Whats this ATF as diesel additive ? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by M123KT-450, this thread has received 16 replies and been viewed 8292 times.
post #1 of 17 (permalink) Old 02-28-2009, 02:36 AM Thread Starter
M123KT-450's Avatar
I heard this from some guys at a truck shop. dump a 1qt of ATF into your tank, for keeping the fuel system lubed and clean .
Any truth to this ?
Mike
1953 REO M48 w/w.
1962 GMC C45.
1969 AMC AMX -390.
1971 AMC /Jeep J4K-DRW.
1988 AMC /Jeep Comanche.
1991 Dodge RamCharger.
AMO #9860
B.O.M.B Squad #43
Dually Club #98
M123KT-450 is offline
post #2 of 17 (permalink) Old 03-01-2009, 12:40 PM
yes, do some searching on here. many guys run tranny fluid. filter it first then run it.
1991 F350 4x4 7.3 idi na
4.10 & 34" super swampers
goatwrangler is offline
post #3 of 17 (permalink) Old 10-07-2009, 10:52 PM
2006 f250 6.0sd veggi oil
blakenissan07's Avatar
Send a message via AIM to blakenissan07
new fluid not used!!!
2006 f 250 6.0 sd runs on veggi oil....
Blake Armstrong
[email protected]
blakenissan07 is offline
post #4 of 17 (permalink) Old 10-07-2009, 11:52 PM
TDG Mafia
Jeffybuilt's Avatar
Dont do it!
Singles Club #247
TDG Mafia Member
Thanks To:
(269) 663-8571
Jeffybuilt is offline
post #5 of 17 (permalink) Old 10-10-2009, 10:21 PM Thread Starter
M123KT-450's Avatar
I been dumping in 2 funnels full of ATF n 1 funnel full of lube to each tank and during the cold months I add 3 gallons of 87octane gasoline...
Why not add ATF ?
I'm buring HSD fuel runs great !
Mike
1953 REO M48 w/w.
1962 GMC C45.
1969 AMC AMX -390.
AMO #9860
B.O.M.B Squad #43
Dually Club #98
post #6 of 17 (permalink) Old 10-13-2009, 05:44 PM
Heard of ATF for injector cleaner, supose it would also provide some lubrcation!
liftruck is offline
The Following User Says Thank You to liftruck For this addition to TDG:
M123KT-450 (12-16-2009)
post #7 of 17 (permalink) Old 12-14-2009, 10:04 PM
i herd atf is only good in older trucks.. not the new ones..
whats everyone using for the newer trucks 06 and up ?
Blake Armstrong
[email protected]
post #8 of 17 (permalink) Old 12-16-2009, 12:31 AM
2 cycle motor oil from Walmart, their Tech brand TCW-3, IRC. It's what I use.
The important difference between ATF and 2 stroke is the 2 stroke is ashless and is intended to be burned, the ATF is not.
Al
FTG-05 is offline
The Following User Says Thank You to FTG-05 For this addition to TDG:
post #9 of 17 (permalink) Old 07-21-2010, 05:03 AM
ATF as originally used as an additive was type A, the current ratings have much more additives.
The red dye in ATF will have consequences if your tank is dipped by the taxman.
The ULSD at the pump should be rated as a cleaner by itself, same with biodiesel.
2cycle will make up for the change in fuel lubricity, same with 2% biodiesel for the old engines.
81 Isuzu /C223na, 5spd
keydl is offline
post #10 of 17 (permalink) Old 11-02-2010, 02:59 AM
6.2smoke'r's Avatar
i run straight ATF all the time during the warmer months of the year in my Chummins . it LOVES IT very clean burning and almost no soot. i get it free from my buddys service shop. just hot filter it @180 in a 2 micron bag. dont run it if the temp drops below 50 injectors will coke all up . been doing this for 3 years and 71k now and no problems. i also run straight waste engine oil in her !
1983 Chevy C-30 / Cummins 12v powered, 5" dual miter cut stacks, AFC FF, KDP killed, 3600 springs, #10 fuel plate, SM465 trans, 4bt flywheel, 4.56's
6.2smoke'r is offline
The Following User Says Thank You to 6.2smoke'r For this addition to TDG:
377pete (06-10-2011)
Howes Diesel Additive 08DMAXDually Bio-Diesel/ULSD/Additives Discussions 6 02-27-2008 04:31 PM
2 Stroke Oil as a Diesel Additive crappace General Diesel 7 12-09-2006 02:22 PM
2007 Diesel Power! Diesel Additive Dragt Racing Series DavidTD Drag Racing 0 08-23-2006 03:37 PM
Whats the scoop on fuel additive? Stormshadow 2003-2007 6.0L Power Stroke 9 05-18-2006 03:39 PM
Additive for diesel cdooguy 2003-2007 6.0L Power Stroke 12 01-07-2006 05:57 AM
