Has anyone burned Mercon V or gear oil? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by HwyStar, this thread has received 4 replies and been viewed 2144 times.
post #1 of 5 (permalink) Old 04-19-2009, 06:21 PM Thread Starter
I have a centrifuge and pump setup to remove all the particulate and most water. Has anyone burned Mercon V transmission fluid(synthetic) or gear oil yet?
MM1(SW)-N USN CVN65 RM22
'05 F350 DRW 4x4 6L - 15.16 @ 84 mph
'04 Mach 1 - 12.94 @107.5 mph
'94 Mark 8 12.36 @ 109 mph
HwyStar is offline
post #2 of 5 (permalink) Old 04-19-2009, 06:46 PM
TDG Official Poo Flinger
TANK'S 250's Avatar
Images: 38
They aren't ashless,...they make a mess of things,..I sure wouldn't do it..
____________________________
Special thanks to:
TrustedPerformance.com
KLMperformance.com
Black Ops Bumpers
FarmboyFabrications.com
TANK'S 250 is offline
post #3 of 5 (permalink) Old 04-19-2009, 08:55 PM
CrowsSynthetics's Avatar
Send a message via Yahoo to CrowsSynthetics
I have seen post of guys doing this and I talked to a guy up east that does this at least the ATF part. I am thinking of bio fuel and just have not done that yet.
Bill
2003 F250 FX4 SUPERCAB SPORT XLT 7.3 PSD
Amsoil 3000 5w 30 ,Amsoil EaAU Air Filter ,Amsoil Pre filter-EaPF13,
Amsoil Dual Remote By-pass BMK-16A, Amsoil ATF & Transfer case, Amsoil 75w-140 fluid front & rear end, Amsoil Antifreeze Fluid
Edge with Attitude, 4" Turbo Back Exhaust,
5" SS Tip
, Transmission Magnefine filter, Sportman Tonneau Cover & Bush Fender Flairs
Now in the stable a new Black 2009 Jetta Sedan TDI
CrowsSynthetics is offline
post #4 of 5 (permalink) Old 06-16-2009, 01:55 PM
I have used ATF (Mercon V, sepcifically) in small amounts in my fuel. Hasn't had any ill effects that I have noticed. Doesn't blend well with SVO though...
Sam
The Trash Truck
96 CC F350 SRW - Built for SVO and mileage
Go Green - HotFox, Dual Heated Dahl 100s, Fuel Filter Coolant Wrap, ArcticFox
Go Fast - Hybrids, H2E, 6.0 IC, Fuelab, BTS 144.2/291.5 uncorrected
thanx go to
Rockin-S-Performance - Install, tech support, and advice
Diesel Innovations - Killer Deal on Parts
Tony Wildman/SWAMPS - Tuning
genie144 is offline
post #5 of 5 (permalink) Old 10-07-2009, 10:50 PM
2006 f250 6.0sd veggi oil
blakenissan07's Avatar
Send a message via AIM to blakenissan07
i have herd 7.3 runs great on trans fluid... i wouldnt use used tho.. if u work for a shop just take home gallons of it new.....
i run straight veggy oil in my 6.0l
looking to get a centtrifuge wana sell it?
2006 f 250 6.0 sd runs on veggi oil....
Blake Armstrong
[email protected]
blakenissan07 is offline
Mobil 1 Mercon ATF - pre Mercon V TooManyToys Whats Been Sold 5 01-15-2009 01:53 PM
How bad will I get burned? Duke Duramax 07.5-2010 (LMM) 29 04-22-2008 04:28 PM
Custom Burned Chips In Michigan???? bigdraft The Parking Lot 4 08-26-2007 06:51 PM
My Freaking neighborhood almost burned up today TriGuy The Parking Lot 6 10-27-2006 11:20 AM
Mercon SP David Anderson 2003-2007 6.0L Power Stroke 1 05-18-2006 08:45 PM
