hho any one using it? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by cookiemonsterblue, this thread has received 3 replies and been viewed 3077 times.
post #1 of 4 (permalink) Old 05-28-2010, 02:52 AM Thread Starter
cookiemonsterblue
I know this sounds like science fiction. An injection of hydrogen through the air induction system of a diesel will increase the efficiency of the burn creating more power and less emissions. By utilizing an hho production cell you can produce hydrogen on board. A search on youtube brings up all sorts of stuff on hho I stumbled on to it by accident while looking at welding stuff(which is some cool a** stuff in itself)
My question is has this topic been started, and is anyone utilizing hydrogen injection. I am looking for what output of hho is right for my 12 valve cummins. I know no one can say use ... and blamo 30% gain.
What I am hoping for is direction. To much hydrogen decreases the efficiency. So what perameters am I looking for, do I set by egt's, is there a point of knocking, I got a gazillion questions. So...
cookiemonsterblue is offline
post #2 of 4 (permalink) Old 05-28-2010, 03:08 AM Thread Starter
cookiemonsterblue
this video starts a little slow but by the end it is amazing
post #3 of 4 (permalink) Old 06-05-2010, 04:30 PM
buffalobob's Avatar
i read an article about a hydrogen injection system for diesel engines. will have to search for it.
2011 silverado lt, crewcab, short bed, 4X4, d-max/ allison
buffalobob is offline
post #4 of 4 (permalink) Old 11-02-2010, 03:07 AM
6.2smoke'r's Avatar
DONT DO IT !!!
i ran HHO in my 2002 chevy 6.0l gasser i have a mint setup all done right too. my ecm whent bazerk had alot higher egt's too. plus the mileage was worse cause you work your alternator too much ( and i have a 200 amp alt ) mine dropped by 2mpg's ! as far as in a diesel gos NEVER !! might as well run gasoline in place of diesel... does HHO produce flamable gas...Yes it does if you want something that is a proven " alternative fuel " for diesels look up "wood gas generator" i built a 23hp kubota generator to run off of it uses diesel only at idle.
1983 Chevy C-30 / Cummins 12v powered, 5" dual miter cut stacks, AFC FF, KDP killed, 3600 springs, #10 fuel plate, SM465 trans, 4bt flywheel, 4.56's
6.2smoke'r is offline
