sand in your tank,..than using Marvel.....lol
____________________________
Special thanks to:
TrustedPerformance.com
KLMperformance.com
Black Ops Bumpers
FarmboyFabrications.com
TANK'S 250 is offline
post #4 of 16 (permalink) Old 03-29-2008, 03:38 AM Thread Starter
Oh i didnt know cuz it says on the back of the bottle that it DOES NOT comply with ULSD restrictions and is illegal for use in 2007 and newer vehicles
post #5 of 16 (permalink) Old 03-29-2008, 03:43 AM
TANK'S 250's Avatar
Images: 38
I WAS using it religiously.... until I saw this.....now I wish I never did.
Good for gas...NOT DIESELS!!!!
scroll down and read #17
VVV linkVVV
http://dieselplace.com/forum/showthread.php?t=177728
Now I use Walmart brand 2 cycle...
Special thanks to:
KLMperformance.com
Black Ops Bumpers
The Following User Says Thank You to TANK'S 250 For this addition to TDG:
Hellbilly (10-09-2009)
post #6 of 16 (permalink) Old 03-29-2008, 03:49 AM Thread Starter
DANG IT!!! I thought i had found something that would make my truck smoke an now i find out it only junk... Its something all the time! : (
post #7 of 16 (permalink) Old 03-29-2008, 04:37 AM
Dieselis' Maximus
driximus's Avatar
Off road diesel is off road because its not taxed, not because its ULSD compliant or not.
"Why in hell can't the Army do it if
the Marines can. They are the same
kind of men; why can't they be like
Marines."
Gen. John J "Black Jack" Pershing, USA; 12 February
1918
driximus is offline
post #8 of 16 (permalink) Old 03-29-2008, 02:52 PM Thread Starter
Does using the 2 cycle oil make your truck smoke any more??
post #9 of 16 (permalink) Old 03-29-2008, 02:55 PM
4cstr
I know in my truck...I get more smoke in my 80 econo tune running 2-cycle than I got without it.
post #10 of 16 (permalink) Old 03-29-2008, 03:03 PM Thread Starter
I wished they would bring back the regular diesel like from the '70s...
