Want to try 2 stroke but..... - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by rhodeisland350, this thread has received 76 replies and been viewed 4737 times.
post #1 of 77 (permalink) Old 04-13-2008, 06:27 PM Thread Starter
I've been using diesel kleen in the white bottle since i picked up my truck in February. After doing all the reading about 2 stroke vs additives I want to try running some 2 stroke and see how my truck runs on it.
My question is should i run a few tanks w/o anything to get all of the diesel kleen through the system or can i add the 2 stroke at my next fill up???? I think i've already filled up twice w/o adding the DK.
Also, i haven't really been running it past a half tank b/c of fuel prices so how many gals does a stock tank not harpooned hold????? And how many gals can you put into the tank after the pump clicks off w/o the harpoon stuck in it??? I usually try to sneak another couple gals in, but i don't want to get a surpise diesel bath .
rhodeisland350 is offline
post #2 of 77 (permalink) Old 04-13-2008, 06:54 PM
********* and Mafia #90
Bcarriveau's Avatar
i would run 2stroke 1oz per gal of fuel and then DK every 8-10 tanks not mixing it with the 2stroke.. just my 2 cents.
100K miles on 4/7/2010
2005 F250 FX4 Supercab Shortbed
Da Rules..Here
Windows 7 Takes the WIN!
Windows 8 might take that Win
http://www.bcarriveau.com/
Dear Tequila:
The TDG TOTQ
Bcarriveau is offline
post #3 of 77 (permalink) Old 04-13-2008, 07:05 PM
mattsn's Avatar
you can add the 2stroke in at anytime. and i think the tanks hold 29 gallons if i remember right.
mattsn is offline
post #4 of 77 (permalink) Old 04-13-2008, 07:45 PM
TDG Singles Outlaw #10
I think the short bed is 27gal..
2006 Harley Davidson 4x4 F250 6.0L-PSD #02250
Bully Dog--Triple Dog w/Outlook, MBRP Turbo-Back 4in SS off-road Exaust, Airaid cold air intake,Zoodad, PDP Intake Elbow, FabTech lift W/ Dirt Logic 2.25 shocks, Moog Teflon Sway Bar Bushings, Nitto Terra Grappler tires, Line-X, Jason Camper Top, KC Light bar, Rigid Dully backup lights, Viper Remote Start Alarm, Eclipse TV/DVD/NAV, Custom TV in center console, JL 500/1 on 2 10W3's, JL 4ch on 5x7 Boston's,http://www.adamspolishes.com/, 2013 5x10 LOOK trailer Grey, 2015 Jayco 34RSBS Trailer.
Next Mods: Head studs(waiting for install),injectors, Steveracermod, Coolant Filter(waiting for install)
For Sale+++ Roll-N-Lock bed cover 6 1/2ft bed +++For Sale
https://www.thedieselgarage.com/galle...=9&userid=8088
TDG Singles Club #117
tjigger is offline
post #5 of 77 (permalink) Old 04-13-2008, 07:51 PM
Bcarriveau's Avatar
i have short bed and mine is 29 as well..
I just said not to mix with DK because your trying to clean the system so i would think dk by it self would work better.
Da Rules..Here
Dear Tequila:
The TDG TOTQ
post #6 of 77 (permalink) Old 04-13-2008, 08:08 PM
mattsn's Avatar
Bill your right , you wouldnt want to mix the two. i meant it could be added at anytime now since he said he hasnt put any DK in for the last two tanks. However if your getting clean fuel and using quality fuel filters and changing them often enough you shouldnt have anything for the DK to clean.
mattsn is offline
post #7 of 77 (permalink) Old 04-13-2008, 08:18 PM
Originally Posted by bcarriveau
i have short bed and mine is 29 as well...
For some reason I thought it was a 27gal, I guess thats because I don't drive it alot and i never fill her up.:shrug:
tjigger is offline
post #8 of 77 (permalink) Old 04-13-2008, 08:18 PM
Bcarriveau's Avatar
its kewl, i can only put like 27 in anyways, bigger fuelsystems start to suck air when they get low..
Da Rules..Here
Dear Tequila:
The TDG TOTQ
post #9 of 77 (permalink) Old 04-13-2008, 09:20 PM
strokin6L's Avatar
Short boxes are 29 gal and long boxed are 38 or 39 gal. I'm glad i dont have a long box cause diesel is like 4.30 a gal here and it would cost me a fortune to fill it up.
strokin6L is offline
post #10 of 77 (permalink) Old 04-13-2008, 09:50 PM
HalfAst Racing
skippy's Avatar
Images: 1
im only running .5oz per gallon as i still have all emissions in place.im almost through my 1st gal of 2 stroke and im gonna pull the egr and check it out.(was new when i started on the 2 stroke)but i can say that for me i didnt notice any big improvements for the first 2-3 tanks.then i steadily gained mileage and it started running quieter.my fuel pump even quieted down.i think the egr will tell the tale if its leaving deposits or not.i run the same fuel every time and im not gonna run any dk till after i check the egr to make sure its unbiased.so far im sold on 2 stroke but i want to see if theres any ill side effects also.
2004 f250 cc/sb,magnaflow turbo back.rockin rcd tunes 18" harley wheels
2001 excursion 6in 35s
1993 mustang lx,6.0l 5r,project rattlesnake
skippy is offline
