Have a question about bio. Can I run 20 gals through a 50 gallon hot water heater - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 06MegaRam, this thread has received 3 replies and been viewed 1087 times.
post #1 of 4 (permalink) Old 05-03-2008, 11:02 PM Thread Starter
Just wondering if I can run only 20 gallons of oil though a 50 gallon hot water heater without burning up the heating element...?
06MegaRam is offline
post #2 of 4 (permalink) Old 01-20-2009, 05:04 PM
sure, thats what i use. the trick is you must disable the top element. i just took mine out and plugged the hole, removed the top thermostat, and wiired straight to the bottom.you can make smaller batches as long as there is enough oil to cover the element. if you are just starting out i suggest you consult "Collaborative Biodiesel Tutorial" website. they will be able to give you the plans for turning your hot water heater into a biodiesel processor.because you need more than just waterheater(pump,plumbing,modifications,temp.gage, etc... hope this helps
1996 F 250 extended cab,4x4,7.3l auto trans,power adder cone filter, 3.5 inch straight exhaust, DFuser 18k mod.and veggie powered.
tommy vestrat is offline
post #3 of 4 (permalink) Old 01-28-2009, 12:00 AM
Sader's Avatar
Put a clear cinyl tube on the outside of the tank and make sure the element is covered. Like tommy vestrat says just make sure the element is covered.
Sader is offline
post #4 of 4 (permalink) Old 02-21-2009, 02:12 AM
can i get some more info on using a water heater to process wvo or wmo ? ive collected about 200 gallons of wmo and im lookin to setup a processor. thanks
1991 F350 4x4 7.3 idi na
4.10 & 34" super swampers
goatwrangler is offline
