Wvo? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by _CH_, this thread has received 12 replies and been viewed 4113 times.
post #1 of 13 (permalink) Old 01-19-2006, 05:50 AM Thread Starter
Wvo?
anyine running some sort of WVO setup?
for as cheap as the kits are im considering it. just dont know how it would work w/our injectors.
thoughts?
_CH_ is offline
post #2 of 13 (permalink) Old 01-19-2006, 09:13 PM
ch,
help us igno's out what the heck is a wvo set up ???
j.schall
jschall is offline
post #3 of 13 (permalink) Old 01-19-2006, 09:35 PM
Waste Vegetable Oil I am assuming...
TXHNTR is offline
post #4 of 13 (permalink) Old 01-19-2006, 09:36 PM
AKA - FFpsd
Its Waste Vegetable Oil....And its basically taking used oil and adding stuff (things that I dont know...lol) so it will run in our trucks.
-Jason
2005 F250 C/C Short Bed
The Diesel Garage
Can You Keep Up???
FireRescuePSD is offline
post #5 of 13 (permalink) Old 01-19-2006, 10:40 PM
WVO is waste veg oil just like FFpsd stated, but it is run as is after filtering.You need a good heater to keep the oil thin enough to pump and warm enough to burn. check here for lots of good info http://biodiesel.infopop.cc/groupee/forums.
You can also check the diesel stop, biodiesel forum( only if we cant answer your questions)
Taking wvo and adding "stuff" is biodiesel.
The stuff needed is wvo, methanol, and sodium hydroxide.
nummit is offline
post #6 of 13 (permalink) Old 01-19-2006, 11:38 PM Thread Starter
as you guys have said, its waste vegetable oil. ive seen kits for around 2g including the tank w/ heater, etc. everything.
im not exactly all that worried about fuel prices, but i figure the cost of the system is about the same as 25 tanks of #2. so in under a year it should about pay for itself if i get anywhere near the same MPG.
not to mention its just cool :Thumbup:
nope.... i stay away from TDS:barf:
_CH_ is offline
post #7 of 13 (permalink) Old 01-21-2006, 08:15 PM
Super Moderator
John_G's Avatar
CH,
That is a valid point on the cost. If you live in a warm climate, you can skate on the heater system.
I suggest finding a "Webb" fuel filter/heater in a truck salvage yard - look for one with the greenish mesh inside, it is a reuseable filter! Clean and re-install. Then go thru the pump and onto the factory filters.
WVO contains NONE of the "nasties" that newer diesels are working around for emissions - like sulphur. You will pass 2010 emissions with a 7.3L PSD using WVO or 80% biodiesel. The lubricity is also pretty good as I undrestand it.
I vote for LIBERTY!
John_G is offline
post #8 of 13 (permalink) Old 01-24-2006, 07:42 PM
barely smokin'
Send a message via AIM to guardrail
There's a great step by step write up on the a 7.3L conversion. I'll see if I can find it, it listed part numbers and routing etc.
02 F250, CC/LB/4x4 4" lift w/ 35's
Straight pipe, barely smokin'
AFE Stage 1
guardrail is offline
post #9 of 13 (permalink) Old 01-25-2006, 12:09 AM Thread Starter
awesome! that would be great!
_CH_ is offline
post #10 of 13 (permalink) Old 01-25-2006, 01:17 AM
barely smokin'
If you can view Pirate 4x4 the thread is here: http://www.pirate4x4.com/forum/showthread.php?t=400760&
If not here's the writeup, i don't know that the pictures will load or not.
Originally Posted by OverThrottle
I thought some of you guys might be interested in how I di d my conversion, since I see some of you guys are getting itno it as well.
My system's switchover is based off of thedieselstop's FordNut74's idea to use check valves and differential pressures to control switchover, and to have added reliability to the system. The system keeps two separate fuel systems up to the motor, so that with a pump failure or plugged filter you can still drive on diesel. In fact, the switchover to diesel is so smooth, you wouldn't even know if you didn't see it on the gauge. He is working on a kit using the same concept as I used for mine. I believe he also has a patent pending on the check valve switchover. Visit his site at http://www.vegistroke.com/ for more info. I also have incorporated ideas I have seen from various other member's conversions. Here is a diagram I drew up that shows the basic layout of my conversion. I simplified it by leaving off the coolant hoses to the various parts. The coolant is sourced and returned via the cabin heater hoses. The final heater exchanger, aluminum fuel lines (HOH), Davco filter, and Hotstick tank heater are all heated by the coolant, and in that order.
I colored the components based on which fuel is flowing through them. As you can see the stock fuel system is mostly unaltered. The only change is that instead of being routed straight from the stock filter to the heads, it goes through a check valve and into the FN74 heart instead. The stock design is to have the heads dead-headed, meaning that fuel goes into the heads as it is consumed, and the stock fuel return is from the integrated FPR in the filter housing. The powerstroke engines have the fuel rails integrated into the heads. This is a nice plus, because it keeps hot oil hot, and may even heat it more. The other side of each fuel rail in the head has a port that is plugged in the stock configuration. The WVO FPR is attached to these ports, and then set to a pressure high enough that it will not return any fuel at the stock pressure. The veggie FPR and purge valve actually have just WVO in them most of the time, but I colored them as both fuels because a small amount of diesel will pass through them during the fast purge cycle.
I currently have a 50 gallon Mueller crossed-poly marine fuel tank for my veggie use. I welded together a frame made of 1" square tube to mount the tank within. It is surrounded by 1" rigid Styrofoam insulation on all 4 sides and the bottom. Also, my tank frame has a 2.5" tall, 8' wide opening across the bottom to allow me to still haul a few sheets of plywood, or one layer of 2" thick lumber and use the full length of my bed. The tank frame is mounted down to the bed on each side with Grade 8 5/8" bolts. I am using the stock tank sending unit that came with the tank I also have a hotstick tank heater on order, but it has not come in yet. It is currently using the stock pickup tube, connected to a ½" push-lock hose to the veggie filter. Once the hotstick comes in, I will use that for the pickup tube.
AFE Stage 1
