room temperature Oil? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by rrose, this thread has received 0 replies and been viewed 967 times.
post #1 of 1 (permalink) Old 02-07-2009, 06:02 PM Thread Starter
Will room temperature waste motor oil flow through a 2 micron water filter? Does it have to be heated to filter through it? Does it have to be cut with diesel to flow through?
2008, F-250, FX4, Crew Cab, Short Bed, Oxford White w/ black interior, Dual Alternators, Sat. Navigation & Radio, Overhead DVD System, ESOF, Solid Rear Window, 3.73 Limited Slip, Upfitter Switches (High Idle & Battery Tender), Tow Command System w/ Power Scope Mirrors, Power Seats, and the Reverse Aid Sensor - Edge Insight Monitor, 2.5" Donahoe Racing Lift Kit, Fox 2.0" Piggy-Back Shocks, KMC Beadlocks w/ 35" Toyo M/T's, MBRP DPF back exhaust, Recon mirror lights, Fitch Fuel Catalyst, Randy Ellis Design Light Bar (Hella & Fuego Lights), Line-X, MotoBar, Gentex Temp/Direction Mirror
rrose is offline
01-08 Use of Room Temperature Vulcanizing (RTV) and Anaerobic Sealant ripmf666 GM Spec Info 0 12-27-2008 12:23 AM
temperature sensor doob51 5.9L Cummins 12 Valve (1994-1998.5) 4 11-07-2007 05:36 AM
Temperature Wire Seventy468 5.9L Cummins (1998.5-2002) 0 03-19-2007 02:37 AM
EGT average temperature? imported_ryan 1994-2003 7.3L Power Stroke 2 02-15-2007 02:08 PM
