2 cycle oil sound test results!!!! - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by imported_jonesie, this thread has received 15 replies and been viewed 1398 times.
post #1 of 16 (permalink) Old 04-26-2008, 02:58 AM Thread Starter
Post 2 cycle oil sound test results!!!!
OK boys and girls.........the results are in-
Here is the setup:
Does 2 cycle oil actually quiet the engine, or is it all in our warped minds??
For the test:
>I parked my truck in it's usual spot on the driveway
>Placed a tape measure on the ground perpendicular to the left front wheel
>Placed a digital sound meter on an 8" high photo tripod with the sound pickup at 36" from the wheel.
>Recorded sound measurements on fast response, "c" weighting and adjusted scale for decibel range.
>Sound measurements were taken with truck at operating temperature, no accessories on (a/c, htr., lights, etc.)
>Measurements recorded for truck at idle and 2000 rpm in park, auto trans.
>Setup was duplicated for straight ULSD and 128:1 2 cycle oil mix, both tests conducted at approximately 6:30 pm PDT., several days apart.
Test #1- 128:1 2 cycle oil (I already had the mix on board, so I ran this test first):
>Reading at idle- 79 db
>Reading at 2000 rpm- 89 db
Test #2- Fuel tank run as low as I dared, then filled with straight ULSD, driven for 125 mi., then tested:
>Reading at idle- 84 db
>Reading at 2000 rpm- 92 db
Conclusion:
The addition of 2 cycle oil at a ratio of 128:1 (or 1 oz/gallon) attenuates or reduces the sound generated by the diesel engine at idle 5 db, and 3 db at 2000 rpm.
Subjectively, the tester felt that the truck ran more smoothly overall and displayed less perceived vibration in-cab with the addition of 2 cycle oil, and also the 5 db sound attenuated recorded was easily noticed both in-cab and standing outside.
Respectfully,
Jonesie.
imported_jonesie is offline
post #2 of 16 (permalink) Old 04-26-2008, 03:01 AM
Ive been runnin 2 cycle in my 24V Cummins for 6 months now! :Thumbup: Theres been times where I have filled up in between without 2 cycle and can def tell and hear a difference in how the truck idled.
fordkiller43 is offline
post #3 of 16 (permalink) Old 04-26-2008, 03:05 AM Thread Starter
Sorry, here are the pics- I was in such a hurry to post I forgot!
Attachment 17425 Straight ULSD setup
Attachment 17427 Idle straight ULSD
Attachment 17428 2000 RPM straight ULSD
Attachment 17426 2 cycle setup
Attachment 17429 Idle 2 cycle
Attachment 17430 2000 RPM 2 cycle
Name:	sound test setup straight ULSD.jpg
ID:	15616   Click image for larger version
Name:	sound test setup 2 stroke.jpg
ID:	15617   Click image for larger version
Name:	idle straight ULSD.jpg
ID:	15618   Click image for larger version
Name:	2000rpm straight ULSD.jpg
ID:	15619   Click image for larger version
Name:	idle 2 stroke.jpg
Name:	2000rpm 2 stroke.jpg
post #4 of 16 (permalink) Old 04-26-2008, 03:08 AM
Good pics man. That def shows the difference!
post #5 of 16 (permalink) Old 04-26-2008, 04:29 AM
I know I can tell a difference. Now I there is hard evidence. Thanks
post #6 of 16 (permalink) Old 04-26-2008, 02:51 PM
2nd Gen Guru
Mopar1973Man's Avatar
Right on! More information to post up on my web site for others to see! Thank you for your time and the information...:Thumbup:
Mopar1973Man is offline
post #7 of 16 (permalink) Old 04-26-2008, 02:53 PM
TDG Official Poo Flinger
TANK'S 250's Avatar
Images: 38
Nice job man,....I'm glad I nominated ya.......lol
____________________________
Special thanks to:
TrustedPerformance.com
KLMperformance.com
Black Ops Bumpers
FarmboyFabrications.com
TANK'S 250 is offline
post #8 of 16 (permalink) Old 04-26-2008, 03:31 PM
Cincinnati Guy's Avatar
What 2 Cycle are you using? Just add it straight to the fuel tank?
FORMERLY SMOKIN85
Ryan
1994 F-350 SRW Crew Cab 4x4 Dana 60 Front, 4.10 Gears with a E4OD
SOLD-1992 F350 7.3
Ryans 92 Diesel Pictures
SOLD-1985 F250 6.9 NA
Ryans 85 Diesel Pictures
The Diesel Garage Mafia
Singles Club
Ridin' Dirty Club #24
Don't forget to vote in TOTQ
Cincinnati Guy is offline
post #9 of 16 (permalink) Old 04-26-2008, 03:34 PM
The Big Meanie
bigdraft's Avatar
way to go Jonesie.....great job right there!!!!!!!
oopkevinoop
Boys Stroke It...Men RAM It
Dually Club Member
Farm Club Member
I Got A Named Bubba
In Progress...
FOREVER FARMS
What Is A Farm With No Barns?
bigdraft is offline
post #10 of 16 (permalink) Old 04-26-2008, 03:38 PM
2nd Gen Guru
Here is my write up on Jonesie hard work and testing... Thank you! :Thumbup:
http://mopar.mopar1973man.com/2002-d...l/db-level.htm
