hydraulic oil - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Andy King, this thread has received 4 replies and been viewed 946 times.
post #1 of 5 (permalink) Old 05-02-2008, 01:03 AM Thread Starter
97F-3504X4PSD
Andy King's Avatar
hydraulic oil
Do ya'll know if Mobile DTE 25 or 26 can be run in our diesels. If it can, would you treat it like the WVO(mixing with methanol & NAOH). Thanks in advance.:thanks:
97, F-350, 7.3 PSD, OBS, 4X4, Reg. Cab, SRW, 4.10 gears w/ Locking rear, 235-85/R16s, Shimmed FPR, Zoo Dad, DIY intake, Turbo friendly Cat., Transgo Tugger Kit(RacerX).
Next(3"-3.5"-4" downpipe & 4" Exhaust)
"You may take a bullet, but you will never take one of my guns"
Andy King is offline
post #2 of 5 (permalink) Old 05-02-2008, 01:20 AM
CrowsSynthetics's Avatar
Send a message via Yahoo to CrowsSynthetics
Post
I really canít say I do know of some using ATF after it has been flushed out of the flush machine.
Bill
2003 F250 FX4 SUPERCAB SPORT XLT 7.3 PSD
Amsoil 3000 5w 30 ,Amsoil EaAU Air Filter ,Amsoil Pre filter-EaPF13,
Amsoil Dual Remote By-pass BMK-16A, Amsoil ATF & Transfer case, Amsoil 75w-140 fluid front & rear end, Amsoil Antifreeze Fluid
Edge with Attitude, 4" Turbo Back Exhaust,
5" SS Tip
, Transmission Magnefine filter, Sportman Tonneau Cover & Bush Fender Flairs
Now in the stable a new Black 2009 Jetta Sedan TDI
CrowsSynthetics is offline
post #3 of 5 (permalink) Old 05-02-2008, 02:05 PM
2nd Gen Guru
Mopar1973Man's Avatar
Bill
Becareful with that for 2 reasons...
1. ATF isn't meant to be burned its got chemicals like friction modifiers in it that will increase wear in the fuel system. Not to mention the amount of deposits it will leave in the combustion chamber.
2. RED DYED diesel is illegal period! If your caught and dipped and find red dyed diesel in there you might be in serious trouble with very large fines!
The only thing that is safe to burn is 2 cycle oil it tested and proven! :Thumbup:
Mopar1973Man is offline
post #4 of 5 (permalink) Old 05-02-2008, 02:21 PM
I would think Hyd. fulid would come under the same thinking chemicls that may be harmfull.
Bill
5" SS Tip
post #5 of 5 (permalink) Old 05-02-2008, 03:06 PM
2nd Gen Guru
What I understand about older lubricants... Like ATF and Hydraulic fluid... Back in the 70's it was basically like mineral oil/petroleum based and a few minor additives put in... That way the old tymers where able to put large amounts of ATF or hydraulic fluid in the fuel and get away with it. Not to mention the design of the older diesel engines would comsume just about anything.
Now with today engines and tight tolerances and electronic injection (pumps or injectors) these engines don't tolerate WEO, WVO, or other oils very well without some sort of change in performance and/or effect of life of the pumps.
Like ASH content is really important... Measures inorganic residues - The small amount of non-combustable metallic material found in almost all petroleum products is commonly called ash. Ash content should not exceed 0.02 mass percent. These residues are actually a deposit that will be left behind on the pistons, and combustion chamber...
Then ther is the carbon residue... Measures residue in fuel - can influence combustion. The tendency of a diesel fuel to form carbon deposits in an engine can be estimated by various tests to determine the carbon residue after 90% of the fuel has been evaporated. WEO or WMO tend to be extremely high in this catagory because of the amount of carbon already wasted in the oil...
So... To keep the performance up I would use a clean oil that meant to burn like BIO or 2 Cycle Oil...:Thumbup:
