transformer oil in a 12 valve - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by baker9713, this thread has received 3 replies and been viewed 963 times.
post #1 of 4 (permalink) Old 04-27-2008, 03:06 PM Thread Starter
Send a message via AIM to baker9713
Anybody have any experience running used transformer oil as fuel? I service the oil purifier units for several power companies & may be able to get it cheap. I haven't been able to find much info on it, but I've read a couple posts here & there that mention it.
Mike
95 Dodge 2500 4x4 12v CTD
Keystone Heights, FL
baker9713 is offline
post #2 of 4 (permalink) Old 05-01-2008, 02:16 PM
2nd Gen Guru
Mopar1973Man's Avatar
Because of other chemicals and the type of oil it is I would highly suggest against even using this in your fuel. The only oil that is design to burn completely and clean is 2 cycle oil...:
Mopar1973Man is offline
post #3 of 4 (permalink) Old 05-01-2008, 02:58 PM
myfastfuel.com has some interesting reading. Im not bucking what mopar is saying at all. There are other opinions on this particular oil to consider. Im at about the 3k mile mark on 40-50% mix of wmo. The only oil that has been in the truck that wasnt diesel motor oil was about 5qts. of mobil 1 and I think I could tell when it would get a dose of that. I dont know if the specific grav. was different or if it just didnt mix the same but the idle was a little irratic. No other issues .
02 F250 CC, 4X4,SB. DP Tunes stk, 80econ,120. NAPA 6637 air element. Summit 4" turboback. GDS hi-flo outlet. 1.0 turbine housing. HX cross-over. Modded pedestal. CCV mod. Fuel rails connected. AIH delete, pre-pump.
Tyrod is offline
post #4 of 4 (permalink) Old 05-03-2008, 12:50 AM
#454
Motown Fire's Avatar
Is the oil petroleum based??? If so I would say why the hell not. Your dodge 12V and my 7.3L are allot alike since they will run off of almost anything.....
2011 Dodge 3500 DRW CTD CrewCab 4X4 G56
2012 PJ 40' Dual Tandem Flat Bed
Motown Fire is offline
