Jet Fuel? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Jetmech, this thread has received 7 replies and been viewed 3004 times.
post #1 of 8 (permalink) Old 05-05-2008, 06:44 PM Thread Starter
Jetmech's Avatar
Jet Fuel?
Does anybody know how jet fuel will run? I heard just add an additive but not 100% sure.
Thanks.
2003 GMC 2500HD 4" straight exhaust, BD manifold, intake, Air Dog 150 lift pump, BD Supermax turbo, Suncoast Stage IV, Isspro EV2 gauges, EFI Live w/DSP 5 tuned by Xtreme FX Tuning.
Canadian Club Member #6.
Jetmech is offline
post #2 of 8 (permalink) Old 05-06-2008, 04:22 PM Thread Starter
Jetmech's Avatar
What about half and half with diesel? Anything to add then or is 2 stroke oil ok to run anyhow. I heard 2 stroke oil doesn't have much effect on a Duramax. Anything else I could add to get the power back?
Jetmech is offline
post #3 of 8 (permalink) Old 05-06-2008, 07:20 PM Thread Starter
Jetmech's Avatar
Thanks for the info. What needs the lube? the fuel pump?
Jetmech is offline
post #4 of 8 (permalink) Old 01-17-2009, 04:37 PM
2nd Gen Guru
Mopar1973Man's Avatar
The whole fuel system... Here is a document from Bosch...
http://mopar.mopar1973man.com/pdf/022003bosch.pdf
If you lubricity is too low it will cause serious damage to pumps and injectors...
PASSING GRADE!
FAILING GRADE!
Mopar1973Man is offline
post #5 of 8 (permalink) Old 11-05-2010, 07:49 PM
Send a message via AIM to BarnhardMarine
Jet fuel is very dry if you add oil to it you will be fine I add about a gallon of oil to 100 gallons of fuel. The USN uses JP5 in all their diesel powered line equipment. I used to use JP5 in my old IHC 4070 it had a 318 in it and it didn't care what it burned
BarnhardMarine is offline
post #6 of 8 (permalink) Old 11-15-2010, 03:05 AM
Duramax/Allison
747MD11's Avatar
we used to put JP8 into the Hummvee (the old 6.5L) when I was in the Army back in the early 90's.. It's just highly refined diesel (Kerosine).
2011 Duramax 2500HD LTZ
100% US Made of mostly US parts with some parts from Germany and Japan.
Video of my truck: Youtube Video
2005 E320 CDI
2008 BMW X5 4.8i
747MD11 is offline
post #7 of 8 (permalink) Old 02-06-2011, 02:58 PM
Send a message via Yahoo to CMorse
JP8
They still use JP8 in all military vehicles. Hummers, UH-60's we put it in everything. Just change out your fuel filters after the first couple of tanks. It will clean everything out and clog your injectors.
CMorse is offline
post #8 of 8 (permalink) Old 05-04-2011, 09:00 PM
Combat Trucker
hillbilli's Avatar
I used to put a lot of miles on vehicles in the military running JP8. It burns really hot and you dont get as much power, we could always tell when we got actual diesel over JP8. Our mechanics recommended puring a quart of tranny fluid every other tank or so to keep the fuel pump lubbed and to keep the injectors from burning up.
hillbilli is offline
