Fuel Additive needed?? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by SDNeal, this thread has received 7 replies and been viewed 1057 times.
post #1 of 8 (permalink) Old 04-25-2008, 02:28 AM Thread Starter
I own an 08 250 PS and am wondering if adding fuel additive to the 6.4L is neccessary or not. I have been seeing a lot of adds for Diesel Kleen and have a friend using it every fill up in a 07 Cummins. Is this something that would be beneficial since using ULSD or is just a waste of money. 2,000 miles on truck and runs great, tail pipe still looks like it did the day I picked it up (what a glorious day)! Any input would be nice or if anyone could recommend a better product in your opinion. Thanks in advance!
SDNeal is offline
post #2 of 8 (permalink) Old 04-25-2008, 02:37 AM
Now Cummins Powered
MRBOHN23's Avatar
Hey bud, well personally I don't think it hurts to run an addative just because it further lubricates the motor. I ran Ford's cetane booster and performance addatives in the winter with every fill up. Now I just tried a bottle of amsoil cetane booster, and noticed a slight increase in mileage out of my last fill up. I just bought a case of Ford's performance addative for the rest of the year. I been averaging about 15mpg's overall which is much better than the 10.5 - 11 mpgs that I was getting when I brought the truck home. Guess it's a preference thing I would run something in it, but thats just me. Make sure it is Ultra Low Sulfur Diesel compatable before you add it to you fuel. Good luck.
2004.5 Dodge 2500 Quad Cab Cummins Powered, Laramie, Tow Pkg., Snow Plow Pkg., 4.10 Rears.
2008 Ford F-250 Crew Cab Lariat, 6.4 Powerstroke, Snowplow Prep, Automatic 3.73 posi, 18 inch wheels, SOLD!!!!
MRBOHN23 is offline
post #3 of 8 (permalink) Old 04-25-2008, 03:50 AM
2 stroke oil (ashless TC-W3) 1 oz. per gallon- there are threads all over this site about it- you'll be telling everybody about it after 10 miles..........
imported_jonesie is offline
post #4 of 8 (permalink) Old 04-25-2008, 04:38 AM
TDG Official Poo Flinger
TANK'S 250's Avatar
Images: 38
do Not Put Anything In Your 08.....especially 2 Cycle...it Will Kill Your Dpf...
The 08's were designed to run on ULSD...2 cycle will cause you nothing but problems.
2 cycle is only to be used in 07 and earlier!
____________________________
Special thanks to:
TrustedPerformance.com
KLMperformance.com
Black Ops Bumpers
FarmboyFabrications.com
TANK'S 250 is offline
post #5 of 8 (permalink) Old 04-25-2008, 10:44 AM
Back in the Saddle
seapig's Avatar
Yea, you'll be telling everyone about the $5000.00 DPF you had to replace because you ran 2 stroke through it.....
~Mike~
2008 F-450 Lariat 4x4 6.4L PSD LWB DRW 4:88's
2nd Vehicle: '08 Sport Trac (Lindy's Chick Truck)
seapig is offline
post #6 of 8 (permalink) Old 04-26-2008, 02:32 AM
OOps....didn't notice what year truck you had- My bad, I'm a :loser ...............what they said- sorry 'bout the bad info!
post #7 of 8 (permalink) Old 04-27-2008, 01:38 AM Thread Starter
Thanks for the input guys, I will be trying something next time I fill up.
SDNeal is offline
post #8 of 8 (permalink) Old 04-28-2008, 12:35 AM
2nd Gen Guru
Mopar1973Man's Avatar
Let me help out here... Since 2 cycle oil or any kind of lubricant is bad in a 2007+ model year trucks I can post a pic of the HFRR values so you can choose a proper additive...
WEO, WVO, and 2 cycle oil are NOT to be used in any 2007+ model year trucks! Beaware some trucks are limited to level of BIO Diesel usage. (Cummins less than B20)
Mopar1973Man is offline
